I have around 50 Jetson Xavier AGX running Jetpack 4.4.1 [L4T 32.4.4] to which I don’t have access physically and would like to be able to either upgrade the Jetpack version so I can upgrade the tensorflow version and install
tf-models-official or install tensorflow-addons. Is there a way to do this over the air or do I need to flash all of them with a new version?
Which TensorFlow version do you want?
The goal would be installing tensorflow-addons so whichever version of jetpack would allow that
We don’t provide the prebuilt for TensorFlow-addons.
You will need to build it from the source.
Its compatibility matrix can be found below:
This guide to build from source is for x86 machines it doesn’t run on arm, is there any solution?
Please check with the library owner to see if they support the Jetson environment and the building instructions.
