I capture image from MIPI camera, I process and send them by socket to a PC.
Until today, everything were going well.
I need an ethernet speed of 1000 Mb/s. Without any reason, the ethernet speed of the jetson is down to 100Mb/s during the running during the process (maybe after after having sent 2/3 Go by socket).
I change the ethernet speed to 1000Mb/s, reboot the jetson, and the problem appears again.
Does someones already has the same problem ?
Notice that I do not use a PCI, it is the ethernet port of the developper kit, and it had been working well during 3 weeks.
Maybe it can help to figure out the problem :
Settings for eth0:
Supported ports: [ TP MII ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Half 1000baseT/Full
Supported pause frame use: Symmetric Receive-only
Supports auto-negotiation: Yes
Supported FEC modes: Not reported
Advertised link modes: 10baseT/Half 10baseT/Full
Advertised pause frame use: Symmetric Receive-only
Advertised auto-negotiation: Yes
Advertised FEC modes: Not reported
Link partner advertised link modes: 10baseT/Half 10baseT/Full
Link partner advertised pause frame use: Symmetric Receive-only
Link partner advertised auto-negotiation: Yes
Link partner advertised FEC modes: Not reported
Speed: 100Mb/s
Duplex: Full
Port: MII
PHYAD: 0
Transceiver: internal
Auto-negotiation: on
Cannot get wake-on-lan settings: Operation not permitted
Link detected: yes
Thank you for your help
