Using OP-TEE to decrypt AES on Orin NX
I would like to use the AES decryption example in my application. As per the documentation of OP TEE in this link, there is a sample for optee_example_aes and the GitHub repo at this link also has the code for it.
However, when I try to compile the application and run it, it’s unable to find the corresponding TA file. In my path, I only have the following:
orin-nx8@ubuntu:/lib/optee_armtz$ l
023f8f1a-292a-432b-8fc4-de8471358067.ta  5c206987-16a3-59cc-ab0f-64b9cfc9e758.ta  a720ccbb-51da-417d-b82e-e5445d474a7a.ta  e13010e0-2ae1-11e5-896a-0002a5d5c51b.ta
02a42f43-d8b7-4a57-aa4d-87bd9b5587cb.ta  5ce0c432-0ab0-40e5-a056-782ca0e6aba2.ta  b3091a65-9751-4784-abf7-0298a7cc35ba.ta  e6a33ed4-562b-463a-bb7e-ff5e15a493c8.ta
25497083-a58a-4fc5-8a72-1ad7b69b8562.ta  731e279e-aafb-4575-a771-38caa6f0cca6.ta  b689f2a7-8adf-477a-9f99-32e90c0ad0a2.ta  f04a0fe7-1f5d-4b9b-abf7-619b85b4ce8c.ta
380231ac-fb99-47ad-a689-9e017eb6e78a.ta  82154947-c1bc-4bdf-b89d-04f93c0ea97c.ta  c3f6e2c0-3548-11e1-b86c-0800200c9a66.ta  f157cda0-550c-11e5-a6fa-0002a5d5c51b.ta
528938ce-fc59-11e8-8eb2-f2801f1b9fd1.ta  873bcd08-c2c3-11e6-a937-d0bf9c45c61c.ta  cb3e5ba0-adf1-11e0-998b-0002a5d5c51b.ta  fd02c9da-306c-48c7-a49c-bbd827ae86ee.ta
5b9e0e40-2636-11e1-ad9e-0002a5d5c51b.ta  a4c04d50-f180-11e8-8eb2-f2801f1b9fd1.ta  d17f73a0-36ef-11e1-984a-0002a5d5c51b.ta  ffd2bded-ab7d-4988-95ee-e4962fff7154.ta
Whereas, the UUID for the AES example is 5dbac793-f574-4871-8ad3-04331ec17f24 can you please tell me where do I find this file, or how can I generate this TA so that I can use it with my application? thanks!
hello hatake_kakashi,
it should be.. aes_ta.c, here’s the header file, aes_ta.h.
let me re-cap the UUID as below for your reference.
/* UUID of the AES example trusted application */
#define TA_AES_UUID \
	{ 0x5dbac793, 0xf574, 0x4871, \
		{ 0x8a, 0xd3, 0x04, 0x33, 0x1e, 0xc1, 0x7f, 0x24 } }
Hi thanks for response but where do I find the TA file? Because I will need it for linking against my application right?
if not, can you please share the steps to the application without using TA file? Thanks.
did you meant generating the TA file? please refer to build instructions.
