[JetsonTX1/TX2] Gstreamer problem
Hi guys,
I have a question about video streaming issue on Jetson TX1/TX2.
Iam using Gstreamer to do video encoding with H265 compression standard on both Jetson TX1/TX2.
Server run on Nvidia Jetson TX1/TX2. Client run on CPU PC.
I dont know why client cannot receive any image from server if it run after. Client always has to run before server.
Please give me a suggestion if you faced with such this problem.
Thanks in advance. !
Best Regards,
AsleyTrung.
Hi Asley,
We have posts about rtsp and udp.
rtsp: [url]https://devtalk.nvidia.com/default/topic/1014789/jetson-tx1/-the-cpu-usage-cannot-down-use-cuda-decode-/post/5188538/#5188538[/url]
udp: [url]https://devtalk.nvidia.com/default/topic/1027423/jetson-tx2/gstreamer-issue-on-tx2/post/5225972/#5225972[/url]
Which is your case? Or you run another case?
