I have a suite of programs that were written for the unix environment that I am trying to compile in a windows environment (pgi workstation 11.7 (64)) with no sucess. We have narrowed down that the problem seems to be with the INCLUDE statement in that it is not reading the file properly. It was suggested to me that someone here may be able to help me. To simplify things I have deleted most of the code and just included the problem pieces.
My source code (Csumnvpi.F) is as follows
SUBROUTINE SUMM
INCLUDE ‘INPARAN.F’
IMPLICIT DOUBLE PRECISION (A-H,O-Z)
INTEGER MCATEG
PARAMETER (MAXG=MCATEG)
print *,MAXG
print *,MCATEG
end
The INPARAN.F file is
PARAMETER(MCATEG=735)
END
I have been compling it with the following command
pgf77 Csumnvpi.F
When I change PARAMETER (MAXG=MCATEG) to be PARAMETER (MAXG=100) it compiles and my print statement for MAXG is 100. However, it is not reading in MCATEG variable (the print statement for this is 0).
I am not a programmer so hopefully I have included all the information needed.
Can anyone help?
Kirsty
Hi Kristy,
The “INCLUDE” statement basically copies the entire contents of the file into this spot. Hence, you should be getting a syntax error since your INPARAN.F contains an “END” statement.
PGI$ pgf77 test.f -o test1.exe
PGFTN-S-0087-Non-constant expression where constant expression required (test.f:4)
0 inform, 0 warnings, 1 severes, 0 fatal for MAIN
PGFTN/x86-64 Windows 11.9-0: compilation completed with severe errors
Though, when I remove the ‘END’, the code compiles and runs as expected:
PGI$ cat test.f
INCLUDE 'INPARAN.F'
INTEGER MCATEG
print *,MAXG
print *,MCATEG
end
PGI$ cat INPARAN.F
PGFTN-W-0119-Redundant specification for mcateg (test.f: 3)
0 inform, 1 warnings, 0 severes, 0 fatal for MAIN
PGFTN/x86-64 Windows 11.9-0: compilation completed with warnings
PGI$ test1.exe
735
735
PGI$
This seems to suggest that INPARAN.F isn’t getting included or is blank. On Windows, file names are not case sensitive so ‘INPARAN.F’ and ‘inparan.f’ are the same. If you are doing any pre-processing, then you could be overwriting the file.
Can you try the above example and see if it works for you?
Hi Mat,
Many thanks for your help. I tried what you said it worked.
Cheers
Kirsty
