TL;DR - Check the gid of vglusers group on the host. Add this group with the gid in the container, and add the user to this group.
So investigating this a bit, I looked at the nvidia devices in the container:
root@56cef279b83f:/# cd /dev
root@56cef279b83f:/dev# ls -l | grep nvidia
crw-rw---- 1 root 1005 195, 0 Nov 23 23:13 nvidia0
crw-rw---- 1 root 1005 195, 255 Nov 23 23:13 nvidiactl
crw-rw---- 1 root 1005 195, 254 Nov 23 23:13 nvidia-modeset
crw-rw-rw- 1 root root 506, 0 Nov 23 23:13 nvidia-uvm
crw-rw-rw- 1 root root 506, 1 Nov 23 23:13 nvidia-uvm-tools
The nvidia devices belonged to a group with gid 1005. This was odd as there was no group in the container with that ID.
I went to look into the devices on the host, and as per my VGL setup, they belong to root, or the vglusers group.
(venv) jsim@goliath:/var/log$ cd /dev/
(venv) jsim@goliath:/dev$ ls -l | grep nvidia
crw-rw---- 1 root vglusers 195, 0 Nov 24 10:13 nvidia0
drwxr-xr-x 2 root root 80 Nov 24 10:31 nvidia-caps
crw-rw---- 1 root vglusers 195, 255 Nov 24 10:13 nvidiactl
crw-rw---- 1 root vglusers 195, 254 Nov 24 10:13 nvidia-modeset
crw-rw-rw- 1 root root 506, 0 Nov 24 10:13 nvidia-uvm
crw-rw-rw- 1 root root 506, 1 Nov 24 10:13 nvidia-uvm-tools
As it turns out, vglusers has a gid of 1005!
jsim@goliath:/dev$ cat /etc/group | grep vglusers
vglusers:x:1005:jsim
So in my Dockerfile, all I had to do is add the group vglusers with gid 1005, and add my user to this group. Problem solved.
RUN groupadd -g 1005 vglusers && \
useradd -ms /bin/bash testuser -u 1000 -g 1005 && \
usermod -a -G video,sudo testuser
