Deepstream service-marker nvmultrisrcbin dynamic add source
How can I dynamically add a source to nvmultisrcbin when using service marker
When I tried using gst-nvmultisrcbincreator. h, I found that the service marker Pipeline.add() does not support * GstElement
Is there any other way
//pipeline.hpp
class Pipeline {
 Pipeline& add(const std::string& element_type, const std::string& element_name, const Args&... args) {
    Element element = Element(element_type, element_name);
    if constexpr (sizeof...(args) > 0) {
      element.set(args...);
    return this->add(element);
  /** @brief Add a given element to the pipeline */
  Pipeline& add(Element element);
//element.hpp
class Element : public Object {
 public:
   * @brief Constructor
   * @param[in] type_name  ehe type name for a specific element defined with Deepstream SDK
   * @param[in] name       name given to the Element instance
  Element(const std::string& type_name, std::string name = std::string());
  /** @brief Downcast copy constructor from Object class */
  Element(const Object&);
  /** @brief Downcast move constructor from Object class */
  Element(Object&&);
  /** @brief Destructor */
  virtual ~Element();
   * @brief Link two Element instances using hint
   * @param[in] dst   target element to which this element links
   * @param[in] hint  hint for the link, providing the source pad name and target pad name
   * @return          target element
  Element & link(Element &dst, std::pair<std::string, std::string> hint);
   * @brief Link two Element instances directly
  Element& link(Element &other);
  /** @brief Find the buffer probe attached to the elmenent by name */
  BufferProbe* getProbe(const std::string& name) {
    return find_<BufferProbe>(name);
   * @brief Create and add a buffer probe to the element
   * A buffer probe will be automatically created by the factory in the plugin.
   * @param[in] plugin_name   name of the plugin where the factory for the buffer probe is defined
   * @param[in] probe_name    name of the buffer probe to be added
   * @param[in] probe_tip     extra information for adding the probe, e.g name of the pad
  Element& addProbe(const std::string& plugin_name,
                    const std::string& probe_name,
                    const std::string probe_tip = "");
  /** @brief Template function for creating and adding buffer probe with properties */
  template<typename... Args>
                    const std::string probe_tip = "",
    addProbe(plugin_name, probe_name, probe_tip);
    auto probe = getProbe(probe_name);
    if (probe && (sizeof...(args) > 0)) {
      probe->set(args...);
    return *this;
   * @brief Add a BufferProbe instance to the element
   * Once the probe is added, the element will take the ownership
   * @param[in] probe         pointer to the buffer probe
  Element& addProbe(BufferProbe* probe, const std::string probe_tip  = "");
  /** @brief Find the signal handler attached to the element by name */
  SignalHandler* getSignalHandler(const std::string& name) {
    return find_<SignalHandler>(name);
   * @brief Connect a signal handler to the element
   * A signal handler is responsible for handling the asynchronous signals emitted from
   * the element. Signals behave like events and are defined by their names. Detailed
   * information of signal types available within an element can be found from the Plugin
   * Manual of Deepstream.
   * Once connected, the element takes the ownership of the signal handler
   * @param[in] signal_name   name of the signal to which the handler is connected
   * @param[in] probe_tip     pointer to the signal handler
  Element& connectSignal(const std::string&signal_name, SignalHandler* handler);
   * @brief Create and connect a handler to element's signal
   * A signal handler will be created automatically by the factory defined in the plugin
   * @param[in] plugin_name   name of the plugin where the factory of the signal handler is defined
   * @param[in] handler_name  name of the signal handler to be added
   * @param[in] signal_names  names of the signals for the handler to connect, separated by "/"
  Element& connectSignal(const std::string& plugin_name,
                         const std::string& handler_name,
                         const std::string& signal_names);
  /** @brief Template function for creating and connecting signal with properties */
                         const std::string& signal_names,
    connectSignal(plugin_name, handler_name, signal_names);
    auto handler = getSignalHandler(handler_name);
    if (handler && (sizeof...(args) > 0)) {
      handler->set(args...);
    return *this;
protected:
  Element(GstObject* object);
  Element& add_(CustomObject* object);
   * buffer probes, signal handlers, signal emitters are held by its target element as shared pointers.
  std::unordered_map<std::string, std::shared_ptr<CustomObject>> objects_;
  template<class T>
  T* find_(const std::string& name) {
    auto itr = find_if(
      objects_.begin(),
      objects_.end(),
      [&](const auto& pair) {
        return pair.first == name && dynamic_cast<T*>(pair.second.get());
    if (itr != objects_.end()) return dynamic_cast<T*>(itr->second.get());
    return nullptr;
//gst-nvmultiurisrcbincreator.h
  GstElement
      *gst_nvmultiurisrcbincreator_get_bin (NvDst_Handle_NvMultiUriSrcCreator
      apiHandle);
  NvDst_Handle_NvMultiUriSrcCreator gst_nvmultiurisrcbincreator_init (gchar *
      binName, NvDsMultiUriMode mode, GstDsNvStreammuxConfig * muxConfig);
  gboolean
      gst_nvmultiurisrcbincreator_add_source (NvDst_Handle_NvMultiUriSrcCreator
      apiHandle, GstDsNvUriSrcConfig * sourceConfig);
You can use “Pipeline& add(Element element)” and “Pipeline& link( std::pair<std::string, std::string> route, std::pair<std::string, std::string> tips)” to use the GstElement got by gst_nvmultiurisrcbincreator_get_bin().
Thank you for your reply
I tried this
But because the types don’t match, we can’t do this
