I want to test USB 3.1 Gen 2 speed
shall i connect parallely 2 Xavier AGX board by using Type c to type c cable
other than any way is to there to test the speed of USB 3.1 Gen 2
Kindly requesting you to help us on this.
The setup may not be correct. For testing it, Xavier is in host mode. One device is connected and run in device mode. You can get a USB 3.1 pendrive and do read/write test.
