I am a new person to Jetson Nano. We need to run Depth Estimation model from HF. In order to make the computations faster, we need access to the GPU.
We are using this docker file:
Use the official Python image
FROM python:3.11-slim
Set the PYTHONUNBUFFERED environment variable
ENV PYTHONUNBUFFERED=1
Install necessary packages for OpenGL and libgthread-2.0
RUN apt-get update && apt-get install -y
libgl1-mesa-glx
libglib2.0-0
&& rm -rf /var/lib/apt/lists/*
Install
RUN pip install opencv-python transformers Pillow numpy
Install PyTorch with CUDA 10.2 support
DOES NOT WORK: RUN pip install torch==1.8.0+cu102 torchvision==0.9.0+cu102 torchaudio===0.8.0 -f https://download.pytorch.org/whl/torch_stable.html
RUN pip install torch torchvision torchaudio -f https://download.pytorch.org/whl/torch_stable.html
Install necessary packages for video processing
RUN apt-get update && apt-get install ffmpeg libsm6 libxext6 -y
Set the working directory
WORKDIR /app
Copy the Python program to the container
COPY depth4.py /app/depth4.py
Copy the video into the container
COPY c_b407_video.mp4 .
Run the Python script when the container launches
CMD [“python”, “depth4.py”]
And this is the depth4.py program
import os
import torch
from transformers import DPTImageProcessor, DPTForDepthEstimation
import cv2
import numpy as np
from PIL import Image
model_name = “Intel/dpt-hybrid-midas”
model_dir = “/models” # Change this to the directory where the volume is mounted
Create the models directory if it doesn’t exist
os.makedirs(model_dir, exist_ok=True)
Check if the model exists in the model directory
if not os.path.exists(os.path.join(model_dir, model_name)):
# If not, download the model
model = DPTForDepthEstimation.from_pretrained(model_name)
processor = DPTImageProcessor.from_pretrained(model_name)
# Save the model and processor
model.save_pretrained(os.path.join(model_dir, model_name))
processor.save_pretrained(os.path.join(model_dir, model_name))
else:
# If it does, load the model and processor from the directory
model = DPTForDepthEstimation.from_pretrained(os.path.join(model_dir, model_name))
processor = DPTImageProcessor.from_pretrained(os.path.join(model_dir, model_name))
Get the current working directory
current_directory = os.getcwd()
Construct the path to the video file
video_path = os.path.join(current_directory, “c_b407_video.mp4”)
Now you can use video_path to access the video file
print(“Video path:”, video_path)
device = torch.device(“cuda” if torch.cuda.is_available() else “cpu”)
model.to(device)
print(torch.cuda.is_available())
Open the video file
cap = cv2.VideoCapture(video_path)
Get video properties
width = int(cap.get(cv2.CAP_PROP_FRAME_WIDTH))
height = int(cap.get(cv2.CAP_PROP_FRAME_HEIGHT))
fps = cap.get(cv2.CAP_PROP_FPS)
frame_count = int(cap.get(cv2.CAP_PROP_FRAME_COUNT))
Define the codec and create VideoWriter object
fourcc = cv2.VideoWriter_fourcc(*‘mp4v’)
out = cv2.VideoWriter(“output.mp4”, fourcc, fps, (width, height))
current_frame = 0
while cap.isOpened():
# Capture frame-by-frame
ret, frame = cap.read()
if not ret:
break
# Convert frame to PIL Image
image = Image.fromarray(cv2.cvtColor(frame, cv2.COLOR_BGR2RGB))
# Prepare image for the model
inputs = processor(images=image, return_tensors="pt")
with torch.no_grad():
# Get depth prediction
outputs = model(**inputs)
predicted_depth = outputs.predicted_depth
# Interpolate to original size
prediction = torch.nn.functional.interpolate(
predicted_depth.unsqueeze(1),
size=image.size[::-1],
mode="bicubic",
align_corners=False,
# Move prediction tensor to CPU for visualization
prediction = prediction.cpu()
# Visualize the prediction
output = prediction.squeeze().numpy()
formatted = (output * 255 / np.max(output)).astype("uint8")
depth = cv2.cvtColor(np.array(Image.fromarray(formatted)), cv2.COLOR_GRAY2BGR)
# Write the depth-enhanced frame to the output video
out.write(depth)
current_frame += 1
if current_frame % 2 == 0: # Print every 10 frames to reduce overhead
print(f'Processed frame {current_frame} of {frame_count}')
break
Release the video file and writer object, and close windows
cap.release()
out.release()
cv2.destroyAllWindows()
The code is unable to access Jetson Nano’s GPU. Please help me. Thank you for considering.
