I used Jetson_Orin_NX_and_Orin_Nano_series_Pinmux_Config_Template.xlsm to generate the three files pinmux.dtsi & gpio.dtsi & padvoltage.dtsi, and i
Copy the “pinmux.dtsi” and “padvoltage.dtsi” files to the “<l4t_top>/bootloader/generic/BCT/” directory.
Copy the “gpio.dtsi” file to the “<l4t_top>/bootloader/” directory.
I want to update jetson-orin-nano-devkit via l4t_initrd_flash.sh, but I don’t want to format the existing Ubuntu system of jetson-orin-nano-devkit. How can I update it without affecting the system?
I using the devkit for Orin Nano.(L4T 36.3, Jetpack-6)
So I can’t simply update the files I need to update? Or is there another way to achieve my idea? Can you provide it?
(For example, use the dtsi file generated by Jetson_Orin_NX_and_Orin_Nano_series_Pinmux_Config_Template.xlsm)
I also want to make sure that I have placed the generated files in the corresponding folders and also changed the
PINMUX_CONFIG=“Replace with the new file name.dtsi”;
PMC_CONFIG=“Replace with the new file name.dtsi”;
After the changes are made, can I only update by reflashing?
Please note that pinmux/gpio dtsi are loaded in MB1(early boot) so that you have to reflash the board to apply the change.
Alternative, you can also generate an overlay dtbo(e.g. jetson-io-hdr40-user-custom.dtbo), which will be loaded during boot up and handled by pinctrl-tegra driver to re-configure the pinmux register if you don’t want to re-flash the board.
