I want use mipi csi to connect two AGX orin Dev Kits(from one AGX orin Dev Kits’ MIPI csi to the other’s). Could you please confirm whether AGX orin Dev Kit support this mode?
Please find the support Camera products from Jetson Partner Supported Cameras | NVIDIA Developer
thanks for you reply.
my problem is how to tranfer big data (4 Gbps) between two AGX orins with low latency? is MIPI CSI feasible?
Jetson CSI only receive data as input. Don’t support output mode.
I don’t think this case could be supported.
Maybe check the ethernet.
OK, thank a lot
