Hi guys,
I use Jetson TX1 to send video from HDMI camera with speed 60fps, nvidia encoding plugin omxh265enc.
But receiver machine runs on CPU only and I use decode plugin on CPU is avdec_h265 (processing capacity: 25fps).
It causes a problem that received images on receiving side is broken, smudged and green screen sometime.
I guess the reason is the difference about processing capacity.
Any suggest for me to fix this problem or to make streaming run smoothly.?
Thanks in advance.!
Best Regards,
Trung.
