USB 3.2 port on a custom carrier board limited to gen1 speeds
According to Orin nano datasheet, all USB 3.2 ports are capable of running at 10Gbit speeds. I tried testing this on my custom carrier board with a USB 3.2 Gen2 device (a USB stick), but it seems that it is limited to gen1 speed. It’s not achieving the write/read speeds it is supposed to and in lsusb I can see that 10Gbit is not listed as a supported speed.
  wSpeedsSupported   0x000c
      Device can operate at High Speed (480Mbps)
      Device can operate at SuperSpeed (5Gbps)
Now for the sake of argument, let’s assume that the device - usb stick - is ok. Do you know of any other issues that might prevent the USB (A) port from achieving 10Gbit speeds?
System:
Jetson Orin nano, Jetpack 6.0
Full reports:
dmesg_report.txt (58.7 KB)
lsusb_report.txt (24.2 KB)
Schematics:
jetson_usb_connector_2
What is the speed of this USB stick when it is put on devkit?
I tested it on an AGX Orin devkit and, although lsusb reported still the same, the speeds were okay - about 800 MB/sec when connected to the USB A ports next to the displayport. I then however tested it again on the original carrier board and the speeds were also okay.
@WayneWWW I’m really sorry for this. It seems that everything was okay the whole time. I must have somehow messed up what speeds was it supposed to achieve.
