Upgrading gcc on jetson orin, L4T 35, is it safe?
I’m using L4T35, jetpack 5.1.5 because I need jax 0.3.25.
So a model needs dependency for a tool, which needs gcc>=10 to run.
Unfortunately, L4T 35 gcc is 9.3 or something.
Is it safe if I upgrade the gcc by sudo apt?
If not safe, I’m afraid I need to change the model implementation myself.
You may consider upgrade to Jetpack 6. gcc version is
$ gcc --version
gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0
Copyright (C) 2021 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
I want to update gcc only, but not cuda. it seems that updating to jetpack doesn’t support me to do this method.
So I had second post, with questions to another proposal.
pls answer to this proposal as well. Thank you so much!!!
