I have reflashed and reinstalled everything I can, but it still does not work.
I see that you’ve reflashed and reinstalled everything on your Jetson Orin Nano, but it still doesn’t work. I’ll provide a comprehensive answer to help you troubleshoot the issue.
Common Issues:
- Boot Issues: Check if the device is booting correctly. If not, try flashing the device again using the correct flash script (e.g.,
flash_l4t_t234_nvme.xmlfor NVMe orflash_l4t_t234_qspi.xmlfor QSPI). Ensure you’re using the correct--external-deviceparameter (e.g.,nvme0n1p1,sda1, ormmcblk0p1). - Kernel Device Tree: Verify that the kernel device tree is correctly configured for your carrier board. If you’re using a custom carrier board, you may need to modify the device tree to match your board’s configuration.
- MB1 and MB2 Configurations: Check if the MB1 and MB2 configurations are correctly set for your device. You can use the
mb1-bctandmb2-bcttools to verify and modify these configurations if needed. - ODM Data: Ensure that the ODM data is correctly set for your device. You can use the
odm-datatool to verify and modify the ODM data if needed. - Flashing Configuration: Verify that the flashing configuration is correct for your device. Check the
flash_l4t_t234_nvme.xmlorflash_l4t_t234_qspi.xmlfile to ensure that the correct flashing configuration is being used.
Comparison with Similar Issues:
- Jetson Orin Nano Developer Kit - Black Screen and Fan Stops After Boot (JetPack 5.1.3): This issue is similar to yours, where the device boots but the fan stops, and the screen remains black. Try flashing the device again using the correct flash script and ensure that the kernel device tree is correctly configured.
- Boot failed: This issue is related to boot failures. Try flashing the device again using the correct flash script and ensure that the MB1 and MB2 configurations are correctly set.
- Cannot cross compile CUDA samples and cutlass3.1.0 with JetPack Cross Compilation container: This issue is related to cross-compilation. Ensure that you’re using the correct cross-compilation container and that the CUDA samples and cutlass3.1.0 are correctly configured.
Next Steps:
- Try flashing the device again using the correct flash script and ensure that the kernel device tree is correctly configured.
- Verify that the MB1 and MB2 configurations are correctly set for your device.
- Check the ODM data and modify it if needed.
- Ensure that the flashing configuration is correct for your device.
- If none of the above steps resolve the issue, try reinstalling the JetPack and CUDA samples.
If you’re still experiencing issues, please provide more details about your setup, including the exact error messages you’re seeing, and I’ll do my best to help you troubleshoot the problem.
usb 1-2: new high-speed USB device number 83 using tegra-xusb
usb 1-2: Device not responding to setup address.
usb 1-2: device not accepting address 83, error -71
It happened since I copy the SD card for backup. I did try flashing again several versions and it still shows the same error. USB-A ports does not work as well as WiFi and Bluetooth modules, but USB-C works.
Some questions to confirm:
- Is your Orin nano a devkit or a custom board?
- How do you flash your device (eg. sdk manager)?
Yes, it is Jetson Orin nano devkit and I used SDK manager from another computer using Ubuntu 22.04
What is your bsp/JP version?
Do your have another developer kit to do the cross check?
Thanks,
I have tried JP 6.1 and 6.2 and they did not work, have the same error.
I do not have another kit to cross check
Please take a photo of your carrier board. It is abnormal that a NV devkit would have -71 error.
Could you share full dmesg with jetpack6.2?
Also, if possible, flash your board with jp5.1.5 too and see if you still see the issue.
