I have an issue related to writing images to disk at 3x60fps. Writing works well at that speed but the gst-launch crash after 195’261 images. But the fps is good up till then…
Any idea why? I thought first it was memory buffer growing so I removed the queue. But it still crash. All three stop at the same time:
0:18:08.450914600 78400 0xaaaae9a82a40 ERROR fdmemory gstfdmemory.c:126:gst_fd_mem_map: 0xffff880181e0: fd 42: mmap failed: Cannot allocate memory
0:18:08.450971465 78400 0xaaaae9a82a40 ERROR fdmemory gstfdmemory.c:126:gst_fd_mem_map: 0xffff880181e0: fd 42: mmap failed: Cannot allocate memory
0:18:08.450983817 78400 0xaaaae9a82a40 ERROR nvvidconv gstnvvconv.c:3353:gst_nvvconv_transform: input buffer mapinfo failed
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error.
Additional debug info:
gstbasesrc.c(3072): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
streaming stopped, reason error (-5)
EOS on shutdown enabled -- waiting for EOS after Error
Waiting for EOS...
Got EOS from element "pipeline0".
EOS received - stopping pipeline...
Execution ended after 0:18:08.234331135
Setting pipeline to NULL ...
Freeing pipeline ...
Is this the fix?
And how do I upgrade without having to re-flash the whole drive? It is a “sh¤#%&¤#” to install deepstream with all the dependencies…
For Information
I purchased one more AGX Orin 64GB with jetpack 5.1.2 installed. I then ran the installation of Jetpack tools for deepstream support.
When now running on the new Jetson to a 4TB M2SSD I get full FPS on all three cameras.
So its would seem that the Jetpack upgrade from 5.1.1 to 5.1.2 would do the trick.
It is a bit problematic though since the first one has deepstream and yolov8 working and it was really hard to make all the dependencies right. I hope I can get that working and then I can flash the first one. Unless you have an idea on how to fx it on the first.
The memory of the process in top command looks stable and does not increase. Could you give it a try? If you also don’t hit the issue, videotestsrc may be fine and the issue is specific to using v4l2src.
I have tried this in two installed systems with Jetpack 5.1.2 and it works. Seems to do the trick. 5.1.1 seems to have a bug of some sort.
Thanks for the support!
I would encourage you to write complete installation instructions for flashing and installing JP and deepstream. The official instructions lack a lot of steps and goes back and forth. Its impossible to follow. I know it should be covering a lot but one guideline that actually works step by step from start to end would be good.
I think you have installation issues flashing JP6 with 22.04. I got a system that didnt even start…
