Hey all!
I’m trying to get a USB modem connected to give my Jetson Orin Nano the ability to connect to cellular data.
I’ve successfully managed to get comms running w/ the USB modem. but I can’t connect due to what seems to be a kernel related error.
jetson@ubuntu:~$ sudo wvdial
--> WvDial: Internet dialer version 1.61
--> Initializing modem.
--> Sending: ATZ
ATZ
OK
--> Sending: ATQ0 V1 E1 S0=0 &C1 &D2 +FCLASS=0
OK
--> Modem initialized.
--> Sending: ATDT*99#
--> Waiting for carrier.
ATDT*99#
CONNECT 115200
--> Carrier detected. Starting PPP immediately.
--> Starting pppd at Sun Mar 9 22:40:32 2025
--> Pid of pppd: 6301
--> Disconnecting at Sun Mar 9 22:40:33 2025
--> The PPP daemon has died: No ppp module error (exit code = 4)
--> man pppd explains pppd error codes in more detail.
--> I guess that's it for now, exiting
--> The PPP daemon has died. (exit code = 4)
Any thoughts on how to fix this? (Ideally without tearing apart my Kernel?)
-W
Please check if additional kernel configs have to be enabled for the component. And refer to developer guide to rebuild kernel image:
Kernel Customization — NVIDIA Jetson Linux Developer Guide
Wait, I see what you mean now! But two questions:
The very first step of the docs involves running the source_sync.sh script, which seems easier than downloading from source manually. Where do I find/get this script?
What configuration/kernel setting would I need to include to get the functionality I need? Specifically, I believe I need the library usb_wwan.h
Thanks so much for the reply!
If you have host PC which ever flashed the Orin Nano developer kit thorough SDKManager. Or have run the manual commands:
Quick Start — NVIDIA Jetson Linux Developer Guide
The script will be in
Linux_for_Tegra/source/source_sync.sh
We are uncertain which configs have to be enabled. This would need other users to share experience.
system
Closed
April 9, 2025, 3:24am
8
