Hi, I would like to add a USB audio gadget (UAC2) to the composite device used on the jetson nano (l4t). I have so far not been successful.
As a first step, I am now first disabling the composite device, and then creating a new USB gadget just for audio.
Here is the script I use to create the UAC2 audio gadget and saved in the file create_usb_audio_gadget.sh.
#!/bin/bash
cd /sys/kernel/config/usb_gadget
# create new gadget
mkdir -p g1
cd g1
echo 0x0955 > idVendor
echo 0xB400 > idProduct
echo 0x001 > bcdDevice
mkdir -p strings/0x409
echo 0x123456789 > strings/0x409/serialnumber
echo "NVIDIA" > strings/0x409/manufacturer
echo "USB Audio Gadget" > strings/0x409/product
mkdir -p configs/c.1
# create the audio gadget
mkdir -p functions/uac2.aud0
ln -s functions/uac2.aud0 configs/c.1
# activate the gadget
ls /sys/class/udc > UDC
Here are the steps I have used
sudo systemctl stop nv-l4t-usb-device-modeto deactivate the composite device ./create_usb_audio_gadget.sh
This results in a segementation fault and here is the log I obtained from dmesg.
[ 470.226448] (null): afunc_bind:1071 Error!
[ 470.230788] Unexpected driver unregister!
[ 470.230864] ------------[ cut here ]------------
[ 470.235489] WARNING: CPU: 0 PID: 6725 at /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/drivers/base/driver.c:191 driver_unregister+0x4c/0x58
[ 470.248437] Modules linked in: overlay zram spidev nvgpu bluedroid_pm ip_tables x_tables
[ 470.248586] CPU: 0 PID: 6725 Comm: ls Not tainted 4.9.140-tegra #1
[ 470.248602] Hardware name: NVIDIA Jetson Nano Developer Kit (DT)
[ 470.248621] task: ffffffc0c991f000 task.stack: ffffffc0f5a7c000
[ 470.248647] PC is at driver_unregister+0x4c/0x58
[ 470.248670] LR is at driver_unregister+0x4c/0x58
[ 470.248692] pc : [<ffffff8008782fdc>] lr : [<ffffff8008782fdc>] pstate: 40400145
[ 470.248705] sp : ffffffc0f5a7fb70
[ 470.248721] x29: ffffffc0f5a7fb70 x28: ffffffc0d21480c8
[ 470.248765] x27: ffffffc0f3af4550 x26: ffffffc0f3af4600
[ 470.248802] x25: ffffffc0f5ab4c88 x24: ffffff80094a2758
[ 470.248838] x23: ffffff800a103e90 x22: ffffffc0f5ab4800
[ 470.248872] x21: ffffffc0f3af4568 x20: ffffffc0d21480f0
[ 470.248905] x19: ffffffc0d2148458 x18: 0000000000000010
[ 470.248939] x17: 0000000000000001 x16: 0000000000000007
[ 470.248973] x15: ffffffffffffffff x14: ffffff808a138a02
[ 470.249006] x13: 0000000000000000 x12: 0000000000000006
[ 470.249038] x11: 0000000000000002 x10: 0000000000000322
[ 470.249072] x9 : 0000000000000001 x8 : ffffffc0fefa1e6b
[ 470.249104] x7 : 0000000000000000 x6 : 000000000b3ae2d3
[ 470.249137] x5 : 0000000000000000 x4 : ffffffc0fefb5be8
[ 470.249169] x3 : ffffffc0fefb5be8 x2 : 0000000000000007
[ 470.249201] x1 : ffffffc0c991f000 x0 : 000000000000001d
[ 470.249247] ---[ end trace 41e809c1c69c038a ]---
[ 470.253903] Call trace:
[ 470.253935] [<ffffff8008782fdc>] driver_unregister+0x4c/0x58
[ 470.253967] [<ffffff8008784568>] platform_driver_unregister+0x20/0x30
[ 470.254005] [<ffffff8008ab32d4>] afunc_unbind+0x24/0x50
[ 470.254039] [<ffffff8008a8f094>] purge_configs_funcs+0xac/0x150
[ 470.254068] [<ffffff8008a8f4a0>] configfs_composite_bind+0x300/0x478
[ 470.254099] [<ffffff8008a928d8>] udc_bind_to_driver+0x48/0x120
[ 470.254120] [<ffffff8008a930b8>] usb_gadget_probe_driver+0xa8/0x148
[ 470.254147] [<ffffff8008a90334>] gadget_dev_desc_UDC_store+0xcc/0x110
[ 470.254183] [<ffffff80082f43e8>] configfs_write_file+0xc0/0x198
[ 470.254214] [<ffffff800825b560>] __vfs_write+0x48/0x118
[ 470.254239] [<ffffff800825c554>] vfs_write+0xac/0x1b0
[ 470.254263] [<ffffff800825db8c>] SyS_write+0x54/0xb0
[ 470.254291] [<ffffff8008083900>] el0_svc_naked+0x34/0x38
[ 470.254991] Internal error: Accessing user space memory outside uaccess.h routines: 96000005 [#1] PREEMPT SMP
[ 470.264955] Modules linked in: overlay zram spidev nvgpu bluedroid_pm ip_tables x_tables
[ 470.273290] CPU: 0 PID: 6725 Comm: ls Tainted: G W 4.9.140-tegra #1
[ 470.280708] Hardware name: NVIDIA Jetson Nano Developer Kit (DT)
[ 470.286740] task: ffffffc0c991f000 task.stack: ffffffc0f5a7c000
[ 470.292706] PC is at kernfs_find_ns+0x28/0x110
[ 470.297184] LR is at kernfs_find_and_get_ns+0x44/0x68
[ 470.302263] pc : [<ffffff80082eeda0>] lr : [<ffffff80082eeecc>] pstate: 40400145
[ 470.309678] sp : ffffffc0f5a7fa60
[ 470.313017] x29: ffffffc0f5a7fa60 x28: ffffffc0d21480c8
[ 470.318397] x27: ffffffc0f3af4550 x26: ffffffc0f3af4600
[ 470.323777] x25: ffffffc0f5ab4c88 x24: ffffff80094a2758
[ 470.329157] x23: ffffff8009026968 x22: 0000000000000000
[ 470.334532] x21: ffffff8009026968 x20: 0000000000000000
[ 470.339907] x19: ffffff8009e92c98 x18: 0000000000000010
[ 470.345278] x17: 0000000000000000 x16: 0000000000000000
[ 470.350650] x15: ffffffffffffffff x14: ffffff808a138a02
[ 470.356022] x13: 0000000000000000 x12: 0000000000000006
[ 470.361396] x11: 0000000000000002 x10: 0000000000000322
[ 470.366770] x9 : 0000000000000001 x8 : ffffffc0fefa1e6b
[ 470.372142] x7 : 0000000000000000 x6 : 000000000b3ae2d3
[ 470.377514] x5 : 0000000000000000 x4 : ffffffc0fefb5be8
[ 470.382888] x3 : ffffffc0fefb5be8 x2 : 0000000000000000
[ 470.388260] x1 : ffffff8009026968 x0 : ffffff80082eeecc
[ 470.395157] Process ls (pid: 6725, stack limit = 0xffffffc0f5a7c000)
[ 470.401531] Call trace:
[ 470.404023] [<ffffff80082eeda0>] kernfs_find_ns+0x28/0x110
[ 470.409545] [<ffffff80082eeecc>] kernfs_find_and_get_ns+0x44/0x68
[ 470.415678] [<ffffff80082f2f34>] sysfs_unmerge_group+0x2c/0x70
[ 470.421551] [<ffffff800878ca7c>] dpm_sysfs_remove+0x34/0x70
[ 470.427163] [<ffffff800877c8f8>] device_del+0x48/0x248
[ 470.432337] [<ffffff8008784d0c>] platform_device_del.part.6+0x2c/0x98
[ 470.438808] [<ffffff8008784dcc>] platform_device_unregister+0x24/0x38
[ 470.445283] [<ffffff8008ab32dc>] afunc_unbind+0x2c/0x50
[ 470.450545] [<ffffff8008a8f094>] purge_configs_funcs+0xac/0x150
[ 470.456497] [<ffffff8008a8f4a0>] configfs_composite_bind+0x300/0x478
[ 470.462885] [<ffffff8008a928d8>] udc_bind_to_driver+0x48/0x120
[ 470.468747] [<ffffff8008a930b8>] usb_gadget_probe_driver+0xa8/0x148
[ 470.475048] [<ffffff8008a90334>] gadget_dev_desc_UDC_store+0xcc/0x110
[ 470.481525] [<ffffff80082f43e8>] configfs_write_file+0xc0/0x198
[ 470.487479] [<ffffff800825b560>] __vfs_write+0x48/0x118
[ 470.492735] [<ffffff800825c554>] vfs_write+0xac/0x1b0
[ 470.497820] [<ffffff800825db8c>] SyS_write+0x54/0xb0
[ 470.502816] [<ffffff8008083900>] el0_svc_naked+0x34/0x38
[ 470.508168] ---[ end trace 41e809c1c69c038b ]---
I have checked in /lib/modules/4.9.140-tegra/modules.builtin which contains the lines
kernel/drivers/usb/gadget/libcomposite.ko
kernel/drivers/usb/gadget/function/usb_f_acm.ko
kernel/drivers/usb/gadget/function/u_serial.ko
kernel/drivers/usb/gadget/function/u_ether.ko
kernel/drivers/usb/gadget/function/usb_f_ncm.ko
kernel/drivers/usb/gadget/function/usb_f_ecm.ko
kernel/drivers/usb/gadget/function/usb_f_rndis.ko
kernel/drivers/usb/gadget/function/usb_f_mass_storage.ko
kernel/drivers/usb/gadget/function/usb_f_fs.ko
kernel/drivers/usb/gadget/function/usb_f_uac1.ko
kernel/drivers/usb/gadget/function/usb_f_uac2.ko
kernel/drivers/usb/gadget/function/usb_f_uvc.ko
kernel/drivers/usb/gadget/function/usb_f_mtp.ko
kernel/drivers/usb/gadget/function/usb_f_ptp.ko
kernel/drivers/usb/gadget/function/usb_f_audio_source.ko
kernel/drivers/usb/gadget/function/usb_f_accessory.ko
kernel/drivers/usb/gadget/udc/udc-core.ko
kernel/drivers/usb/gadget/udc/tegra_xudc.ko
which seems to indicate that the usb audio gadget drivers are built into the kernel.
However, I have noticed that the u_audio module seems to be missing both from the built-in modules and the external modules. So I wonder if that might be the problem. I have previously managed to create a USB audio gadget in a pocketbeagle board and the module u_audio was required there.
I’d be very grateful for any help on this topic. Thank you in advance!
