• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 5.0.1
• TensorRT Version
• NVIDIA GPU Driver Version (valid for GPU only) 440+
• Issue Type( questions, new requirements, bugs) questions
I am trying to count the number of objects of a class in a frame and send it to the broker. I have to use interval of 15 for the system to work so I am only running inference every 16 frames. My issue is that when I check downstream of the plugin I dont know if there are 0 objects in the frame cause its the 15 frames of no inference or if tehre really are no objects.
Is there a variable to check when inference runs using interval?
