I have been installed jetpack component in emmc(16GB).
Can I install jetpack component in external drive with booting from emmc.
If then, Can you tell me how to install jetpack component in external drive?
Thank you.
Thank you.
No, you can only choose one place as rootfs.
Becuase of limited emmc space, all necessary files cannot put into emmc.
Due to the limited capacity of emmc, it is difficult to put all the necessary files in emmc.
What method should I use in this case?
In case 2, what is emmc used for?
Why is emmc chosen for the jetson production module?
Is it because of the speed?
Thank you.
Bootloader will still be on the emmc and rootfs (your OS and your jetpack component) will be on the external storage.
Hope this will make this much easier to understand.
If I put only a bootloader in emmc, wouldn’t it waste emmc’s storage space?
Do you usually put only bootloader in emmc like this?
How does Nvidia recommend using it?
Thank you.
Bootloader can only put over the emmc because our bootrom only able to support those internal boot device like qspi and emmc on jetson.
Yes, put bootloader on emmc and rootfs on the external drive.
Can I use a sdcard as an external drive?
What documents can I refer to?
Thank you.
Better checking my post here first.
I have been used a carrier board below you see.
I have read a content below.
Can I use a sdcard as a NVMe drive?
To set up an NVMe drive manually for booting
1.For this method, confirm that the device can boot successfully from eMMC. If it cannot, correct the problem by flashing to eMMC first.
2.Connect the NVMe drive to the host computer.
=> Host computer means ubuntu18.04 hostpc for flashing a jetson?
3.Check the NVMe drive’s device name (e.g. /dev/nvme0n1):
=> I can’t find /dev/nvme0n1 in ubuntu hostpc
How can I find /dev/nvme0n1
Is it possible to use sdcard as a NVMe drive?
Thank you.
nvme0n1 is mostly for NVMe drive case… if you want to use sdcard, you shall use something like mmcblk1p1 …
Check the device node name on your jetson first…
It is the ubuntu host PC.
Already told … anything with “nvme” is for the nvme drive only… if you want to use sdcard or anything else, please get the correct device name for yourself…
Please stop asking such kind of question again and again. Try to think what these steps are doing by yourself first.
There is no direct document for external sdcard, just use the same concept to achieve that by yourself.
7. (update: 2022/2/14) SDKM is able to directly flash to NVMe on jetson after jetpack4.6
This is because the initrd flash tool in this link is implemented and it can directly flash the NVMe drive on jetson.
=> This is available on jetson nano?
Thank you.
No, not available on jetson nano.
Also, I am not sure if you know that sdcard and NVMe are two different kinds of external drive…
I didn’t know.
now i know
Thank you.
The contents below are emmc first
Are you saying you have to flash it with the command sudo ./flash jetson-nano-devkit-emmc mmcblk0p1?
For this method only, confirm that the device can boot successfully from eMMC. If it cannot, correct the problem by flashing to eMMC first
Thank you.
