I have an HP Zbook G5 with graphical card GP107GLM
Since last Friday I can’t make my monitor working using the USB-C port. It was still working on Thursday (when I run the software updater).
I also completely reinstalled the laptop with a fresh new Ubuntu and the problem is still there…
Some information about my laptop:
lshw -class display
*-display
description: VGA compatible controller
product: GP107GLM [Quadro P1000 Mobile]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller bus_master cap_list rom
configuration: driver=nvidia latency=0
resources: irq:152 memory:e8000000-e8ffffff memory:a0000000-afffffff memory:b0000000-b1ffffff ioport:4000(size=128) memory:e9080000-e90fffff
*-graphics
product: EFI VGA
physical id: 2
logical name: /dev/fb0
capabilities: fb
configuration: depth=32 resolution=1920,1080
lspci|grep VGA
01:00.0 VGA compatible controller: NVIDIA Corporation GP107GLM [Quadro P1000 Mobile] (rev a1)
nvidia-smi
Mon Dec 4 14:46:20 2023
| NVIDIA-SMI 535.129.03 Driver Version: 535.129.03 CUDA Version: 12.2 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 Quadro P1000 Off | 00000000:01:00.0 On | N/A |
| N/A 48C P0 N/A / ERR! | 896MiB / 4096MiB | 1% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1801 G /usr/lib/xorg/Xorg 318MiB |
| 0 N/A N/A 2011 G /usr/bin/gnome-shell 42MiB |
| 0 N/A N/A 3458 C+G …9319132,14200362056835276957,262144 312MiB |
| 0 N/A N/A 8318 G …ures=SpareRendererForSitePerProcess 85MiB |
| 0 N/A N/A 12729 G …sion,SpareRendererForSitePerProcess 88MiB |
uname -r
6.2.0-37-generic
sudo cat /sys/module/nvidia_drm/parameters/modeset
Y
And the result of nvidia-bug-report.sh:
nvidia-bug-report.log.gz (483.5 KB)
Thank you by advance,
Jean-Guy
