USB Audio gadget on Jetson Orin devkit 64G
I have the Jetson Orin devkit 64G and I was wondering if is there is any guidance on getting usb audio gadget to work. It appears that all other ubuntu packages for jetson like IGX have the g_audio module included with the kernel but not the Jetson l4t.
I’m on 36.4.3 JetPack 6.2
I have compiled the modules below, and added them to lib/modules followed with depmod etc…
drivers/usb/gadget/function/u_audio.ko
drivers/usb/gadget/function/usb_f_uac1.ko
drivers/usb/gadget/function/usb_f_uac2.ko
I have disabled the usb-device mode so that there is no conflict.
sudo systemctl disable nv-l4t-usb-device-mode-runtime.service
sudo systemctl disable nv-l4t-usb-device-mode.service
After reboot I am able to load the modules
sudo modprobe libcomposite -v
sudo modprobe u_audio -v
sudo modprobe usb_f_uac1 -v
sudo modprobe usb_f_uac2 -v
sudo modprobe tegra-xudc -v
insmod /lib/modules/5.15.148-tegra/kernel/drivers/usb/gadget/libcomposite.ko
insmod /lib/modules/5.15.148-tegra/kernel/drivers/usb/gadget/function/u_audio.ko
insmod /lib/modules/5.15.148-tegra/kernel/drivers/usb/gadget/function/usb_f_uac1.ko
insmod /lib/modules/5.15.148-tegra/kernel/drivers/usb/gadget/function/usb_f_uac2.ko
However, when I’m trying to create usb_audio gadget I am getting below error:
[   81.414095] u_audio: module verification failed: signature and/or required key missing - tainting kernel
[   91.422520] udc 3550000.usb: failed to start test_uac1_gadget: -19
[  122.446570] configfs-gadget gadget: afunc_bind:1163 Error!
[  122.446604] udc 3550000.usb: failed to start g1: -19
[  136.160645] configfs-gadget gadget: afunc_bind:1163 Error!
[  136.160737] udc 3550000.usb: failed to start g1: -19
Could you please advise ? I only purchased this entire device for the use of usb audio gadget mode
Do you build the modules by following:
Kernel Customization — NVIDIA Jetson Linux Developer Guide 1 documentation
Not sure but it seems like the error is reported if the ko files are copied to the system from another system. Please try to enable the corresponding configs and rebuild kernel.
Thanks for the reply @DaneLLL
I have indeed compiled these on the orin itself using the guide and not copied them from another system
Do you rebuild and replace both Linux kernel and NVIDIA out-of-tree modules?
Yes I have tried using the guide and built everything but it doesn’t seem to build these modules and I have to explicitly build them. See below
Build and install:
cd $HOME
mkdir kernel_customization
cd kernel_customization
wget https://developer.nvidia.com/downloads/embedded/l4t/r36_release_v4.3/sources/public_sources.tbz2
tar -xvf public_sources.tbz2
cd Linux_for_Tegra/source/
tar xf kernel_src.tbz2
tar xf kernel_oot_modules_src.tbz2
tar xf nvidia_kernel_display_driver_source.tbz2
vi usb_audio_fragment.config
cat usb_audio_fragment.config
# usb_audio_fragment.config
# USB Audio dependencies
CONFIG_USB_SUPPORT=y
CONFIG_USB_GADGET=y
CONFIG_SND=y
CONFIG_USB_CONFIGFS=m
# USB Audio modules
CONFIG_USB_U_AUDIO=m
CONFIG_USB_F_UAC1=m
CONFIG_USB_F_UAC2=m
cd kernel/kernel-jammy-src
scripts/kconfig/merge_config.sh -m arch/arm64/configs/defconfig ../../usb_audio_fragment.config
Using arch/arm64/configs/defconfig as base
Merging ../../usb_audio_fragment.config
# merged configuration written to .config (needs make)
cp .config arch/arm64/configs/defconfig
grep -E '^(CONFIG_USB_F_UAC1|CONFIG_USB_F_UAC2|CONFIG_USB_U_AUDIO)' arch/arm64/configs/defconfig
CONFIG_USB_F_UAC1=m
CONFIG_USB_F_UAC2=m
cd ../../
make -C kernel
Kernel Image: /home/jetson/kernel_customization/Linux_for_Tegra/source/kernel/kernel-jammy-src/arch/arm64/boot/Image
Kernel sources compiled successfully.
export INSTALL_MOD_PATH=/
sudo -E make install -C kernel
sudo cp kernel/kernel-jammy-src/arch/arm64/boot/Image /boot/Image
export KERNEL_HEADERS=$PWD/kernel/kernel-jammy-src
make modules
make[1]: Leaving directory '/home/jetson/kernel_customization/Linux_for_Tegra/source/nvdisplay'
Display driver compiled successfully.
find . -name "*.ko" | grep -E "f_uac|u_audio"
# Looks like uac or audio modules were not built !
sudo -E make modules_install
sudo nv-update-initrd
make dtbs
DTBs compiled successfully.
sudo cp kernel-devicetree/generic-dts/dtbs/* /boot/dtb
sudo systemctl reboot -i
After reboot:
vi create_usb_audio.sh
chmod +x create_usb_audio.sh
sudo ./create_usb_audio.sh
Checking and loading required modules...
Loading module: libcomposite
Loading module: u_audio
modprobe: FATAL: Module u_audio not found in directory /lib/modules/5.15.148-tegra
Failed to load module: u_audio
Error: Failed to load essential module u_audio. Exiting.
# Looks like modules are not built, lets force creation
make ARCH=arm64 CONFIG_USB_F_UAC1=m CONFIG_USB_F_UAC2=m CONFIG_USB_U_AUDIO=m M=drivers/usb/gadget/function modules
  CC [M]  drivers/usb/gadget/function/u_audio.o
  CC [M]  drivers/usb/gadget/function/f_uac1.o
  LD [M]  drivers/usb/gadget/function/usb_f_uac1.o
  CC [M]  drivers/usb/gadget/function/f_uac2.o
  LD [M]  drivers/usb/gadget/function/usb_f_uac2.o
  MODPOST drivers/usb/gadget/function/Module.symvers
  CC [M]  drivers/usb/gadget/function/u_ether.mod.o
  LD [M]  drivers/usb/gadget/function/u_ether.ko
  CC [M]  drivers/usb/gadget/function/u_serial.mod.o
  LD [M]  drivers/usb/gadget/function/u_serial.ko
  CC [M]  drivers/usb/gadget/function/usb_f_accessory.mod.o
  LD [M]  drivers/usb/gadget/function/usb_f_accessory.ko
  CC [M]  drivers/usb/gadget/function/usb_f_acm.mod.o
  LD [M]  drivers/usb/gadget/function/usb_f_acm.ko
  CC [M]  drivers/usb/gadget/function/usb_f_ecm.mod.o
  LD [M]  drivers/usb/gadget/function/usb_f_ecm.ko
  CC [M]  drivers/usb/gadget/function/usb_f_ecm_subset.mod.o
  LD [M]  drivers/usb/gadget/function/usb_f_ecm_subset.ko
  CC [M]  drivers/usb/gadget/function/usb_f_eem.mod.o
  LD [M]  drivers/usb/gadget/function/usb_f_eem.ko
  CC [M]  drivers/usb/gadget/function/usb_f_fs.mod.o
  LD [M]  drivers/usb/gadget/function/usb_f_fs.ko
  CC [M]  drivers/usb/gadget/function/usb_f_mass_storage.mod.o
  LD [M]  drivers/usb/gadget/function/usb_f_mass_storage.ko
  CC [M]  drivers/usb/gadget/function/usb_f_ncm.mod.o
  LD [M]  drivers/usb/gadget/function/usb_f_ncm.ko
  CC [M]  drivers/usb/gadget/function/usb_f_obex.mod.o
  LD [M]  drivers/usb/gadget/function/usb_f_obex.ko
  CC [M]  drivers/usb/gadget/function/usb_f_rndis.mod.o
  LD [M]  drivers/usb/gadget/function/usb_f_rndis.ko
  CC [M]  drivers/usb/gadget/function/usb_f_serial.mod.o
  LD [M]  drivers/usb/gadget/function/usb_f_serial.ko
  CC [M]  drivers/usb/gadget/function/u_audio.mod.o
  LD [M]  drivers/usb/gadget/function/u_audio.ko
  CC [M]  drivers/usb/gadget/function/usb_f_uac1.mod.o
  LD [M]  drivers/usb/gadget/function/usb_f_uac1.ko
  CC [M]  drivers/usb/gadget/function/usb_f_uac2.mod.o
  LD [M]  drivers/usb/gadget/function/usb_f_uac2.ko
# Great!, the modules are built, lets copy them
sudo cp -v drivers/usb/gadget/function/*.ko /lib/modules/5.15.148-tegra/kernel/drivers/usb/gadget/function/ && sudo chmod 644 /lib/modules/5.15.148-tegra/kernel/drivers/usb/gadget/function/*.ko && sudo depmod -a
'drivers/usb/gadget/function/u_audio.ko' -> '/lib/modules/5.15.148-tegra/kernel/drivers/usb/gadget/function/u_audio.ko'
'drivers/usb/gadget/function/u_ether.ko' -> '/lib/modules/5.15.148-tegra/kernel/drivers/usb/gadget/function/u_ether.ko'
'drivers/usb/gadget/function/usb_f_accessory.ko' -> '/lib/modules/5.15.148-tegra/kernel/drivers/usb/gadget/function/usb_f_accessory.ko'
'drivers/usb/gadget/function/usb_f_acm.ko' -> '/lib/modules/5.15.148-tegra/kernel/drivers/usb/gadget/function/usb_f_acm.ko'
'drivers/usb/gadget/function/usb_f_ecm.ko' -> '/lib/modules/5.15.148-tegra/kernel/drivers/usb/gadget/function/usb_f_ecm.ko'
'drivers/usb/gadget/function/usb_f_ecm_subset.ko' -> '/lib/modules/5.15.148-tegra/kernel/drivers/usb/gadget/function/usb_f_ecm_subset.ko'
'drivers/usb/gadget/function/usb_f_eem.ko' -> '/lib/modules/5.15.148-tegra/kernel/drivers/usb/gadget/function/usb_f_eem.ko'
'drivers/usb/gadget/function/usb_f_fs.ko' -> '/lib/modules/5.15.148-tegra/kernel/drivers/usb/gadget/function/usb_f_fs.ko'
'drivers/usb/gadget/function/usb_f_mass_storage.ko' -> '/lib/modules/5.15.148-tegra/kernel/drivers/usb/gadget/function/usb_f_mass_storage.ko'
'drivers/usb/gadget/function/usb_f_ncm.ko' -> '/lib/modules/5.15.148-tegra/kernel/drivers/usb/gadget/function/usb_f_ncm.ko'
'drivers/usb/gadget/function/usb_f_obex.ko' -> '/lib/modules/5.15.148-tegra/kernel/drivers/usb/gadget/function/usb_f_obex.ko'
'drivers/usb/gadget/function/usb_f_rndis.ko' -> '/lib/modules/5.15.148-tegra/kernel/drivers/usb/gadget/function/usb_f_rndis.ko'
'drivers/usb/gadget/function/usb_f_serial.ko' -> '/lib/modules/5.15.148-tegra/kernel/drivers/usb/gadget/function/usb_f_serial.ko'
'drivers/usb/gadget/function/usb_f_uac1.ko' -> '/lib/modules/5.15.148-tegra/kernel/drivers/usb/gadget/function/usb_f_uac1.ko'
'drivers/usb/gadget/function/usb_f_uac2.ko' -> '/lib/modules/5.15.148-tegra/kernel/drivers/usb/gadget/function/usb_f_uac2.ko'
'drivers/usb/gadget/function/u_serial.ko' -> '/lib/modules/5.15.148-tegra/kernel/drivers/usb/gadget/function/u_serial.ko'
sudo depmod -a
Create gadget:
sudo ./create_usb_audio.sh create
Creating USB Audio Gadget...
Loading required modules...
Loading module: usb_f_uac1
Loading module: usb_f_uac2
Enabling gadget with UDC: 3550000.usb
./create_usb_audio.sh: line 153: echo: write error: No such device
Warning: Failed to enable gadget with UDC
Verifying final configuration:
libcomposite: Loaded successfully
u_audio: Loaded successfully
usb_f_uac1: Loaded successfully
usb_f_uac2: Loaded successfully
Checking USB device status...
Warning: USB device not found in system yet
sudo dmesg| tail
[   16.934062] rtk_btusb: btusb_notify: hci0 evt 3
[   16.983169] NET: Registered PF_ALG protocol family
[   17.115688] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
[   17.143722] [drm] Initialized nvidia-drm 0.0.0 20160202 for 13800000.display on minor 1
[   17.145700] nv_platform 13800000.display: [drm] Cannot find any crtc or sizes
[   19.395358] ACK 04 d4
[   19.396679] ACK 04 d4
[   19.413641] IPv6: ADDRCONF(NETDEV_CHANGE): wlP1p1s0: link becomes ready
[   19.772714] rfkill: input handler disabled
[  146.683876] udc 3550000.usb: failed to start g1: -19
Error reproduced:
Script create_usb_audio.sh for reference:
#!/bin/bash
# Check if running as root
if [[ $EUID -ne 0 ]]; then
   echo "This script must be run as root"
   exit 1
fi
# Global variables
GADGET_NAME="g1"
CONFIGFS_ROOT="/sys/kernel/config"
GADGET_DIR="$CONFIGFS_ROOT/usb_gadget/$GADGET_NAME"
REQUIRED_MODULES=(
    "libcomposite"
    "u_audio"
    "usb_f_uac1"
    "usb_f_uac2"
# Function to check if configfs is mounted
check_configfs() {
    if ! mount | grep -q "^configfs on $CONFIGFS_ROOT"; then
        echo "Mounting configfs..."
        mount -t configfs none "$CONFIGFS_ROOT"
        if [ $? -ne 0 ]; then
            echo "Error: Failed to mount configfs"
            return 1
        fi
    fi
    return 0
# Function to perform cleanup
cleanup() {
    echo "Cleaning up USB gadget..."
    if [ -d "$GADGET_DIR" ]; then
        # Ensure we're in the gadget directory
        cd "$GADGET_DIR" || exit 1
        # Disable UDC first
        if [ -f "UDC" ]; then
            echo "" > UDC
        fi
        # Remove function link
        rm -f configs/c.1/uac1.0 2>/dev/null
        # Remove directories in reverse order
        rm -rf functions/uac1.0 2>/dev/null
        rm -rf configs/c.1/strings/0x409 2>/dev/null
        rm -rf configs/c.1 2>/dev/null
        rm -rf strings/0x409 2>/dev/null
        # Return to parent and remove gadget directory
        cd ..
        rmdir "$GADGET_NAME" 2>/dev/null
    fi
    echo "Cleanup completed"
# Function to load module with verification
load_module() {
    local module=$1
    if ! lsmod | grep -q "^$module "; then
        echo "Loading module: $module"
        modprobe $module -v
        sleep 1  # Give the module time to initialize
            echo "Failed to load module: $module"
            return 1
        fi
    else
        echo "Module $module is already loaded"
    fi
    return 0
# Function to create gadget
create_gadget() {
    echo "Creating USB Audio Gadget..."
    # Check and mount configfs
    if ! check_configfs; then
        echo "Error: ConfigFS not available"
        exit 1
    fi
    # Load required modules
    echo "Loading required modules..."
    for module in "${REQUIRED_MODULES[@]}"; do
        if ! load_module $module; then
            echo "Warning: Failed to load module $module"
            # Continue anyway as some modules might be built into the kernel
        fi
    done
    # Create gadget directory
    mkdir -p "$GADGET_DIR" || exit 1
    # USB device configuration
    echo 0x1d6b > idVendor  # Linux Foundation
    echo 0x0104 > idProduct # Multifunction Composite Gadget
    echo 0x0100 > bcdDevice # Version 1.0.0
    echo 0x0200 > bcdUSB   # USB 2.0
    # Device info
    mkdir -p strings/0x409
    echo "fedcba9876543210" > strings/0x409/serialnumber
    echo "NVIDIA" > strings/0x409/manufacturer
    echo "USB Audio Gadget" > strings/0x409/product
    # Create configuration
    mkdir -p configs/c.1/strings/0x409
    echo "UAC1 Config" > configs/c.1/strings/0x409/configuration
    echo 250 > configs/c.1/MaxPower
    # Create UAC1 function with error checking
    mkdir -p functions/uac1.0
    if [ -d "functions/uac1.0" ]; then
        # Try to set audio parameters with error checking
        if [ -f "functions/uac1.0/sample_rate" ]; then
            echo 48000 > functions/uac1.0/sample_rate
        fi
        if [ -f "functions/uac1.0/channels" ]; then
            echo 2 > functions/uac1.0/channels
        fi
        if [ -f "functions/uac1.0/bits_per_sample" ]; then
            echo 16 > functions/uac1.0/bits_per_sample
        fi
    else
        echo "Warning: Failed to create UAC1 function directory"
    fi
    # Link function to configuration with error checking
    ln -s functions/uac1.0 configs/c.1/ 2>/dev/null
    if [ ! -L "configs/c.1/uac1.0" ]; then
        echo "Warning: Failed to create function symlink"
    fi
    # Find and verify UDC
    UDC=$(ls /sys/class/udc | head -n1)
    if [ -z "$UDC" ]; then
        echo "Error: No UDC available"
        cleanup
        exit 1
    fi
    # Enable the gadget with error checking
    echo "Enabling gadget with UDC: $UDC"
    echo "$UDC" > UDC
    sleep 1
    # Verify gadget is enabled
    CURRENT_UDC=$(cat UDC)
    if [ -z "$CURRENT_UDC" ]; then
        echo "Warning: Failed to enable gadget with UDC"
    else
        echo "Gadget enabled successfully with UDC: $CURRENT_UDC"
    fi
    # Show final status
    echo -e "\nVerifying final configuration:"
        if lsmod | grep -q "^$module "; then
            echo "$module: Loaded successfully"
        else
            echo "$module: Not loaded (might be built into kernel)"
        fi
    done
    # Check if gadget appears in USB devices
    echo -e "\nChecking USB device status..."
    if lsusb | grep -q "1d6b:0104"; then
        echo "USB device found in system"
    else
        echo "Warning: USB device not found in system yet"
    fi
# Function to check status
check_status() {
    echo "=== USB Audio Gadget Status ==="
    echo -e "\n1. ConfigFS Mount Status:"
    if mount | grep -q "^configfs on $CONFIGFS_ROOT"; then
        echo "✓ ConfigFS is mounted"
    else
        echo "✗ ConfigFS is not mounted"
    fi
    echo -e "\n2. Gadget Status:"
        echo "✓ Gadget exists at $GADGET_DIR"
        if [ -f "$GADGET_DIR/UDC" ]; then
            UDC_STATUS=$(cat "$GADGET_DIR/UDC")
            if [ -n "$UDC_STATUS" ]; then
                echo "✓ Gadget is active on UDC: $UDC_STATUS"
            else
                echo "✗ Gadget is inactive (no UDC assigned)"
            fi
        fi
        echo -e "\nGadget Configuration:"
        if [ -f "$GADGET_DIR/idVendor" ]; then
            echo "- Vendor ID: 0x$(cat $GADGET_DIR/idVendor)"
        fi
        if [ -f "$GADGET_DIR/idProduct" ]; then
            echo "- Product ID: 0x$(cat $GADGET_DIR/idProduct)"
        fi
        echo -e "\nAudio Configuration:"
        if [ -f "$GADGET_DIR/functions/uac1.0/sample_rate" ]; then
            echo "- Sample Rate: $(cat $GADGET_DIR/functions/uac1.0/sample_rate) Hz"
        fi
        if [ -f "$GADGET_DIR/functions/uac1.0/channels" ]; then
            echo "- Channels: $(cat $GADGET_DIR/functions/uac1.0/channels)"
        fi
        if [ -f "$GADGET_DIR/functions/uac1.0/bits_per_sample" ]; then
            echo "- Bits per Sample: $(cat $GADGET_DIR/functions/uac1.0/bits_per_sample)"
        fi
    else
        echo "✗ No gadget exists at $GADGET_DIR"
    fi
    echo -e "\n3. Required Modules Status:"
            echo "✓ $module: Loaded"
        else
            echo "✗ $module: Not loaded"
        fi
    done
    echo -e "\n4. USB Device Status:"
        echo "✓ USB device found in system (1d6b:0104)"
        echo -e "\nDevice in lsusb:"
        lsusb | grep "1d6b:0104"
    else
        echo "✗ USB device not found in system"
    fi
    echo -e "\n5. System Audio Status:"
    if command -v aplay >/dev/null; then
        echo "ALSA Audio Devices:"
        aplay -l
    else
        echo "aplay not available - can't check audio devices"
    fi
# Show usage information
usage() {
    echo "Usage: $0 [command]"
    echo "Commands:"
    echo "  create    - Create new USB audio gadget"
    echo "  cleanup   - Remove existing USB audio gadget"
    echo "  recreate  - Remove existing gadget and create new one"
    echo "  status    - Show current gadget status"
    exit 1
# Main script
case "$1" in
    "create")
        create_gadget
    "cleanup")
        cleanup
    "recreate")
        cleanup
        create_gadget
    "status")
        check_status
        usage
esac
UPDATE:
I have now ran:
make ARCH=arm64 defconfig
make ARCH=arm64 menuconfig # Selected the UAC1 and UAC2 (had to make the USB gadget a module)
make ARCH=arm64 savedefconfig
cp defconfig arch/arm64/configs/defconfig
cd ../../
make -C kernel
Above has built the correct modules without having to force it, I have followed rest of the instructions but even now I get the same error at the end:
[   62.712439] udc 3550000.usb: failed to start g1: -19
Looks like there is number of similar topics that were closed without resolution
I’m really hoping we can resolve this @DaneLLL because this is quite expensive device and I need it specifically for USB audio which seem to be not working
Since we don’t have much experience in the function, would see if other users can check and share experience.
Jetpack 6.2 is wit kernel 5.15 and Jetpack 5.1.5 is with kernel 5.10. And you may try to enable the same configs on K5.10, to check whether enabling the configs works on different kernel version.
So I’ve just moved back to kernel 5.10 and I get the same error :
root@ubuntu:/home/jetson# uname -r
5.10.104-tegra
root@ubuntu:/home/jetson# dmesg | tail
[   19.255990] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x2080014a result 0x56:
[   19.284468] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
[   19.284994] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x730190 result 0x56:
[   19.763325] nvethernet 6810000.ethernet: [xpcs_lane_bring_up][477][type:0x4][loga-0x0] PCS block lock SUCCESS
[   19.763407] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   19.764161] nvethernet 6810000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[   22.233443] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[   42.451175] vdd-12v-sys: disabling
[   42.451216] vdd-3v3-ftdi: disabling
[   54.275666] configfs-gadget 3550000.xudc: failed to start g1: -19
Would it be possible to get someone from engineering team from nvidia to advise on this ? It feels like I bought a expensive car with a missing wheel.
The error looks identical on K5.10 and K5.15. Would suggest add prints in the driver code to check why it returns failed to start g1: -19. May check what -19 means.
I’ve now also tried the ubuntu provided image which has the audio modules available in their image. There is a legacy audio module called g_audio which is handling creation of usb audio device without having to run bash scripts, just running modprobe g_audio should bring up a device and it should immediately be visible via connected usb-c cable on other device. This works on raspberry pi perfectly.
I have download the official ubuntu image:
https://cdimage.ubuntu.com/releases/jammy/release/nvidia-tegra/ubuntu-22.04-preinstalled-server-arm64+tegra-igx.img.xz
Extracted it to USB drive using rufus on windows, and I have booted the Jetson Orin from it.
When I just ran modprobe g_audio
I got this message:
[154957.460893] udc-core: couldn't find an available UDC - added [g_audio] to list of pending drivers
Then I have ran the modprobe tegra_xudc
And I got the message below
[154998.606361] udc 3550000.usb: failed to start g_audio: -19
[154998.606882] tegra-xudc 3550000.usb: failed to add USB gadget: -19
It appears that the tegra-xudc is at fault here as it’s unable to bring up the audio gadget interface.
As mentioned earlier @DaneLLL is it possible to mention it somewhere with the product team for this ? This looks like a defect in a product
Will check it with our team. It looks to be an additional function since it is not enabled in default upstream kernel. We don’t much experience in the function and need other users to share experience.
Thanks. There are other “gadget” functions enabled by default, but not this one. Someone had to make a decision to not include it, while it’s an industry standard. All Ubuntu images have the audio gadget included in the mainstream kernel, and so does Raspberry Pi. For some reason, this feature was skipped from tegra-xudc by the looks of it. Can you advise how I can claim a refund for this device based on this thread?
If the developer kit is physically broken, you may ask for RMA. Please try like:
[playback]
// get index of the audio device:
$ aplay -l
(...skip)
card 2: M [Plantronics Blackwire C220 M], device 0: USB Audio [USB Audio]
  Subdevices: 0/1
  Subdevice #0: subdevice #0
// run the command. hw:2,0 is card 2, device 0
$ aplay -Dhw:2,0  test_stereo_44100Hz_16bit_PCM.wav
[recording]
$ arecord -l
(...skip)
  Subdevices: 0/1
$ arecord -D hw:2,0 -c2 -d 10 -r 44100 -f S16_LE a.wav
And please check if USB Audio gadget can only run in other mode instead of isochronous endpoint. There is a constraint:
UAC2 and tegra-xUDC ISOC transfers - #3 by DaneLLL
