Deepstream7.0 in docker on ubuntu22 with dGPU
Does service maker in deepstream 7.0 support dynamic addition and deletion of elements like the example in this URL changing-elements-in-a-pipeline
? If so, can you give an example?
Which elements do you want to dynamically add/remove?
There is only sample of dynamically adding/removing sources with /opt/nvidia/deepstream/deepstream/service-maker/sources/apps/deepstream_test5_app
I’ve written a couple of inference plugins custom-infer, in a pipeline like this source ->nvv4l2decoder->nvstreammux->nvvideoconvert->custom-infer-1 ->nvdsosd->sink, I want to dynamically replace custom-infer-1 with custom-infer-2 when pipeline is running. Does Maker have a solution, and how can I implement it?
This is not supported now. You may need to add both custom infers in the pipeline and filter the meta data to output.
