Using nvfortran with -cuda option
Hello, I’m using the NVIDIA HPC SDK 24.5 with CUDA 12.4.
I have some Fortran code that uses straight CUDA to offload two loops - all source files have “*.f” extension.
Everything compiles and runs successfully (albeit slower than expected) if I use the following compile options.
“-O3 -cpp -r8 -tp=cascadelake -target=gpu -cuda -mp=gpu -gpu=cuda12.4,cc70”
However, if I remove the “-mp=gpu” option, which shouldn’t need to be there as the code isn’t doing any OpenMP, I get the following errors.
“nvfortran-Warning-The -target option has no effect unless a language-specific option is used (e.g.: -acc, -mp, -stdpar, -cuda)”
The compiler doesn’t detect that the “-cuda” option is on the command line.
What’s going on here? Is this a bug in the nvfortran compiler?
I’m using NVIDIA V100 GPUs.
Best wishes,
Michael
Hi Michael,
I think it’s just a typo in the warning message. CUDA Fortran is being applied.
“-target” is only for OpenACC, OpenMP, and STDPAR since these can be compiled to target either the GPU or multicore CPU. However CUDA Fortran, i.e. “-cuda”, can only target GPUs. Hence, the warning is correct, just that “-cuda” shouldn’t be in the message.
I’ll report it.
-Mat
Hi Michael,
FYI, engineering was able to clean up the warning message in our 25.5 release:
% nvfortran -cuda -target=gpu x.f -V25.5
nvfortran-Warning-The -target option has no effect unless it is combined with a programming model option that supports multiple targets, such as -acc, -mp, or -stdpar
Thanks again for the report,
Mat
