GPU
• DeepStream Version
6.1
• TensorRT Version
question, new requirements
Would it be possible to add an option to attach external Re-Id feature vectors to an object’s metadata, and use those vectors when calculating similarity in DeepSORT INSTEAD of doing inference within the tracker module itself (such as mars-small128.pb etc.) ?
Ideally it should be possible to disable any model inference within the DeepSORT tracker entirely, and instead attach the Re-Id vectors to the input batch’s objects.
This would allow the user to run any Re-Id feature extractor as a SGIE (for instance, onnx models etc…) as well as providing a way of accessing the Re-Id vectors from outside the tracker (currently there is no way to access the vectors extracted in the DeepSORT tracker).
Thoughts…?
/M
