*** Summary ***
I’m capturing frames from a LI-AR0234CS-GMSL2-OWL camera using the V4L2 interface.
For this investigation, I’m using v4l2-ctl to manipulate V4L2 controls and capture raw frame data, but I get similar results with my own code.
I can capture valid raw frames (albeit with a different pixel format than expected) but modifying the standard V4L2 controls (exposure, gain) has no effect.
*** System details ***
$ cat /etc/nv_tegra_release
# R35 (release), REVISION: 1.0, GCID: 31346300, BOARD: t186ref, EABI: aarch64, DATE: Thu Aug 25 18:41:45 UTC 2022
$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 20.04.5 LTS
Release: 20.04
Codename: focal
$ uname -a
Linux mtd-orin 5.10.104-tegra #1 SMP PREEMPT Wed Aug 10 20:17:07 PDT 2022 aarch64 aarch64 aarch64 GNU/Linux
*** Procedure and Results ***
I’m using this command line, adapted from the Leopard docs:
$ v4l2-ctl -V --set-fmt-video=width=1920,height=1200,pixelformat=RG10 --set-ctrl bypass_mode=0,gain=1600,exposure=22000,exposure_short=22000 --stream-mmap --stream-count=10 --stream-to=frames.raw
Those control settings set gain and all exposure controls to max values, subsequently confirmed as having been set by running with -L to show current control values.
The above does yield 10 frames of data that I am able to subsequently decode, but after issuing the following complaint:
The pixelformat 'RG10' is invalid
Format Video Capture:
Width/Height : 1920/1200
Pixel Format : 'BA10' (10-bit Bayer GRGR/BGBG)
Field : None
Bytes per Line : 3840
Size Image : 4608000
Colorspace : sRGB
Transfer Function : Default (maps to sRGB)
YCbCr/HSV Encoding: Default (maps to ITU-R 601)
Quantization : Default (maps to Full Range)
Flags :
So I’m getting data, but the RG10 format is not available (only BA10, which is a different Bayer pattern). That is not the primary problem, though.
Here is the debayered image (last of 10 captured frames):
It looks pretty dark. This room is well lit.
Some details:
- I’m debayering in the crudest possible way, so ignore any small-scale color aberration, etc.
- I’m decoding as though the input Bayer data were 16 bits per pixel (despite BA10 claiming to be the bottom 10 bits) because the input in fact occupies the full range (Input bounds: 2114 → 65535).
Then I run again with gain and exposure all set to their minimum values, like this:
$ v4l2-ctl -V --set-fmt-video=width=1920,height=1200,pixelformat=BA10 --set-ctrl bypass_mode=0,gain=100,exposure=28,exposure_short=28 --stream-mmap --stream-count=10 --stream-to=frames.raw -d /dev/video0
I get this:
[ not allowed to post second image here but it’s a new image that’s similarly dark]
Essentially identical despite totally different control settings (which all succeeded, as confirmed by running v4l2-ctl
with -L).
The controls enumerated on the V4L2 interface are inert. Exposure and gain controls reflect my settings but have no effect on the captured data.
What might I doing wrong?
Here’s what the controls show after the first run (max exposure, etc.):
$ v4l2-ctl -V -d /dev/video0 -L
Field : None
Colorspace : sRGB
Flags :
Camera Controls
group_hold 0x009a2003 (bool) : default=0 value=0 flags=execute-on-write
hdr_enable 0x009a2004 (intmenu): min=0 max=1 default=0 value=0
0: 0 (0x0)
1: 1 (0x1)
eeprom_data 0x009a2005 (str) : min=0 max=1024 step=2 value='ffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffff00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000' flags=read-only, has-payload
sensor_mode 0x009a2008 (int64) : min=0 max=1 step=1 default=0 value=0 flags=slider
gain 0x009a2009 (int64) : min=100 max=1600 step=1 default=100 value=1600 flags=slider
exposure 0x009a200a (int64) : min=28 max=22000 step=1 default=22000 value=22000 flags=slider
frame_rate 0x009a200b (int64) : min=30000000 max=30000000 step=30000000 default=30000000 value=30000000 flags=slider
exposure_short 0x009a200c (int64) : min=28 max=22000 step=1 default=22000 value=22000 flags=slider
stereo_eeprom 0x009a200d (u8) : min=0 max=4096 step=2 default=0 [160] flags=read-only, has-payload
sensor_configuration 0x009a2032 (u32) : min=0 max=4294967295 step=1 default=0 [22] flags=read-only, volatile, has-payload
sensor_mode_i2c_packet 0x009a2033 (u32) : min=0 max=4294967295 step=1 default=0 [1026] flags=read-only, volatile, has-payload
sensor_control_i2c_packet 0x009a2034 (u32) : min=0 max=4294967295 step=1 default=0 [1026] flags=read-only, volatile, has-payload
bypass_mode 0x009a2064 (intmenu): min=0 max=1 default=0 value=0
0: 0 (0x0)
1: 1 (0x1)
override_enable 0x009a2065 (intmenu): min=0 max=1 default=0 value=0
0: 0 (0x0)
1: 1 (0x1)
height_align 0x009a2066 (int) : min=1 max=16 step=1 default=1 value=1
size_align 0x009a2067 (intmenu): min=0 max=2 default=0 value=0
0: 1 (0x1)
1: 65536 (0x10000)
2: 131072 (0x20000)
write_isp_format 0x009a2068 (int) : min=1 max=1 step=1 default=1 value=1
sensor_signal_properties 0x009a2069 (u32) : min=0 max=4294967295 step=1 default=0 [30][18] flags=read-only, has-payload
sensor_image_properties 0x009a206a (u32) : min=0 max=4294967295 step=1 default=0 [30][16] flags=read-only, has-payload
sensor_control_properties 0x009a206b (u32) : min=0 max=4294967295 step=1 default=0 [30][36] flags=read-only, has-payload
sensor_dv_timings 0x009a206c (u32) : min=0 max=4294967295 step=1 default=0 [30][16] flags=read-only, has-payload
low_latency_mode 0x009a206d (bool) : default=0 value=0
preferred_stride 0x009a206e (int) : min=0 max=65535 step=1 default=0 value=0
sensor_modes 0x009a2082 (int) : min=0 max=30 step=1 default=30 value=1 flags=read-only
