hi, Shane, I found an interesting issue, I try blow command to control IMX219,
gst-launch-1.0 nvarguscamerasrc ! ‘video/x-raw(memory:NVMM),width=3820, height=2464, framerate=21/1, format=NV12’ ! nvvidconv flip-method=0 ! ‘video/x-raw,width=960, height=616’ ! nvvidconv ! nvegltransform ! nveglglessink -e
it works very well, so I check the camera parameter, and I get
Camera Controls
group_hold 0x009a2003 (bool) : default=0 value=0 flags=execute-on-write
sensor_mode 0x009a2008 (int64) : min=0 max=5 step=1 default=0 value=0 flags=slider
gain 0x009a2009 (int64) : min=16 max=170 step=1 default=16 value=128 flags=slider
exposure 0x009a200a (int64) : min=13 max=683709 step=1 default=2495 value=46765 flags=slider
frame_rate 0x009a200b (int64) : min=2000000 max=21000000 step=1 default=21000000 value=21000000 flags=slider
bypass_mode 0x009a2064 (intmenu): min=0 max=1 default=0 value=1
override_enable 0x009a2065 (intmenu): min=0 max=1 default=0 value=1
height_align 0x009a2066 (int) : min=1 max=16 step=1 default=1 value=1
size_align 0x009a2067 (intmenu): min=0 max=2 default=0 value=0
write_isp_format 0x009a2068 (bool) : default=0 value=0
sensor_signal_properties 0x009a2069 (u32) : min=0 max=4294967295 step=1 default=0 [30][18] flags=read-only, has-payload
sensor_image_properties 0x009a206a (u32) : min=0 max=4294967295 step=1 default=0 [30][16] flags=read-only, has-payload
sensor_control_properties 0x009a206b (u32) : min=0 max=4294967295 step=1 default=0 [30][36] flags=read-only, has-payload
sensor_dv_timings 0x009a206c (u32) : min=0 max=4294967295 step=1 default=0 [30][16] flags=read-only, has-payload
low_latency_mode 0x009a206d (bool) : default=0 value=0
sensor_modes 0x009a2082 (int) : min=0 max=30 step=1 default=30 value=5 flags=read-only
I found bypass_mode=1 and override_enable=1, so I try v4l2-ctl command, as
v4l2-ctl -d /dev/video0 --set-fmt-video=width=3280,height=2464,pixelformat=RG10 --set-ctrl=sensor_mode=0, --stream-mmap --stream-count=1 --stream-to=test9.raw
because the bypass_mode=1, so this command is stuck, then I run below command,
v4l2-ctl -d /dev/video0 --set-fmt-video=width=3280,height=2464,pixelformat=RG10 --set ctrl=sensor_mode=0,bypass_mode=0 --stream-mmap --stream-count=1 --stream-to=test9.raw
it works, and now the parameters of camera are
bypass_mode 0x009a2064 (intmenu): min=0 max=1 default=0 value=0
yes, as you can see, the override_enable =1 and it works, but if I just set override_enable=1 via v4l2-ctl, the command will be stuck, it seems that gst-launch-1.0 nvarguscamerasrc can set override_enable successfully, and next, I try to change the exposure and gain parameter, and both these two parameter can work very well.
now I am confused that why the v4l2-ctl cannot set override_enable=1 directly via the command:
v4l2-ctl -d /dev/video0 --set-fmt-video=width=3280,height=2464,pixelformat=RG10 --set-ctrl=sensor_mode=0,override_enable=1,bypass_mode=0 --stream-mmap --stream-count=1 --stream-to=test9.raw
