Hi, I’m developing with multiple cameras on Jetson Xavier.
Using nvivafilter I could manage to warp the images from camera on Gstreamer.
so the command line worked fine. (1.)
However when I tried to attach this on my program. it didn’t work.
I’ve attached code below, please refer (2., 4.)
- warped input to screen on command line (works)
gst-launch-1.0 -v pylonsrc camera=1 fps=30 ! bayer2rgb ! nvvidconv ! 'video/x-raw(memory:NVMM), width=1920, height=1200, format=I420, framerate=30/1' ! nvivafilter customer-lib-name=./lib-gst-custom-opencv_cudaprocess1.so cuda-process=true ! 'video/x-raw(memory:NVMM), format=RGBA' ! nvegltransform ! nveglglessink
- warped input to appsink (Problem)
descr_string_vec[j] = "pylonsrc camera=" + std::to_string(j) + " fps=" + fps_s + " "
"! bayer2rgb "
"! nvvidconv top=0 bottom=1200 left=0 right=1920 "
"! video/x-raw(memory:NVMM), width=1920, height=1200, format=I420, framerate=(fraction)" + fps_s + "/1 "
"! nvivafilter customer-lib-name=../cu/lib-gst-custom-opencv_cudaprocess" + std::to_string(j) + ".so cuda-process=true "
"! video/x-raw(memory:NVMM), format=RGBA "
"! video/x-raw, width=1920, height=1200, format=RGBA, framerate=(fraction)" + fps_s + "/1 "
"! appsink name=sink" + std::to_string(j) + " ";
- original input to appsink (works)
"! bayer2rgb "
"! videoconvert "
"! video/x-raw, format=BGR, framerate=(fraction)" + fps_s + "/1 "
"! appsink name=sink sync=true ";
- image gabbing code
GstFlowReturn
new_sample(GstAppSink *appsink, gpointer data) {
static int framecount = 0;
framecount++;
GstSample *sample = gst_app_sink_pull_sample(appsink);
GstCaps *caps = gst_sample_get_caps(sample);
GstBuffer *buffer = gst_sample_get_buffer(sample);
const GstStructure *info = gst_sample_get_info(sample);
// ---- Read frame and convert to opencv format ---------------
GstMapInfo map;
gst_buffer_map (buffer, &map, GST_MAP_READ);
// convert gstreamer data to OpenCV Mat, you could actually
// resolve height / width from caps...
///how to directly gpumat
//Mat frame(input_size, CV_8UC3, (char*)map.data, Mat::AUTO_STEP);
cv::Mat frame(input_size, CV_8UC4, (char*)map.data, Mat::AUTO_STEP);
// TODO: synchronize this....
frameQueue[0].push_back(frame);
gst_buffer_unmap(buffer, &map);
// print dot every 30 frames
if (framecount%30 == 0) {
//g_print ("......");
// show caps on first frame
if (framecount == 1) {
g_print ("%s\n", gst_caps_to_string(caps));
gst_sample_unref (sample);
return GST_FLOW_OK;
Q1) the result image of 2. is blue-ish warped image and red-ish small original images… (2.jpg)
Why it does not contain only warped image?
Q2) I’m trying to search as many as possible. however, the code 2. looks little bit inefficient.
Can I minimize the lines? is there any redundant usage?
I’ve attatched opencv conversion code 4. and images regarding code above for more clear understand.
