I am working on this project with a Orin Nano Devkit:
Unfortunately the repo only describes the installation on a raspberry pi.
I already managed to compile a .ko file on the orin and insert it using
sudo cp ds90ub954.ko /lib/modules/
uname -r/kernel/drivers/media/i2c/.
Also the start at boot of the .ko file should work after inserting “ds90ub954” into /etc/modules.
Then I copied the .dtbo file into /boot (and also /boot/dtb). But the overlay gets not listed here
sudo /opt/nvidia/jetson-io/config-by-hardware.py -l
The problem might be this line in the .dtbo file which is raspberry pi specific.
compatible = “brcm,bcm2835”
But just removing it, did not solve the problem. I attached the complete .dts file (as .txt) that I compiled to the .dtbo file.
Greetings, Matthias
ds90ub954.dts.txt (1.2 KB)
