On I tried viewing and using a video from a live stream that is in h264 format on the Jetson TX1.The live stream address is rtsp://admin:admin@/live.sdp. The stream simply does not open on vlc or the default video player. I have the newest Tegra and JetPack. On my PC, that has the same Ubuntu 14, the video stream runs perfectly.
From my research it seems to be a problem with the h264 format, because other formats can be played just fine.
Did i have to download some codec packs or something? Nobody else seems to have this problem.
Do you need some more information, because i don’t know what might be needed.
