Hello, I’ve installed Yolov5 on an AGX using the latest Jetpack, and followed the instructions to install Pytorch using this answer: LINK.
My problem is that when I run a detection it says its using CPU. I confirmed that CUDA is installed however when I check in python, by importing Pytorch, if CUDA is present it says False.
How do I get Pytorch to use the GPU? When using Yolov5 on my desktop this didn’t happen so I’ve no idea how to fix it. Thanks.
Also I don’t know if this is an issue but I get a warning with OpenBLAS, it went away by doing what was said here : LINK2
however when I rebooted it came back. Is there a permanent way to fix this? (Sorry if I’m not supposed to ask two things in one post.)
