Hi !
I’m using the LT from last year on TX2
# R28 (release), REVISION: 2.0, GCID: 10567845, BOARD: t186ref, EABI: aarch64, DATE: Fri Mar 2 04:57:01 UTC 2018
Here is the inspection nvarguscamerasrc plugin from the system.
nvidia@tx2-cb:~$ gst-inspect-1.0 nvarguscamerasrc
Factory Details:
Rank primary (256)
Long-name NvArgusCameraSrc
Klass Video/Capture
Description nVidia ARGUS Camera Source
Author Viranjan Pagar <vpagar@nvidia.com>, Amit Pandya <apandya@nvidia.com>
Plugin Details:
Name nvarguscamerasrc
Description nVidia ARGUS Source Component
Filename /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvarguscamerasrc.so
Version 1.0.0
License Proprietary
Source module nvarguscamerasrc
Binary package NvARGUSCameraSrc
Origin URL http://nvidia.com/
GObject
+----GInitiallyUnowned
+----GstObject
+----GstElement
+----GstBaseSrc
+----GstNvArgusCameraSrc
Pad Templates:
SRC template: 'src'
Availability: Always
Capabilities:
video/x-raw(memory:NVMM)
width: [ 1, 2147483647 ]
height: [ 1, 2147483647 ]
format: { NV12 }
framerate: [ 0/1, 120/1 ]
Element Flags:
no flags set
Element Implementation:
Has change_state() function: gst_base_src_change_state
Element has no clocking capabilities.
Element has no URI handling capabilities.
Pads:
SRC: 'src'
Pad Template: 'src'
Element Properties:
name : The name of the object
flags: readable, writable
String. Default: "nvarguscamerasrc0"
parent : The parent of the object
Object of type "GstObject"
blocksize : Size in bytes to read per buffer (-1 = default)
Unsigned Integer. Range: 0 - 4294967295 Default: 4096
num-buffers : Number of buffers to output before sending EOS (-1 = unlimited)
Integer. Range: -1 - 2147483647 Default: -1
typefind : Run typefind before negotiating
Boolean. Default: false
do-timestamp : Apply current stream time to buffers
Boolean. Default: true
silent : Produce verbose output ?
timeout : timeout to capture in seconds (Either specify timeout or num-buffers, not both)
Unsigned Integer. Range: 0 - 2147483647 Default: 0
wbmode : White balance affects the color temperature of the photo
Enum "GstNvArgusCamWBMode" Default: 0, "off"
(0): off - GST_NVCAM_WB_MODE_OFF
(1): auto - GST_NVCAM_WB_MODE_AUTO
(2): incandescent - GST_NVCAM_WB_MODE_INCANDESCENT
(3): fluorescent - GST_NVCAM_WB_MODE_FLUORESCENT
(4): warm-fluorescent - GST_NVCAM_WB_MODE_WARM_FLUORESCENT
(5): daylight - GST_NVCAM_WB_MODE_DAYLIGHT
(6): cloudy-daylight - GST_NVCAM_WB_MODE_CLOUDY_DAYLIGHT
(7): twilight - GST_NVCAM_WB_MODE_TWILIGHT
(8): shade - GST_NVCAM_WB_MODE_SHADE
(9): manual - GST_NVCAM_WB_MODE_MANUAL
saturation : Property to adjust saturation value
Float. Range: 0 - 2 Default: 0
And for the work I found that I have to use manual control to exposure time, but according several links from the past
The parameters don’t exist on my current version, so is that possible that I just update that plugin only without reinstall OS ? Thank you very much !
