Hi.
I’m using TX2NX with JP 4.6.3. I created a camera driver (IMX585) which is working fine in JP 4.5.2, I can read RAW image by command v4l2-ctl --set-fmt-video=width=3856,height=2180,pixelformat=RG12 --stream-mmap --set-ctrl=sensor_mode=0,bypass_mode=0,frame_rate=15000000,exposure=30000,gain=0,hdr_enable=0 --stream-count=1 --stream-skip=10 -d /dev/video0 --verbose flawlessly as well as using argus_camera app without problem.
But on JP 4.6.3, argus_camera app works and give the same output as JP 4.5, but v4l2-ctl raw reading (using command above) doesn’t work.
The v4l2-ctl hangs after STREAMON, dmesg message and trace as below:
v4l2-ctl
dmesg
[ 139.976798] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 139.983327] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 140.312795] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 140.319512] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 140.644818] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 140.651283] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
Trace
# tracer: nop
# entries-in-buffer/entries-written: 2810/2810 #P:4
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
kworker/4:1-5175 [004] .... 11508.920760: rtos_queue_peek_from_isr_failed: tstamp:359789624279 queue:0x0b4b4940
kworker/4:1-5175 [004] .... 11509.088745: rtos_queue_peek_from_isr_failed: tstamp:359794624271 queue:0x0b4b4940
kworker/4:1-5175 [004] .... 11509.256747: rtos_queue_peek_from_isr_failed: tstamp:359799624265 queue:0x0b4b4940
kworker/4:1-5175 [004] .... 11509.424813: rtos_queue_peek_from_isr_failed: tstamp:359804624257 queue:0x0b4b4940
kworker/4:1-5175 [004] .... 11509.592748: rtos_queue_peek_from_isr_failed: tstamp:359809624251 queue:0x0b4b4940
kworker/4:1-5175 [004] .... 11509.704746: rtos_queue_peek_from_isr_failed: tstamp:359814624245 queue:0x0b4b4940
kworker/4:1-5175 [004] .... 11509.872755: rtos_queue_peek_from_isr_failed: tstamp:359819624239 queue:0x0b4b4940
kworker/4:1-5175 [004] .... 11510.040754: rtos_queue_peek_from_isr_failed: tstamp:359824624231 queue:0x0b4b4940
kworker/4:1-5175 [004] .... 11510.208747: rtos_queue_peek_from_isr_failed: tstamp:359829624223 queue:0x0b4b4940
kworker/4:1-5175 [004] .... 11510.376761: rtos_queue_peek_from_isr_failed: tstamp:359834624216 queue:0x0b4b4940
kworker/4:1-5175 [004] .... 11510.544766: rtos_queue_peek_from_isr_failed: tstamp:359839624210 queue:0x0b4b4940
kworker/4:1-5175 [004] .... 11510.712760: rtos_queue_peek_from_isr_failed: tstamp:359844624204 queue:0x0b4b4940
kworker/4:1-5175 [004] .... 11510.824771: rtos_queue_peek_from_isr_failed: tstamp:359849624207 queue:0x0b4b4940
kworker/4:1-5175 [004] .... 11510.992735: rtos_queue_peek_from_isr_failed: tstamp:359854624187 queue:0x0b4b4940
kworker/4:1-5175 [004] .... 11511.160775: rtos_queue_peek_from_isr_failed: tstamp:359859624181 queue:0x0b4b4940
kworker/4:1-5175 [004] .... 11511.328762: rtos_queue_peek_from_isr_failed: tstamp:359864624175 queue:0x0b4b4940
kworker/4:1-5175 [004] .... 11511.496749: rtos_queue_peek_from_isr_failed: tstamp:359869624169 queue:0x0b4b4940
kworker/4:1-5175 [004] .... 11511.664763: rtos_queue_peek_from_isr_failed: tstamp:359874624163 queue:0x0b4b4940
kworker/4:1-5175 [004] .... 11511.832777: rtos_queue_peek_from_isr_failed: tstamp:359879624157 queue:0x0b4b4940
kworker/4:1-5175 [004] .... 11511.944750: rtos_queue_peek_from_isr_failed: tstamp:359884624149 queue:0x0b4b4940
kworker/4:1-5175 [004] .... 11512.112770: rtos_queue_peek_from_isr_failed: tstamp:359889624141 queue:0x0b4b4940
kworker/4:1-5175 [004] .... 11512.280753: rtos_queue_peek_from_isr_failed: tstamp:359894624135 queue:0x0b4b4940
kworker/4:1-5175 [004] .... 11512.448773: rtos_queue_peek_from_isr_failed: tstamp:359899624128 queue:0x0b4b4940
kworker/4:1-5175 [004] .... 11512.616752: rtos_queue_peek_from_isr_failed: tstamp:359904624122 queue:0x0b4b4940
kworker/4:1-5175 [004] .... 11512.784820: rtos_queue_peek_from_isr_failed: tstamp:359909624116 queue:0x0b4b4940
kworker/4:1-5175 [004] .... 11512.952726: rtos_queue_peek_from_isr_failed: tstamp:359914624108 queue:0x0b4b4940
kworker/4:1-5175 [004] .... 11513.064744: rtos_queue_peek_from_isr_failed: tstamp:359919624100 queue:0x0b4b4940
kworker/4:1-5175 [004] .... 11513.232777: rtos_queue_peek_from_isr_failed: tstamp:359924624094 queue:0x0b4b4940
kworker/4:1-5175 [004] .... 11513.400746: rtos_queue_peek_from_isr_failed: tstamp:359929624091 queue:0x0b4b4940
kworker/4:1-5175 [004] .... 11513.568747: rtos_queue_peek_from_isr_failed: tstamp:359934624082 queue:0x0b4b4940
kworker/4:1-5175 [004] .... 11513.743916: rtos_queue_peek_from_isr_failed: tstamp:359939624074 queue:0x0b4b4940
kworker/4:1-5175 [004] .... 11513.908751: rtos_queue_peek_from_isr_failed: tstamp:359944624068 queue:0x0b4b4940
kworker/4:1-5175 [004] .... 11513.964704: rtos_queue_peek_from_isr_failed: tstamp:359947020926 queue:0x0b4b4940
v4l2-ctl-5289 [000] .... 11533.569296: tegra_channel_open: vi-output, imx585 9-001a
v4l2-ctl-5289 [000] .... 11533.588746: tegra_channel_set_power: imx585 9-001a : 0x1
v4l2-ctl-5289 [000] .... 11533.588759: camera_common_s_power: status : 0x1
v4l2-ctl-5289 [000] .... 11533.889261: tegra_channel_set_power: 150c0000.nvcsi--2 : 0x1
v4l2-ctl-5289 [000] .... 11533.889271: csi_s_power: enable : 0x1
v4l2-ctl-5289 [000] .... 11533.892985: tegra_channel_capture_setup: vnc_id 0 W 3856 H 2180 fmt 20
vi-output, imx5-5290 [005] .... 11533.893235: tegra_channel_set_stream: enable : 0x1
vi-output, imx5-5290 [000] .... 11533.894669: tegra_channel_set_stream: 150c0000.nvcsi--2 : 0x1
vi-output, imx5-5290 [000] .... 11533.894673: csi_s_stream: enable : 0x1
vi-output, imx5-5290 [000] .... 11533.894713: tegra_channel_set_stream: imx585 9-001a : 0x1
kworker/4:1-5175 [004] .... 11533.920699: rtos_queue_peek_from_isr_failed: tstamp:360570492669 queue:0x0b4b4940
kworker/4:1-5175 [004] .... 11533.920701: rtcpu_start: tstamp:360570495668
kworker/4:1-5175 [004] .... 11533.920703: rtos_queue_send_from_isr_failed: tstamp:360570508531 queue:0x0b4a7698
kworker/4:1-5175 [004] .... 11533.920704: rtos_queue_send_from_isr_failed: tstamp:360570508639 queue:0x0b4ab1a8
kworker/4:1-5175 [004] .... 11533.920704: rtos_queue_send_from_isr_failed: tstamp:360570508746 queue:0x0b4acdd8
kworker/4:1-5175 [004] .... 11533.920705: rtos_queue_send_from_isr_failed: tstamp:360570508855 queue:0x0b4af718
kworker/4:1-5175 [004] .... 11533.920705: rtos_queue_send_from_isr_failed: tstamp:360570508960 queue:0x0b4b04d8
kworker/4:1-5175 [004] .... 11533.920706: rtos_queue_send_from_isr_failed: tstamp:360570509069 queue:0x0b4b1298
kworker/4:1-5175 [004] .... 11533.920707: rtos_queue_send_from_isr_failed: tstamp:360570509174 queue:0x0b4b2058
kworker/4:1-5175 [004] .... 11533.920708: rtos_queue_send_failed: tstamp:360570509633 queue:0x0b4a7698
kworker/4:1-5175 [004] .... 11533.920709: rtos_queue_send_from_isr_failed: tstamp:360570518429 queue:0x0b4a7698
kworker/4:1-5175 [004] .... 11533.920709: rtos_queue_send_from_isr_failed: tstamp:360570518536 queue:0x0b4ab1a8
kworker/4:1-5175 [004] .... 11533.920710: rtos_queue_send_from_isr_failed: tstamp:360570518641 queue:0x0b4acdd8
kworker/4:1-5175 [004] .... 11533.920711: rtos_queue_send_from_isr_failed: tstamp:360570518750 queue:0x0b4af718
kworker/4:1-5175 [004] .... 11533.920711: rtos_queue_send_from_isr_failed: tstamp:360570518859 queue:0x0b4b04d8
kworker/4:1-5175 [004] .... 11533.920712: rtos_queue_send_from_isr_failed: tstamp:360570518963 queue:0x0b4b1298
kworker/4:1-5175 [004] .... 11533.920713: rtos_queue_send_from_isr_failed: tstamp:360570519068 queue:0x0b4b2058
kworker/4:1-5175 [004] .... 11533.920713: rtos_queue_send_failed: tstamp:360570520012 queue:0x0b4a7698
vi-output, imx5-5290 [003] .... 11534.038798: tegra_channel_capture_frame: sof:11533.917993280
kworker/4:1-5175 [004] .... 11534.088756: rtcpu_vinotify_event: tstamp:360575074293 tag:ATOMP_FS channel:0x00 frame:1 vi_tstamp:360575073917 data:0x00000000
kworker/4:1-5175 [004] .... 11534.088762: rtcpu_vinotify_event: tstamp:360575079154 tag:CHANSEL_PXL_SOF channel:0x00 frame:1 vi_tstamp:360575078780 data:0x00000001
kworker/4:1-5175 [004] .... 11534.088764: rtcpu_vinotify_event: tstamp:360575084380 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:1 vi_tstamp:360575084011 data:0x08000000
kworker/4:1-5175 [004] .... 11534.088768: rtos_queue_peek_from_isr_failed: tstamp:360575492991 queue:0x0b4b4940
kworker/4:1-5175 [004] .... 11534.088770: rtcpu_vinotify_event: tstamp:360575584752 tag:CHANSEL_PXL_EOF channel:0x00 frame:1 vi_tstamp:360575583843 data:0x08830002
kworker/4:1-5175 [004] .... 11534.088772: rtcpu_vinotify_event: tstamp:360575584870 tag:CHANSEL_FAULT channel:0x00 frame:1 vi_tstamp:360575583871 data:0x00010800
kworker/4:1-5175 [004] .... 11534.088774: rtcpu_vinotify_event: tstamp:360575585066 tag:ATOMP_FE channel:0x00 frame:1 vi_tstamp:360575584088 data:0x00000000
vi-output, imx5-5290 [000] .... 11534.257563: tegra_channel_capture_setup: vnc_id 0 W 3856 H 2180 fmt 20
vi-output, imx5-5290 [000] .... 11534.257600: tegra_channel_capture_frame: sof:11533.917993280
kworker/4:1-5175 [004] .... 11534.260704: rtos_queue_peek_from_isr_failed: tstamp:360580492981 queue:0x0b4b4940
kworker/4:1-5175 [004] .... 11534.260707: rtos_queue_send_from_isr_failed: tstamp:360581899781 queue:0x0b4a7698
kworker/4:1-5175 [004] .... 11534.260708: rtos_queue_send_from_isr_failed: tstamp:360581899891 queue:0x0b4ab1a8
kworker/4:1-5175 [004] .... 11534.260709: rtos_queue_send_from_isr_failed: tstamp:360581900000 queue:0x0b4acdd8
kworker/4:1-5175 [004] .... 11534.260710: rtos_queue_send_from_isr_failed: tstamp:360581900109 queue:0x0b4af718
kworker/4:1-5175 [004] .... 11534.260711: rtos_queue_send_from_isr_failed: tstamp:360581900213 queue:0x0b4b04d8
kworker/4:1-5175 [004] .... 11534.260712: rtos_queue_send_from_isr_failed: tstamp:360581900318 queue:0x0b4b1298
kworker/4:1-5175 [004] .... 11534.260713: rtos_queue_send_from_isr_failed: tstamp:360581900423 queue:0x0b4b2058
kworker/4:1-5175 [004] .... 11534.260715: rtos_queue_send_failed: tstamp:360581900971 queue:0x0b4a7698
kworker/4:1-5175 [004] .... 11534.260716: rtos_queue_send_from_isr_failed: tstamp:360581905925 queue:0x0b4a7698
kworker/4:1-5175 [004] .... 11534.260717: rtos_queue_send_from_isr_failed: tstamp:360581906031 queue:0x0b4ab1a8
kworker/4:1-5175 [004] .... 11534.260718: rtos_queue_send_from_isr_failed: tstamp:360581906137 queue:0x0b4acdd8
kworker/4:1-5175 [004] .... 11534.260719: rtos_queue_send_from_isr_failed: tstamp:360581906245 queue:0x0b4af718
kworker/4:1-5175 [004] .... 11534.260720: rtos_queue_send_from_isr_failed: tstamp:360581906349 queue:0x0b4b04d8
kworker/4:1-5175 [004] .... 11534.260721: rtos_queue_send_from_isr_failed: tstamp:360581906453 queue:0x0b4b1298
kworker/4:1-5175 [004] .... 11534.260722: rtos_queue_send_from_isr_failed: tstamp:360581906556 queue:0x0b4b2058
kworker/4:1-5175 [004] .... 11534.260723: rtos_queue_send_failed: tstamp:360581906980 queue:0x0b4a7698
kworker/4:1-5175 [004] .... 11534.260724: rtos_queue_send_from_isr_failed: tstamp:360581912599 queue:0x0b4a7698
kworker/4:1-5175 [004] .... 11534.260725: rtos_queue_send_from_isr_failed: tstamp:360581912709 queue:0x0b4ab1a8
kworker/4:1-5175 [004] .... 11534.260726: rtos_queue_send_from_isr_failed: tstamp:360581912814 queue:0x0b4acdd8
kworker/4:1-5175 [004] .... 11534.260727: rtos_queue_send_from_isr_failed: tstamp:360581912922 queue:0x0b4af718
kworker/4:1-5175 [004] .... 11534.260728: rtos_queue_send_from_isr_failed: tstamp:360581913024 queue:0x0b4b04d8
kworker/4:1-5175 [004] .... 11534.260729: rtos_queue_send_from_isr_failed: tstamp:360581913128 queue:0x0b4b1298
kworker/4:1-5175 [004] .... 11534.260730: rtos_queue_send_from_isr_failed: tstamp:360581913233 queue:0x0b4b2058
kworker/4:1-5175 [004] .... 11534.260730: rtos_queue_send_failed: tstamp:360581913674 queue:0x0b4a7698
kworker/4:1-5175 [004] .... 11534.260731: rtos_queue_send_from_isr_failed: tstamp:360581916135 queue:0x0b4a7698
kworker/4:1-5175 [004] .... 11534.260732: rtos_queue_send_from_isr_failed: tstamp:360581916241 queue:0x0b4ab1a8
kworker/4:1-5175 [004] .... 11534.260733: rtos_queue_send_from_isr_failed: tstamp:360581916348 queue:0x0b4acdd8
kworker/4:1-5175 [004] .... 11534.260734: rtos_queue_send_from_isr_failed: tstamp:360581916455 queue:0x0b4af718
kworker/4:1-5175 [004] .... 11534.260735: rtos_queue_send_from_isr_failed: tstamp:360581916559 queue:0x0b4b04d8
kworker/4:1-5175 [004] .... 11534.260736: rtos_queue_send_from_isr_failed: tstamp:360581916664 queue:0x0b4b1298
kworker/4:1-5175 [004] .... 11534.260737: rtos_queue_send_from_isr_failed: tstamp:360581916769 queue:0x0b4b2058
kworker/4:1-5175 [004] .... 11534.260738: rtos_queue_send_failed: tstamp:360581917683 queue:0x0b4a7698
kworker/4:1-5175 [004] .... 11534.316753: rtcpu_vinotify_event: tstamp:360583415267 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:360583414895 data:0x00000001
vi-output, imx5-5290 [003] .... 11534.372428: tegra_channel_capture_frame: sof:11534.251632608
kworker/4:1-5175 [004] .... 11534.372756: rtos_queue_peek_from_isr_failed: tstamp:360585492976 queue:0x0b4b4940
kworker/4:1-5175 [004] .... 11534.372762: rtcpu_vinotify_event: tstamp:360585500518 tag:ATOMP_FS channel:0x00 frame:6 vi_tstamp:360585500143 data:0x00000000
kworker/4:1-5175 [004] .... 11534.372765: rtcpu_vinotify_event: tstamp:360585505376 tag:CHANSEL_PXL_SOF channel:0x00 frame:6 vi_tstamp:360585505007 data:0x00000001
kworker/4:1-5175 [004] .... 11534.372767: rtcpu_vinotify_event: tstamp:360585510274 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:6 vi_tstamp:360585509905 data:0x08000000
kworker/4:1-5175 [004] .... 11534.428750: rtcpu_vinotify_event: tstamp:360586010978 tag:CHANSEL_PXL_EOF channel:0x00 frame:6 vi_tstamp:360586010069 data:0x08830002
kworker/4:1-5175 [004] .... 11534.428756: rtcpu_vinotify_event: tstamp:360586011100 tag:CHANSEL_FAULT channel:0x00 frame:6 vi_tstamp:360586010098 data:0x00010800
kworker/4:1-5175 [004] .... 11534.428758: rtcpu_vinotify_event: tstamp:360586011296 tag:ATOMP_FE channel:0x00 frame:6 vi_tstamp:360586010315 data:0x00000000
kworker/4:1-5175 [004] .... 11534.540758: rtos_queue_peek_from_isr_failed: tstamp:360590492969 queue:0x0b4b4940
vi-output, imx5-5290 [005] .... 11534.589514: tegra_channel_capture_setup: vnc_id 0 W 3856 H 2180 fmt 20
vi-output, imx5-5290 [005] .... 11534.589549: tegra_channel_capture_frame: sof:11534.251632608
kworker/4:1-5175 [004] .... 11534.596698: rtos_queue_send_from_isr_failed: tstamp:360592275016 queue:0x0b4a7698
kworker/4:1-5175 [004] .... 11534.596701: rtos_queue_send_from_isr_failed: tstamp:360592275128 queue:0x0b4ab1a8
kworker/4:1-5175 [004] .... 11534.596702: rtos_queue_send_from_isr_failed: tstamp:360592275236 queue:0x0b4acdd8
kworker/4:1-5175 [004] .... 11534.596703: rtos_queue_send_from_isr_failed: tstamp:360592275343 queue:0x0b4af718
kworker/4:1-5175 [004] .... 11534.596704: rtos_queue_send_from_isr_failed: tstamp:360592275448 queue:0x0b4b04d8
kworker/4:1-5175 [004] .... 11534.596705: rtos_queue_send_from_isr_failed: tstamp:360592275553 queue:0x0b4b1298
kworker/4:1-5175 [004] .... 11534.596706: rtos_queue_send_from_isr_failed: tstamp:360592275657 queue:0x0b4b2058
kworker/4:1-5175 [004] .... 11534.596708: rtos_queue_send_failed: tstamp:360592276211 queue:0x0b4a7698
kworker/4:1-5175 [004] .... 11534.596709: rtos_queue_send_from_isr_failed: tstamp:360592280342 queue:0x0b4a7698
kworker/4:1-5175 [004] .... 11534.596709: rtos_queue_send_from_isr_failed: tstamp:360592280448 queue:0x0b4ab1a8
kworker/4:1-5175 [004] .... 11534.596710: rtos_queue_send_from_isr_failed: tstamp:360592280556 queue:0x0b4acdd8
kworker/4:1-5175 [004] .... 11534.596711: rtos_queue_send_from_isr_failed: tstamp:360592280663 queue:0x0b4af718
kworker/4:1-5175 [004] .... 11534.596712: rtos_queue_send_from_isr_failed: tstamp:360592280767 queue:0x0b4b04d8
kworker/4:1-5175 [004] .... 11534.596713: rtos_queue_send_from_isr_failed: tstamp:360592280871 queue:0x0b4b1298
kworker/4:1-5175 [004] .... 11534.596714: rtos_queue_send_from_isr_failed: tstamp:360592280976 queue:0x0b4b2058
kworker/4:1-5175 [004] .... 11534.596715: rtos_queue_send_failed: tstamp:360592281400 queue:0x0b4a7698
kworker/4:1-5175 [004] .... 11534.596716: rtos_queue_send_from_isr_failed: tstamp:360592286323 queue:0x0b4a7698
kworker/4:1-5175 [004] .... 11534.596716: rtos_queue_send_from_isr_failed: tstamp:360592286430 queue:0x0b4ab1a8
kworker/4:1-5175 [004] .... 11534.596717: rtos_queue_send_from_isr_failed: tstamp:360592286536 queue:0x0b4acdd8
kworker/4:1-5175 [004] .... 11534.596718: rtos_queue_send_from_isr_failed: tstamp:360592286644 queue:0x0b4af718
kworker/4:1-5175 [004] .... 11534.596719: rtos_queue_send_from_isr_failed: tstamp:360592286747 queue:0x0b4b04d8
kworker/4:1-5175 [004] .... 11534.596720: rtos_queue_send_from_isr_failed: tstamp:360592286851 queue:0x0b4b1298
kworker/4:1-5175 [004] .... 11534.596721: rtos_queue_send_from_isr_failed: tstamp:360592286956 queue:0x0b4b2058
kworker/4:1-5175 [004] .... 11534.596722: rtos_queue_send_failed: tstamp:360592287387 queue:0x0b4a7698
kworker/4:1-5175 [004] .... 11534.596723: rtos_queue_send_from_isr_failed: tstamp:360592289691 queue:0x0b4a7698
kworker/4:1-5175 [004] .... 11534.596723: rtos_queue_send_from_isr_failed: tstamp:360592289797 queue:0x0b4ab1a8
kworker/4:1-5175 [004] .... 11534.596724: rtos_queue_send_from_isr_failed: tstamp:360592289905 queue:0x0b4acdd8
kworker/4:1-5175 [004] .... 11534.596725: rtos_queue_send_from_isr_failed: tstamp:360592290014 queue:0x0b4af718
kworker/4:1-5175 [004] .... 11534.596726: rtos_queue_send_from_isr_failed: tstamp:360592290118 queue:0x0b4b04d8
kworker/4:1-5175 [004] .... 11534.596728: rtos_queue_send_from_isr_failed: tstamp:360592290222 queue:0x0b4b1298
kworker/4:1-5175 [004] .... 11534.596729: rtos_queue_send_from_isr_failed: tstamp:360592290328 queue:0x0b4b2058
kworker/4:1-5175 [004] .... 11534.596730: rtos_queue_send_failed: tstamp:360592291246 queue:0x0b4a7698
kworker/4:1-5175 [004] .... 11534.652765: rtcpu_vinotify_event: tstamp:360593841494 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:360593841121 data:0x00000001
vi-output, imx5-5290 [003] .... 11534.706076: tegra_channel_capture_frame: sof:11534.585271776
kworker/4:1-5175 [004] .... 11534.708763: rtos_queue_peek_from_isr_failed: tstamp:360595492963 queue:0x0b4b4940
kworker/4:1-5175 [004] .... 11534.708769: rtcpu_vinotify_event: tstamp:360595926741 tag:ATOMP_FS channel:0x00 frame:11 vi_tstamp:360595926369 data:0x00000000
kworker/4:1-5175 [004] .... 11534.708771: rtcpu_vinotify_event: tstamp:360595931604 tag:CHANSEL_PXL_SOF channel:0x00 frame:11 vi_tstamp:360595931233 data:0x00000001
kworker/4:1-5175 [004] .... 11534.708773: rtcpu_vinotify_event: tstamp:360595936801 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:11 vi_tstamp:360595936431 data:0x08000000
kworker/4:1-5175 [004] .... 11534.764832: rtcpu_vinotify_event: tstamp:360596437205 tag:CHANSEL_PXL_EOF channel:0x00 frame:11 vi_tstamp:360596436296 data:0x08830002
kworker/4:1-5175 [004] .... 11534.764839: rtcpu_vinotify_event: tstamp:360596437331 tag:CHANSEL_FAULT channel:0x00 frame:11 vi_tstamp:360596436325 data:0x00010800
kworker/4:1-5175 [004] .... 11534.764841: rtcpu_vinotify_event: tstamp:360596437525 tag:ATOMP_FE channel:0x00 frame:11 vi_tstamp:360596436542 data:0x00000000
kworker/4:1-5175 [004] .... 11534.876769: rtos_queue_peek_from_isr_failed: tstamp:360600492965 queue:0x0b4b4940
vi-output, imx5-5290 [000] .... 11534.925718: tegra_channel_capture_setup: vnc_id 0 W 3856 H 2180 fmt 20
vi-output, imx5-5290 [000] .... 11534.925758: tegra_channel_capture_frame: sof:11534.585271776
Looks at the trace, it looks like I have error tag:CHANSEL_FAULT channel:0x00 frame:11 vi_tstamp:360596436325 data:0x00010800. According to Jetson/l4t/Camera BringUp - eLinux.org, it looks like the error is PIXEL_SPURIOUS? Which means the line information is missing in the image data.
Is there any update in JP 4.6 that can cause this error?
Look at register setting applied for image sensor, all registers are set to identical values between JP 4.6 and JP 4.5.
Device tree is also the same for both Jetpack.
Thank you so much for reading and sharing.
