Hi all I developed a custom camera driver which is working properly. The resolution of my camera is 376x376.
When I capture raw frame using v4l-ctl I get a raw frame with size 282kb which is 376x376x2 bytes
then I used the following gstreamer pipeline to visualize the frames
gst-launch-1.0 nvv4l2camerasrc ! nvvidconv ! xvimagesink
I was able to see the video stream, after this when I try to capture raw frame using v4l-ctl
the size of the image is 1.4mb which is odd.
I have attached the two raw frames here
frame9.raw (276.1 KB)
1.4.raw (1.4 MB)
hello varun_pandithurai,
may I also confirm which JetPack release version you’re working on, thanks
Hi @JerryChang
I am using jetpack 32.5.2
did you have different sensor modes?
could you please try assign the formats completely to check this.
for example,
$ v4l2-ctl -d /dev/video0 --set-fmt-video=width=2592,height=1944,pixelformat=RG10 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=1 --stream-to=test.raw
Hi @JerryChang
I have only one mode in this sensor driver.
okay,
could you please confirm you’re using the same command but dump different size raw images before/after running nvv4l2camerasrc
Hi @JerryChang
Yes I get different size raw image using same command
