Hi guys,
I want to use a Jetson Xavier NX as the host system for an Azure Kinect
camera. After some minor processing I want to stream the point cloud from the
Kinect camera into another system using an Ethernet cable.
Unfortunately, the transmission of data is not fast enough. I ran some
test using iperf3 to check on the transfer speed between the Jetson and a
regular laptop.
This is what I got:
Using the Jetson as a server and calling iperf3 -c jetson from a regular laptop:
Connecting to host jetson, port 5201
[ ID] Interval Transfer Bandwidth Retr
[ 4] 0.00-10.00 sec 879 MBytes 737 Mbits/sec 43 sender
[ 4] 0.00-10.00 sec 875 MBytes 734 Mbits/sec receiver
Using the Jetson as a client and calling calling iperf3 -c not-the-jetson from the Jetson:
[ 4] 0.00-10.00 sec 163 MBytes 136 Mbits/sec 2501 sender
[ 4] 0.00-10.00 sec 162 MBytes 136 Mbits/sec receiver
As a reference, here is the output of the same test between two regular laptops
[ 4] 0.00-10.00 sec 1.10 GBytes 943 Mbits/sec 6 sender
[ 4] 0.00-10.00 sec 1.10 GBytes 941 Mbits/sec receiver
Here the info I got from calling ethtool eth0 in the Jetson
Settings for eth0:
Supported ports: [ TP MII ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Full
Supported pause frame use: Symmetric Receive-only
Supports auto-negotiation: Yes
Supported FEC modes: Not reported
Advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
Advertised pause frame use: Symmetric Receive-only
Advertised auto-negotiation: Yes
Advertised FEC modes: Not reported
Link partner advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
Link partner advertised pause frame use: Symmetric Receive-only
Link partner advertised auto-negotiation: Yes
Link partner advertised FEC modes: Not reported
Speed: 1000Mb/s
Duplex: Full
Port: MII
PHYAD: 1
Transceiver: internal
Auto-negotiation: on
Cannot get wake-on-lan settings: Operation not permitted
Link detected: yes
So, my question is: What do I need to do to improve the data transfer between the Jetson
and my laptop?
