I am working with Jetson TX2 for a project that requires the use of an ultrasonic sensor HC-SR04 to measure distance between the jetson and the detected object. But I am unable find how to connect HC-SR04 to jetson directly and achieve the distance measurement!
Thank you @ShaneCCC. I found out that Ultrasonic sensor needs a pulse input which, to the best of my knowledge, is not possible from Jetson. This however can be achieved with the help of a Micro-controller (Arduino, Raspberry PI etc).
