Thanks for your response.
Your suggestions have been very useful.
When I execute lsusb -t with and without the display I get the same response.
nvidia@george:~/projects/FujitsuWarp$ lsusb -t
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=tegra-xusb/3p, 5000M
|__ Port 1: Dev 2, If 0, Class=Video, Driver=uvcvideo, 5000M
|__ Port 1: Dev 2, If 1, Class=Video, Driver=uvcvideo, 5000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=tegra-xusb/4p, 480M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 1: Dev 3, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 4: Dev 4, If 1, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 4: Dev 4, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
The failure manifests itself when reading live data from the camera, using USB3.0. When I either run my own program or the vender’s software to stream the data, disconnecting the display causes streaming to halt. Similarly if I attempt to run either program with the display disconnected, no data is read, then when I connect the display, streaming runs successfully.
Streaming works successfully when using USB2.0, regardless of the display being connected.
