Upgrade tensorrt on orin Nx jetpack 6.2
Is it possible to upgrade the tensorrt from jetpack 6.2 from 10.3 to something newer like 10.14 for an orin Nx?
Please find the upgradable package on the TensorRT download link below:
The latest version for JetPack 6 is 10.7 GA.
Thanks so much for this.
Is it possible to deploy tensorrt 10.14 on jetpack 6.2 on an orin Nx if we build the tensorrt 10.14 from source?
We have tested several versions of trt from 10.3 to 10.7, and found that our models have degraded accuracy and the predictions diverged significantly from that of onnxruntime. We have tested tensorrt10.14 and found that it works superbly with our model.
You can only run up to 10.7. It is not possible to run 10.14 on Jetpack 6.2.
