万兆以太网up时会出现报错
报错打印如下,内核打印phy call trace
[ 138.037537] Aquantia AQR113C 6810000.ethernet:00: aqr107_read_status failed: -110
[ 138.045289] Aquantia AQR113C 6810000.ethernet:00: PHY system interface is not yet ready
[ 138.053640] ------------[ cut here ]------------
[ 138.053707] WARNING: CPU: 2 PID: 151 at drivers/net/phy/phy.c:958 phy_error+0x1c/0x60
[ 138.061786] Modules linked in: nvidia_modeset(OE) fuse lzo_rle lzo_compress zram ramoops reed_solomon loop nvgpu(E) aes_ce_blk crypto_simd cryptd aes_ce_cipher ghash_ce snd_soc_tegra210_ope snd_soc_tegra186_dspk snd_soc_tegra186_asrc snd_hda_codec_hdmi sha2_ce snd_soc_tegra210_mvc snd_soc_tegra210_iqc snd_soc_tegra186_arad snd_soc_tegra210_admaif snd_soc_tegra210_afc snd_soc_tegra210_dmic snd_soc_tegra210_adx snd_hda_tegra sha256_arm64 snd_soc_tegra210_adsp snd_soc_tegra210_amx snd_soc_tegra_pcm snd_soc_tegra210_mixer snd_soc_tegra_machine_driver sha1_ce snd_soc_tegra210_i2s snd_soc_tegra210_sfc snd_hda_codec nvidia(OE) snd_soc_tegra_utils nvadsp snd_soc_rt5640 snd_hda_core snd_soc_simple_card_utils pwm_fan snd_soc_tegra210_ahub snd_soc_spdif_tx nct1008 tegra_bpmp_thermal snd_soc_rl6231 tegra210_adma spi_tegra114 ina3221 userspace_alert binfmt_misc nvmap ip_tables x_tables [last unloaded: mtd]
[ 138.062120] CPU: 2 PID: 151 Comm: kworker/u24:2 Tainted: G W OE 5.10.104-tegra #22
[ 138.062124] Hardware name: Unknown Jetson AGX Orin/Jetson AGX Orin, BIOS 3.1-32827747 03/19/2023
[ 138.062140] Workqueue: events_power_efficient phy_state_machine
[ 138.062153] pstate: 60c00009 (nZCv daif +PAN +UAO -TCO BTYPE=–)
[ 138.062157] pc : phy_error+0x1c/0x60
[ 138.062161] lr : phy_error+0x1c/0x60
[ 138.062163] sp : ffff800011ffbd30
[ 138.062166] x29: ffff800011ffbd30 x28: ffffa1a1d2bd6000
[ 138.062172] x27: ffff20ac40022870 x26: ffff20ac40022820
[ 138.062178] x25: 0000000000000000 x24: 00000000ffffff92
[ 138.062184] x23: ffff20ac6e0974f8 x22: ffff20ac40960e80
[ 138.062189] x21: ffff20ac6e097000 x20: 0000000000000005
[ 138.062194] x19: ffff20ac6e097000 x18: 0000000000000010
[ 138.062202] x17: 0000000000000000 x16: ffffa1a1d0e33210
[ 138.062209] x15: ffff20ac409613f0 x14: 4333313152514120
[ 138.062214] x13: 6169746e61757141 x12: 656e72656874652e
[ 138.062219] x11: 3030303031383620 x10: 6d65747379732059
[ 138.062225] x9 : 4850203a30303a74 x8 : 6f6e207369206563
[ 138.062231] x7 : 61667265746e6920 x6 : c0000000ffffefff
[ 138.062236] x5 : 0000000000000000 x4 : ffff20bb6eafd958
[ 138.062241] x3 : ffff20ac40960e80 x2 : ffffa1a1d0fce170
[ 138.062247] x1 : ffff20ac40960e80 x0 : ffffa1a1d0fce170
[ 138.062259] Call trace:
[ 138.062266] phy_error+0x1c/0x60
[ 138.062271] phy_state_machine+0x90/0x220
[ 138.062305] process_one_work+0x1c4/0x4a0
[ 138.062311] worker_thread+0x54/0x430
[ 138.062318] kthread+0x148/0x170
[ 138.062339] ret_from_fork+0x10/0x24
[ 138.062345] —[ end trace adb20770a2c2f720 ]—
For information, do you observe the issue on developer kit? Do you use Jetpack 6.0GA(r36.3)?
使用的是jetpack 35.3.1,目前发现在不接网线时,出现这个错误后cat /proc/interrupts查询中断发现int触发了两次,断开int连接没有中断触发就不会报这个错误,但不接网线为什么会触发两次中断呢?
还是有问题,你们也没人回复啊
There seems duplicated topic opened and Ethernet firmware has problem
Have you contacted with PHY vendor?
