Why is the nvarguscamerasrc GStreamer element limited to 120 FPS max? Is the source of this element available anywhere?
hello arne.caspari,
may I know your sensor capability and also what’s the your current results.
thanks
I currently work on an IMX290. This sensor could produce for example 260 FPS @ 640x480 resolution. I could set such a mode with v4l2-ctl for example but not with the nvarguscamerasrc because the capabilities (GstCaps) of the element are limited to 120 FPS:
GObject
+----GInitiallyUnowned
+----GstObject
+----GstElement
+----GstBaseSrc
+----GstNvArgusCameraSrc
Pad Templates:
SRC template: 'src'
Availability: Always
Capabilities:
video/x-raw(memory:NVMM)
width: [ 1, 2147483647 ]
height: [ 1, 2147483647 ]
format: { (string)NV12 }
framerate: [ 0/1, 120/1 ]
Other sensors could produce more than 1000 FPS when running in cropped window mode so a frame rate limit does not really make sense at all.
hello arne.caspari,
please replace the libgstnvarguscamerasrc.so with the attachment,
you might perform warm-reboot to let the change takes effect.
thanks
Thank you very much but unfortunately the new plugin does not load:
(gst-plugin-scanner:2680): GStreamer-WARNING **: 08:49:36.285: Failed to load plugin '/usr/lib/gstreamer-1.0/libgstnvarguscamerasrc.so': /usr/lib/gstreamer-1.0/libgstnvarguscamerasrc.so: undefined symbol: _ZN9EGLStream13FrameConsumer6createEPN5Argus12OutputStreamEPNS1_6StatusE
Is this for Jetpack 32.1 ?
hello arne.caspari,
yes, I was based-on l4t-r32.1 to make pre-built library for your testing.
let me check what’s going-on.
hello arne.caspari,
please try again with the attachment, you should replace the pre-built library as below.
$ sudo cp ~/libgstnvarguscamerasrc.so /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvarguscamerasrc.so
I’ve also confirm the modification works, it removes the 120-fps frame rate upper bound limitation.
for example,
$ gst-inspect-1.0 nvarguscamerasrc
Pad Templates:
SRC template: 'src'
Capabilities:
framerate: [ 0/1, 2147483647/1 ]
devtalk1056210_Jun26_v2.tar.gz (27.3 KB)
Hello JerryChang,
I will test this again on a clean Jetpack installation later on. I am currently using an OpenEmbedded image but it uses the libraries from JetPack 32.1 so it should make no difference. I will come back after I tested it on the original JetPack.
Oh, silly me, I mixed up the attachments. The v2 attachment has the unresolved symbol fixed. I will test and let you know.
Thank you very much!
Jerry, I tried v2 but am still seeing the symbol error:
nvidia@nvidia-desktop:~$ rm ~/.cache/gstreamer-1.0/registry.aarch64.bin
nvidia@nvidia-desktop:~$ gst-inspect-1.0
(gst-plugin-scanner:9675): GStreamer-WARNING **: 09:14:12.394: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvarguscamerasrc.so': /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvarguscamerasrc.so: undefined symbol: _ZN9EGLStream13FrameConsumer6createEPN5Argus12OutputStreamEjPNS1_6StatusE
$ objdump -x libgstnvarguscamerasrc.so |grep EjPNS1
0000000000000000 F *UND* 0000000000000000 _ZN9EGLStream13FrameConsumer6createEPN5Argus12OutputStreamEjPNS1_6StatusE
This is with JetPack 4.2.1 / L4T 32.2 on TX2. I will try again with 4.2.2, but I want to make sure first that I have the right file. Is this correct for v2?—
$ sha256sum devtalk1056210_Jun26_v2.tar.gz devtalk1056210_Jun26_v2/libgstnvarguscamerasrc.so
65a2f403b862f6b3ab823ec7c72801f693f811f438477fe052a9e10a8b128892 devtalk1056210_Jun26_v2.tar.gz
dae759e9e7b78b5e71bbf6b65889c89c21df027b556b44f7f0f5f4001e39e9ac devtalk1056210_Jun26_v2/libgstnvarguscamerasrc.so
hello D3_cwhite,
please note that there’s code-base dependency.
to summarize, you should working with below to removes the 120-fps frame rate upper bound limitation.
JetPack 4.2/l4t-r32.1, to apply the pre-built library in comment #7.
JetPack 4.2.1/l4t-r32.2, please apply the pre-built library in Topic 1062039.
this change already integrate to release code-line, please expect later release will include that fix.
thanks
Dear Jerry Chang,
the download link in your comment #7 is broken. I got only an XML error page with Access Denied. Could you please fix the link or reupload the devtalk1056210_Jun26_v2.tar.gz file?
It is used by the CenturyArks IMX378 setup for Jetson TX2 which I need to use and CenturyArks doesn’t provide a copy or download mirror.
Best regards,
Robert
