Hi, we are running the IMX274 and cannot get the gain to remain constant. When we change the exposure time, the gain adjusts automatically. We cannot get a dark image, no matter what settings we try.
gst-launch-1.0 nvcamerasrc auto-exposure=1 exposure-time=0.0005 ! 'video/x-raw(memory:NVMM),width=3840, height=2160, framerate=60/1' ! nvvidconv ! 'video/x-raw, format=I420, width=3840, height=2160' ! clockoverlay halignment=2 valignment=1 ! omxh265enc ! rtph265pay config-interval=1 ! udpsink host=192.168.2.106 port=8554
wbmode : White balance affects the color temperature of the photo
flags: readable, writable
Enum "GstNvCamWBMode" Default: 1, "auto"
(0): off - GST_NVCAM_WB_MODE_OFF
(1): auto - GST_NVCAM_WB_MODE_AUTO
(2): incandescent - GST_NVCAM_WB_MODE_INCANDESCENT
(3): fluorescent - GST_NVCAM_WB_MODE_FLUORESCENT
(4): warm-fluorescent - GST_NVCAM_WB_MODE_WARM_FLUORESCENT
(5): daylight - GST_NVCAM_WB_MODE_DAYLIGHT
(6): cloudy-daylight - GST_NVCAM_WB_MODE_CLOUDY_DAYLIGHT
(7): twilight - GST_NVCAM_WB_MODE_TWILIGHT
(8): shade - GST_NVCAM_WB_MODE_SHADE
(9): manual - GST_NVCAM_WB_MODE_MANUAL
scene-mode : property to set scene mode
Enum "GstNvCamSceneMode" Default: 0, "face-priority"
(0): face-priority - GST_NVCAM_SCENE_MODE_FACE_PRIORITY
(1): action - GST_NVCAM_SCENE_MODE_ACTION
(2): portrait - GST_NVCAM_SCENE_MODE_PORTRAIT
(3): landscape - GST_NVCAM_SCENE_MODE_LANDSCAPE
(4): night - GST_NVCAM_SCENE_MODE_NIGHT
(5): night-portrait - GST_NVCAM_SCENE_MODE_NIGHT_PORTRAIT
(6): theatre - GST_NVCAM_SCENE_MODE_THEATRE
(7): beach - GST_NVCAM_SCENE_MODE_BEACH
(8): snow - GST_NVCAM_SCENE_MODE_SNOW
(9): sunset - GST_NVCAM_SCENE_MODE_SUNSET
(10): steady-photo - GST_NVCAM_SCENE_MODE_STEADYSHOT
(11): fireworks - GST_NVCAM_SCENE_MODE_FIREWORKS
(12): sports - GST_NVCAM_SCENE_MODE_SPORTS
(13): party - GST_NVCAM_SCENE_MODE_PARTY
(14): candle-light - GST_NVCAM_SCENE_MODE_CANDLE_LIGHT
(15): barcode - GST_NVCAM_SCENE_MODE_BARCODE
color-effect : property to set color effect
Enum "GstNvCamColorEffectMode" Default: 1, "off"
(1): off - GST_NVCAM_COLOR_EFFECT_OFF
(2): mono - GST_NVCAM_COLOR_EFFECT_MONO
(3): negative - GST_NVCAM_COLOR_EFFECT_NEGATIVE
(4): solarize - GST_NVCAM_COLOR_EFFECT_SOLARIZE
(5): sepia - GST_NVCAM_COLOR_EFFECT_SEPIA
(6): posterize - GST_NVCAM_COLOR_EFFECT_POSTERIZE
(7): aqua - GST_NVCAM_COLOR_EFFECT_AQUA
auto-exposure : property to set auto exposure mode
Enum "GstNvCamAutoExposureMode" Default: 2, "on"
(1): off - GST_NVCAM_AUTO_EXPOSURE_OFF
(2): on - GST_NVCAM_AUTO_EXPOSURE_ON
(3): OnAutoFlash - GST_NVCAM_AUTO_EXPOSURE_AUTOFLASH
(4): OnAlwaysFlash - GST_NVCAM_AUTO_EXPOSURE_ALWAYSFLASH
(5): OnFlashRedEye - GST_NVCAM_AUTO_EXPOSURE_AUTO_RED_EYE
flash : property to set flash mode
Enum "GstNvCamFlashMode" Default: 0, "off"
(0): off - GST_NVCAM_FLASH_OFF
(1): on - GST_NVCAM_FLASH_ON
(2): torch - GST_NVCAM_FLASH_TORCH
(3): auto - GST_NVCAM_FLASH_AUTO
flicker : property to select flicker detection and avoidance mode
Enum "GstNvCamFlickerMode" Default: 3, "auto"
(0): off - GST_NVCAM_FLICKER_OFF
(1): 50Hz - GST_NVCAM_FLICKER_50HZ
(2): 60Hz - GST_NVCAM_FLICKER_60HZ
(3): auto - GST_NVCAM_FLICKER_AUTO
contrast : property to adjust contrast value
Float. Range: 0 - 1 Default: 0
saturation : property to adjust saturation value
Float. Range: 0 - 2 Default: 1
tnr-strength : property to adjust temporal noise reduction strength
tnr-mode : property to select temporal noise reduction mode
Enum "GstNvCamTNRMode" Default: 0, "NoiseReduction_Off"
(0): NoiseReduction_Off - GST_NVCAM_NR_OFF
(1): NoiseReduction_Fast - GST_NVCAM_NR_FAST
(2): NoiseReduction_HighQuality - GST_NVCAM_NR_HIGHQUALITY
edge-enhancement : property to adjust edge enhnacement value
Float. Range: 0 - 1 Default: -1
trigger : property to fire pre capture trigger
Enum "GstNvCamCaptureTrigger" Default: 0, ""
(1): idle - GST_NVCAM_TRIGGER_IDLE
(2): start - GST_NVCAM_TRIGGER_START
intent : property to select capture intent
Enum "GstNvCamCaptureIntent" Default: 1, "preview"
(1): preview - GST_NVCAM_INTENT_PREVIEW
(2): still - GST_NVCAM_INTENT_STILL
(3): video - GST_NVCAM_INTENT_VIDEO
(4): video-snapshot - GST_NVCAM_INTENT_VIDEO_SNAPSHOT
(5): zsl - GST_NVCAM_INTENT_ZSL
sensor-id : Set the id of camera sensor to use. Default 0.)
Integer. Range: 0 - 255 Default: 0
enable-exif : Return Exif data with captured frame
Boolean. Default: false
enable-meta : Return Sensor meta data with captured frame
aeRegion : Property to set region of interest for auto exposure.
Use GArray, with values of ROI coordinates (top,left,bottom,right)
and weight in that order, to set the property.
Boxed pointer of type "GArray"
wbRegion : Property to set region of interest for white balance.
fpsRange : Property to set FPS range.
Use string with values of FPS Range (low, high)
String. Default: null
exposure-time : Property to adjust exposure time.
This property will have effect only when Exposure mode is Off.
Float. Range: 0 - 3.402823e+38 Default: 0.033
wbManualMode : Property to set manual mode of White balance.
This property will have effect only when wbMode is manual.
Enum "GstNvCamWBManualMode" Default: 0, "off"
(0): off - GST_NVCAM_WB_MANUAL_OFF
(1): reset - GST_NVCAM_WB_MANUAL_RESET
(2): restore - GST_NVCAM_WB_MANUAL_RESTORE
(3): external-gains - GST_NVCAM_WB_MANUAL_EXTGAINS
wbGains : Property to set external white balance Gains.
Use GArray, with values of WB gains (R, GR, GB, B)
This will have effect only when wbMode is manual.
stitchConfig : Property to set stitching windows.
Use GArray, with values of sensor id and
window coordinates (sensor-id,top,left,bottom,right)
callback : Property to set user callback. It is required if user wants
to change capture settings per frame. Provide address
of GstNvCamSrcCallbacks type struct as value.
flags: writable
Pointer. Write only
dump-bayer : Dump raw bayer data in still capture mode.
num-sensors : Property to get number of sensors.
Returns GArray containing number of sensors {usb,csi}
flags: readable
orientation : Sensor orientation value. This must be accessed in READY state.
flags: readable
Integer. Range: 0 - 360 Default: -1
