edit_or
September 13, 2021, 3:43am
1
I am using deepstream-app and do inference for four different rtsp streams.
I like to save each stream into individual files.
When I save as
[sink1]
enable=1
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265
codec=1
#encoder type 0=Hardware 1=Software
enc-type=0
sync=0
#iframeinterval=10
bitrate=10000000
#H264 Profile - 0=Baseline 2=Main 4=High
#H265 Profile - 0=Main 1=Main10
profile=0
output-file=out.mp4
source-id=0
All four channels are saved into one file.
How can I save in four different files?
Amycao
September 14, 2021, 6:49am
3
• DeepStream Version
• TensorRT Version
edit_or
September 14, 2021, 6:52am
4
Thanks this is setup infos.
Xavier
5.1 (latest)
R32 (release), REVISION: 4.3, GCID: 21589087, BOARD: t186ref, EABI: aarch64, DATE: Fri Jun 26 04:34:27 UTC 2020
• TensorRT Version
latest
10.2
Amycao
September 14, 2021, 7:50am
5
output to two individual files, for your reference.
[tiled-display]
enable=0
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP
type=3
uri=file://../../streams/sample_1080p_h264.mp4
num-sources=1
#drop-frame-interval=2
gpu-id=0
(0): memtype_device - Memory type Device
(1): memtype_pinned - Memory type Host Pinned
(2): memtype_unified - Memory type Unified
cudadec-memtype=0
[source1]
enable=1
type=3
num-sources=1
gpu-id=0
cudadec-memtype=0
[sink1]
enable=1
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265
codec=1
enc-type=0
sync=0
#iframeinterval=10
bitrate=2000000
profile=0
output-file=out.mp4
source-id=0
[sink2]
enable=1
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265
codec=1
enc-type=0
sync=0
#iframeinterval=10
bitrate=2000000
profile=0
output-file=out1.mp4
source-id=1
edit_or
September 17, 2021, 2:06am
6
It doesn’t work.
The following config is set in my config file.
[sink1]
enable=1
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265
codec=1
enc-type=0
sync=0
#iframeinterval=10
bitrate=2000000
profile=0
output-file=out.mp4
source-id=0
[sink2]
enable=1
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265
codec=1
enc-type=0
sync=0
#iframeinterval=10
bitrate=2000000
profile=0
source-id=1
If different source-id is set (source-id=0 and source-id=1), only one file is saved.
I set both source-id=0, then it saved two out.mp4 and out1.mp4. But same video is saved. All four channels in one image as shown in attached file.
Amycao
September 17, 2021, 2:58am
7
Please disable tiler.
[tiled-display]
enable=0
