Wrong and Invalid ID recieved for object while extracting feature embedding using the REID module
• Hardware Platform (Jetson / GPU) NVIDIA RTX 3060
• DeepStream Version 7.0
• TensorRT Version v8601
• NVIDIA GPU Driver Version (valid for GPU only) 545.29.06
I am trying to run the REID module using the accuracy / perf configurations.
While running I am also extracting the feature embedding with respect to every object in the frame.
Currently I am using python + deepstream to get the feature embeddings. As the functionality for feature embedding are not officially provided by NVIDIA, since deepstream_python_apps repository is opensource,
I am using the files and functionality shared in one previous discussion here : How to access Re-ID tensor for cross camera re-id - #32 by st123439
The below code was working fine for us for the deepstream version 6.4. When we updated to deepstream 7.0 we started encountering issues with “ID of REID vector”
With respect to the below code, reidInd = reidInd_ptr.contents.value used to give us the index of the object in user meta using which we were able to extract the feature embedding of the object we require from list of feature embedding using the index we used to get using the “reidInd_ptr.contents.value”.
Ever since we switched to deepstream 7.0 instead of the ID it plain returns us the value 256 for all the iterations regardless of any input we give.
                user_meta = pyds.NvDsUserMeta.cast(l_user_meta.data)
                if user_meta and (user_meta.base_meta.meta_type == pyds.NVDS_TRACKER_OBJ_REID_META) and user_meta.user_meta_data:
                    reidInd_ptr = ctypes.cast(pyds.get_ptr(user_meta.user_meta_data), ctypes.POINTER(ctypes.c_int32))
                    print("reidInd.real:",reidInd)
                    if reidInd >= 0 and reidInd < pReidTensor.numFilled:
                        feature = reidFeatures[reidInd, :]
                        try:
                            obj_data["reid_feature"] = [float(x) for x in list(feature)]
                        except:
                            print("problem")
We request you to please help us out in getting the ID of the object which was working well in deepstream 6.4.
The definition of NVDS_TRACKER_OBJ_REID_META changed between DS 6.x and DS 7.0. Please refer: Deepstream Tracker FAQ - #6 by kesong
