Hi guys,
currently, our team works on a project based on Jetson Orin Nano. Our goal is to do some video processing from two 640 * 480 60Hz cameras with 2 bytes per pixel. The nuance is that we use USB 2.0 to connect cameras, and we face with the bandwidth issues.
Our idea is to use USB type-A slot and USB type-C slot, for cameras 1 and 2 correspondingly, such that we can have allocated 480 mbps bandwidth per each camera, which is enough for us.
According to the board block diagram and lsusb output, they are attached to USB0 and USB1 ports on Jetson Orin Nano.
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=tegra-xusb/4p, 10000M
|\_\_ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 10000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=tegra-xusb/4p, 480M
|\_\_ Port 1: Dev 28, If 3, Class=CDC Data, Driver=cdc_acm, 480M
|\_\_ Port 1: Dev 28, If 1, Class=Video, Driver=, 480M
|\_\_ Port 1: Dev 28, If 2, Class=Communications, Driver=cdc_acm, 480M
|\_\_ Port 1: Dev 28, If 0, Class=Video, Driver=, 480M
|\_\_ Port 2: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
|\_\_ Port 3: Dev 27, If 2, Class=Communications, Driver=cdc_acm, 480M
|\_\_ Port 3: Dev 27, If 0, Class=Video, Driver=, 480M
|\_\_ Port 3: Dev 27, If 3, Class=CDC Data, Driver=cdc_acm, 480M
|\_\_ Port 3: Dev 27, If 1, Class=Video, Driver=, 480M
|\_\_ Port 3: Dev 3, If 0, Class=Wireless, Driver=rtk_btusb, 12M
|\_\_ Port 3: Dev 3, If 1, Class=Wireless, Driver=rtk_btusb, 12M
And according to page 24 in this technical reference we should have 480 Mbps per each port:
Each USB 2.0 port (3x) operates in USB 2.0 high-speed mode when connecting directly to a USB 2.0 peripheral and operates in USB 1.1 full- and low-speed modes when connecting directly to a USB 1.1 peripheral. When operating in High-Speed mode, each USB 2.0 port is allocated with one High-Speed unit bandwidth. Approximately a 480 Mb/s bandwidth is allocated to each USB 2.0 port. All USB 2.0 ports operating in full- or low-speed modes share one full- and low-speed bus instance, which means 12 Mb/s theoretical bandwidth is distributed across these ports.
But in fact we don’t observe such numbers.
Do you have any ideas what is wrong here? Do we use a wrong document as a reference, or our understanding is wrong?
