Could you check the 0x155c0124 by devmem2 to see what the different before and after you add the dpaux@155c0000 in DT.
155c0124: DPAUX_HYBRID_PADCTL_0 = 0x00002462 //
I2C_SDA_INPUT_RCV = 0x00000000 // [15:15] DISABLE [DISABLE=0,ENABLE=1]
I2C_SCL_INPUT_RCV = 0x00000000 // [14:14] DISABLE [DISABLE=0,ENABLE=1]
AUX_CMH = 0x00000002 // [13:12] V1_10 [V0_10=0,V0_55=1,V1_10=2,V1_60=3]
AUX_DRVZ = 0x00000004 // [10:08] OHM_56_49 [OHM_38_10=7,OHM_43_91=6,OHM_47_15=5,OHM_51_53=3,OHM_56_49=4,OHM_62_94=2,OHM_70_12=1,OHM_93_37=0]
AUX_DRVI = 0x00000018 // [07:02] I12_00 [I00_00=0,I07_17=1,I07_81=4,I08_02=5,I08_23=6,I08_44=7,I08_65=8,I08_86=9,I09_07=10,I09_28=11,I09_49=12,I09_70=13,I09_91=14,I10_12=15,I10_33=16,I10_54=17,I10_75=18,I10_96=19,I11_17=20,I11_37=21,I11_58=22,I11_79=23,I12_00=24,I12_20=25,I12_41=26,I12_62=27,I12_82=28,I13_03=29,I13_23=30,I13_44=31,I13_64=32,I13_84=33,I14_04=34,I14_25=35,I14_45=36,I14_65=37,I14_85=38,I15_05=39,I15_24=40,I15_44=41,I15_63=42,I15_83=43,I16_02=44,I16_21=45,I16_40=46,I16_59=47,I16_78=48,I16_96=49,I17_14=50,I17_32=51,I17_49=52,I17_66=53,I17_82=54,I17_98=55,I18_13=56,I18_28=57,I18_43=58,I18_56=59,I18_69=60,I18_82=61,I18_94=62,I19_05=63,V07_38=2,V07_59=3]
AUX_INPUT_RCV = 0x00000001 // [01:01] ENABLE [DISABLE=0,ENABLE=1]
MODE = 0x00000000 // [00:00] AUX [AUX=0,I2C=1]
