we have a TX2-NX with a Raspberry PI camera module connected to one CSI-2 port. The camera works fine with Argus, however when I try to capture raw data with v4l2-ctl the tool hangs and there are no frames captured. I use the following command for trying to capture the raw data:
v4l2-ctl -d /dev/video0 --set-ctrl bypass_mode=0 --set-fmt-video=width=3264,height=2464,pixelformat=RG10 --stream-mmap --stream-count=1 --stream-to=image.raw
A clean dmesg after the command gives:
nvidia@nvidia-desktop:~$ sudo dmesg -c
[ 1159.232468] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 1159.240450] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 1159.456518] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 1159.464738] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 1159.676546] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 1159.684603] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 1159.900639] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 1159.908592] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 1160.124574] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
It seems VI doesnt receive the acquired frame in time. If this is the case whats the difference compared to receiving the data with Argus?
We are using L4T R32.6.1
Any suggestions on this issue are very much appreciated. If you need more information please let me know…
Thanks, Steve
What’s the camera? IMX219?
Maybe check the trace log for the v4l2-ctl if more clue.
Yeah this a IMX219 based camera.
I’ve tried to enable the trace log, but when I do so I get a permission denied error:
nvidia@nvidia-desktop:~$ echo 1 > /sys/kernel/debug/tracing/tracing_on
bash: /sys/kernel/debug/tracing/tracing_on: Permission denied
nvidia@nvidia-desktop:~$ sudo echo 1 > /sys/kernel/debug/tracing/tracing_on
Do you have any advise why this isn’t possible?
Thanks,
Steve
I managed to enable tracing via sudo -s
This is the log I get after I executed the v4l2-ctl command:
tracer: nop
# entries-in-buffer/entries-written: 582/582 #P:6
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
v4l2-ctl-8841 [002] .... 424.166602: tegra_channel_open: vi-output, imx219 0-0010
v4l2-ctl-8841 [002] .... 424.167835: tegra_channel_set_power: imx219 0-0010 : 0x1
v4l2-ctl-8841 [002] .... 424.167896: camera_common_s_power: status : 0x1
v4l2-ctl-8841 [002] .... 424.191220: tegra_channel_set_power: 150c0000.nvcsi--1 : 0x1
v4l2-ctl-8841 [002] .... 424.191238: csi_s_power: enable : 0x1
v4l2-ctl-8841 [002] .... 424.223046: tegra_channel_capture_setup: vnc_id 0 W 3264 H 2464 fmt 20
vi-output, imx2-8842 [004] .... 424.223243: tegra_channel_set_stream: enable : 0x1
vi-output, imx2-8842 [000] .... 424.224397: tegra_channel_set_stream: 150c0000.nvcsi--1 : 0x1
vi-output, imx2-8842 [000] .... 424.224399: csi_s_stream: enable : 0x1
vi-output, imx2-8842 [000] .... 424.224428: tegra_channel_set_stream: imx219 0-0010 : 0x1
kworker/1:0-18 [001] .... 424.268453: rtos_queue_peek_from_isr_failed: tstamp:13492175636 queue:0x0b4b4940
kworker/1:0-18 [001] .... 424.268465: rtcpu_start: tstamp:13492178914
kworker/1:0-18 [001] .... 424.268470: rtos_queue_send_from_isr_failed: tstamp:13492189915 queue:0x0b4a7698
kworker/1:0-18 [001] .... 424.268474: rtos_queue_send_from_isr_failed: tstamp:13492190023 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 424.268477: rtos_queue_send_from_isr_failed: tstamp:13492190129 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 424.268480: rtos_queue_send_from_isr_failed: tstamp:13492190237 queue:0x0b4af718
kworker/1:0-18 [001] .... 424.268483: rtos_queue_send_from_isr_failed: tstamp:13492190340 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 424.268486: rtos_queue_send_from_isr_failed: tstamp:13492190447 queue:0x0b4b1298
kworker/1:0-18 [001] .... 424.268489: rtos_queue_send_from_isr_failed: tstamp:13492190553 queue:0x0b4b2058
kworker/1:0-18 [001] .... 424.268494: rtos_queue_send_failed: tstamp:13492191013 queue:0x0b4a7698
kworker/1:0-18 [001] .... 424.268497: rtos_queue_send_from_isr_failed: tstamp:13492196332 queue:0x0b4a7698
kworker/1:0-18 [001] .... 424.268500: rtos_queue_send_from_isr_failed: tstamp:13492196440 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 424.268503: rtos_queue_send_from_isr_failed: tstamp:13492196546 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 424.268506: rtos_queue_send_from_isr_failed: tstamp:13492196655 queue:0x0b4af718
kworker/1:0-18 [001] .... 424.268509: rtos_queue_send_from_isr_failed: tstamp:13492196760 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 424.268512: rtos_queue_send_from_isr_failed: tstamp:13492196865 queue:0x0b4b1298
kworker/1:0-18 [001] .... 424.268515: rtos_queue_send_from_isr_failed: tstamp:13492196969 queue:0x0b4b2058
kworker/1:0-18 [001] .... 424.268518: rtos_queue_send_failed: tstamp:13492197901 queue:0x0b4a7698
kworker/1:0-18 [001] .... 424.436486: rtos_queue_peek_from_isr_failed: tstamp:13497176077 queue:0x0b4b4940
vi-output, imx2-8842 [000] .... 424.467303: tegra_channel_capture_setup: vnc_id 0 W 3264 H 2464 fmt 20
vi-output, imx2-8842 [000] .... 424.467376: tegra_channel_capture_frame: sof:-549620698988.-271825995648
kworker/1:0-18 [001] .... 424.492512: rtos_queue_send_from_isr_failed: tstamp:13499802517 queue:0x0b4a7698
kworker/1:0-18 [001] .... 424.492532: rtos_queue_send_from_isr_failed: tstamp:13499802787 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 424.492650: rtos_queue_send_from_isr_failed: tstamp:13499803058 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 424.492657: rtos_queue_send_from_isr_failed: tstamp:13499803388 queue:0x0b4af718
kworker/1:0-18 [001] .... 424.492665: rtos_queue_send_from_isr_failed: tstamp:13499803667 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 424.492672: rtos_queue_send_from_isr_failed: tstamp:13499803934 queue:0x0b4b1298
kworker/1:0-18 [001] .... 424.492680: rtos_queue_send_from_isr_failed: tstamp:13499804200 queue:0x0b4b2058
kworker/1:0-18 [001] .... 424.492693: rtos_queue_send_failed: tstamp:13499805429 queue:0x0b4a7698
kworker/1:0-18 [001] .... 424.492701: rtos_queue_send_from_isr_failed: tstamp:13499811643 queue:0x0b4a7698
kworker/1:0-18 [001] .... 424.492709: rtos_queue_send_from_isr_failed: tstamp:13499811913 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 424.492717: rtos_queue_send_from_isr_failed: tstamp:13499812181 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 424.492725: rtos_queue_send_from_isr_failed: tstamp:13499812455 queue:0x0b4af718
kworker/1:0-18 [001] .... 424.492732: rtos_queue_send_from_isr_failed: tstamp:13499812723 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 424.492739: rtos_queue_send_from_isr_failed: tstamp:13499812989 queue:0x0b4b1298
kworker/1:0-18 [001] .... 424.492747: rtos_queue_send_from_isr_failed: tstamp:13499813255 queue:0x0b4b2058
kworker/1:0-18 [001] .... 424.492755: rtos_queue_send_failed: tstamp:13499814387 queue:0x0b4a7698
kworker/1:0-18 [001] .... 424.492763: rtos_queue_send_from_isr_failed: tstamp:13499822159 queue:0x0b4a7698
kworker/1:0-18 [001] .... 424.492771: rtos_queue_send_from_isr_failed: tstamp:13499822429 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 424.492779: rtos_queue_send_from_isr_failed: tstamp:13499822697 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 424.492786: rtos_queue_send_from_isr_failed: tstamp:13499822967 queue:0x0b4af718
kworker/1:0-18 [001] .... 424.492794: rtos_queue_send_from_isr_failed: tstamp:13499823247 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 424.492802: rtos_queue_send_from_isr_failed: tstamp:13499823514 queue:0x0b4b1298
kworker/1:0-18 [001] .... 424.492809: rtos_queue_send_from_isr_failed: tstamp:13499823784 queue:0x0b4b2058
kworker/1:0-18 [001] .... 424.492818: rtos_queue_send_failed: tstamp:13499824880 queue:0x0b4a7698
kworker/1:0-18 [001] .... 424.492825: rtos_queue_send_from_isr_failed: tstamp:13499827726 queue:0x0b4a7698
kworker/1:0-18 [001] .... 424.492834: rtos_queue_send_from_isr_failed: tstamp:13499827994 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 424.492841: rtos_queue_send_from_isr_failed: tstamp:13499828265 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 424.492849: rtos_queue_send_from_isr_failed: tstamp:13499828536 queue:0x0b4af718
kworker/1:0-18 [001] .... 424.492856: rtos_queue_send_from_isr_failed: tstamp:13499828805 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 424.492864: rtos_queue_send_from_isr_failed: tstamp:13499829072 queue:0x0b4b1298
kworker/1:0-18 [001] .... 424.492872: rtos_queue_send_from_isr_failed: tstamp:13499829340 queue:0x0b4b2058
kworker/1:0-18 [001] .... 424.492879: rtos_queue_send_failed: tstamp:13499832573 queue:0x0b4a7698
kworker/1:0-18 [001] .... 424.548558: rtos_queue_peek_from_isr_failed: tstamp:13502176072 queue:0x0b4b4940
vi-output, imx2-8842 [000] .... 424.687199: tegra_channel_capture_setup: vnc_id 0 W 3264 H 2464 fmt 20
vi-output, imx2-8842 [000] .... 424.687255: tegra_channel_capture_frame: sof:-549620698988.-271825995648
kworker/1:0-18 [001] .... 424.716554: rtos_queue_send_from_isr_failed: tstamp:13506673582 queue:0x0b4a7698
kworker/1:0-18 [001] .... 424.716713: rtos_queue_send_from_isr_failed: tstamp:13506673857 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 424.716722: rtos_queue_send_from_isr_failed: tstamp:13506674130 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 424.716732: rtos_queue_send_from_isr_failed: tstamp:13506674467 queue:0x0b4af718
kworker/1:0-18 [001] .... 424.716740: rtos_queue_send_from_isr_failed: tstamp:13506674735 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 424.716748: rtos_queue_send_from_isr_failed: tstamp:13506675001 queue:0x0b4b1298
kworker/1:0-18 [001] .... 424.716756: rtos_queue_send_from_isr_failed: tstamp:13506675269 queue:0x0b4b2058
kworker/1:0-18 [001] .... 424.716769: rtos_queue_send_failed: tstamp:13506676563 queue:0x0b4a7698
kworker/1:0-18 [001] .... 424.716777: rtos_queue_send_from_isr_failed: tstamp:13506682417 queue:0x0b4a7698
kworker/1:0-18 [001] .... 424.716785: rtos_queue_send_from_isr_failed: tstamp:13506682685 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 424.716793: rtos_queue_send_from_isr_failed: tstamp:13506682955 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 424.716801: rtos_queue_send_from_isr_failed: tstamp:13506683226 queue:0x0b4af718
kworker/1:0-18 [001] .... 424.716826: rtos_queue_send_from_isr_failed: tstamp:13506683494 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 424.716834: rtos_queue_send_from_isr_failed: tstamp:13506683764 queue:0x0b4b1298
kworker/1:0-18 [001] .... 424.716842: rtos_queue_send_from_isr_failed: tstamp:13506684040 queue:0x0b4b2058
kworker/1:0-18 [001] .... 424.716850: rtos_queue_send_failed: tstamp:13506685158 queue:0x0b4a7698
kworker/1:0-18 [001] .... 424.716858: rtos_queue_send_from_isr_failed: tstamp:13506694119 queue:0x0b4a7698
kworker/1:0-18 [001] .... 424.716866: rtos_queue_send_from_isr_failed: tstamp:13506694390 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 424.716874: rtos_queue_send_from_isr_failed: tstamp:13506694662 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 424.716882: rtos_queue_send_from_isr_failed: tstamp:13506694947 queue:0x0b4af718
kworker/1:0-18 [001] .... 424.716890: rtos_queue_send_from_isr_failed: tstamp:13506695211 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 424.716898: rtos_queue_send_from_isr_failed: tstamp:13506695477 queue:0x0b4b1298
kworker/1:0-18 [001] .... 424.717006: rtos_queue_send_from_isr_failed: tstamp:13506695744 queue:0x0b4b2058
kworker/1:0-18 [001] .... 424.717014: rtos_queue_send_failed: tstamp:13506696877 queue:0x0b4a7698
kworker/1:0-18 [001] .... 424.717022: rtos_queue_send_from_isr_failed: tstamp:13506699533 queue:0x0b4a7698
kworker/1:0-18 [001] .... 424.717030: rtos_queue_send_from_isr_failed: tstamp:13506699801 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 424.717038: rtos_queue_send_from_isr_failed: tstamp:13506700067 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 424.717046: rtos_queue_send_from_isr_failed: tstamp:13506700337 queue:0x0b4af718
kworker/1:0-18 [001] .... 424.717054: rtos_queue_send_from_isr_failed: tstamp:13506700604 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 424.717062: rtos_queue_send_from_isr_failed: tstamp:13506700871 queue:0x0b4b1298
kworker/1:0-18 [001] .... 424.717069: rtos_queue_send_from_isr_failed: tstamp:13506701137 queue:0x0b4b2058
kworker/1:0-18 [001] .... 424.717078: rtos_queue_send_failed: tstamp:13506704449 queue:0x0b4a7698
kworker/1:0-18 [001] .... 424.717092: rtos_queue_peek_from_isr_failed: tstamp:13507175940 queue:0x0b4b4940
kworker/1:0-18 [001] .... 424.884378: rtos_queue_peek_from_isr_failed: tstamp:13512176019 queue:0x0b4b4940
vi-output, imx2-8842 [000] .... 424.907289: tegra_channel_capture_setup: vnc_id 0 W 3264 H 2464 fmt 20
vi-output, imx2-8842 [000] .... 424.907364: tegra_channel_capture_frame: sof:-549620698988.-271825995648
kworker/1:0-18 [001] .... 424.940523: rtos_queue_send_from_isr_failed: tstamp:13513551454 queue:0x0b4a7698
kworker/1:0-18 [001] .... 424.940543: rtos_queue_send_from_isr_failed: tstamp:13513551740 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 424.940657: rtos_queue_send_from_isr_failed: tstamp:13513552011 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 424.940665: rtos_queue_send_from_isr_failed: tstamp:13513552281 queue:0x0b4af718
kworker/1:0-18 [001] .... 424.940672: rtos_queue_send_from_isr_failed: tstamp:13513552548 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 424.940680: rtos_queue_send_from_isr_failed: tstamp:13513552814 queue:0x0b4b1298
kworker/1:0-18 [001] .... 424.940688: rtos_queue_send_from_isr_failed: tstamp:13513553080 queue:0x0b4b2058
kworker/1:0-18 [001] .... 424.940701: rtos_queue_send_failed: tstamp:13513554373 queue:0x0b4a7698
kworker/1:0-18 [001] .... 424.940709: rtos_queue_send_from_isr_failed: tstamp:13513559785 queue:0x0b4a7698
kworker/1:0-18 [001] .... 424.940717: rtos_queue_send_from_isr_failed: tstamp:13513560055 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 424.940725: rtos_queue_send_from_isr_failed: tstamp:13513560327 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 424.940732: rtos_queue_send_from_isr_failed: tstamp:13513560598 queue:0x0b4af718
kworker/1:0-18 [001] .... 424.940740: rtos_queue_send_from_isr_failed: tstamp:13513560865 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 424.940748: rtos_queue_send_from_isr_failed: tstamp:13513561135 queue:0x0b4b1298
kworker/1:0-18 [001] .... 424.940755: rtos_queue_send_from_isr_failed: tstamp:13513561406 queue:0x0b4b2058
kworker/1:0-18 [001] .... 424.940763: rtos_queue_send_failed: tstamp:13513562478 queue:0x0b4a7698
kworker/1:0-18 [001] .... 424.940771: rtos_queue_send_from_isr_failed: tstamp:13513570336 queue:0x0b4a7698
kworker/1:0-18 [001] .... 424.940779: rtos_queue_send_from_isr_failed: tstamp:13513570628 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 424.940786: rtos_queue_send_from_isr_failed: tstamp:13513570895 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 424.940795: rtos_queue_send_from_isr_failed: tstamp:13513571162 queue:0x0b4af718
kworker/1:0-18 [001] .... 424.940802: rtos_queue_send_from_isr_failed: tstamp:13513571427 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 424.940810: rtos_queue_send_from_isr_failed: tstamp:13513571691 queue:0x0b4b1298
kworker/1:0-18 [001] .... 424.940817: rtos_queue_send_from_isr_failed: tstamp:13513571956 queue:0x0b4b2058
kworker/1:0-18 [001] .... 424.940825: rtos_queue_send_failed: tstamp:13513573121 queue:0x0b4a7698
kworker/1:0-18 [001] .... 424.940833: rtos_queue_send_from_isr_failed: tstamp:13513576650 queue:0x0b4a7698
kworker/1:0-18 [001] .... 424.940841: rtos_queue_send_from_isr_failed: tstamp:13513576918 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 424.940849: rtos_queue_send_from_isr_failed: tstamp:13513577185 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 424.940856: rtos_queue_send_from_isr_failed: tstamp:13513577452 queue:0x0b4af718
kworker/1:0-18 [001] .... 424.940864: rtos_queue_send_from_isr_failed: tstamp:13513577718 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 424.940872: rtos_queue_send_from_isr_failed: tstamp:13513577983 queue:0x0b4b1298
kworker/1:0-18 [001] .... 424.940879: rtos_queue_send_from_isr_failed: tstamp:13513578247 queue:0x0b4b2058
kworker/1:0-18 [001] .... 424.940887: rtos_queue_send_failed: tstamp:13513581534 queue:0x0b4a7698
kworker/1:0-18 [001] .... 425.052429: rtos_queue_peek_from_isr_failed: tstamp:13517176075 queue:0x0b4b4940
vi-output, imx2-8842 [000] .... 425.127121: tegra_channel_capture_setup: vnc_id 0 W 3264 H 2464 fmt 20
vi-output, imx2-8842 [000] .... 425.127173: tegra_channel_capture_frame: sof:-549620698988.-271825995648
kworker/1:0-18 [001] .... 425.164355: rtos_queue_send_from_isr_failed: tstamp:13520421127 queue:0x0b4a7698
kworker/1:0-18 [001] .... 425.164361: rtos_queue_send_from_isr_failed: tstamp:13520421399 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 425.164363: rtos_queue_send_from_isr_failed: tstamp:13520421672 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 425.164364: rtos_queue_send_from_isr_failed: tstamp:13520421943 queue:0x0b4af718
kworker/1:0-18 [001] .... 425.164366: rtos_queue_send_from_isr_failed: tstamp:13520422211 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 425.164368: rtos_queue_send_from_isr_failed: tstamp:13520422484 queue:0x0b4b1298
kworker/1:0-18 [001] .... 425.164369: rtos_queue_send_from_isr_failed: tstamp:13520422753 queue:0x0b4b2058
kworker/1:0-18 [001] .... 425.164372: rtos_queue_send_failed: tstamp:13520423988 queue:0x0b4a7698
kworker/1:0-18 [001] .... 425.164374: rtos_queue_send_from_isr_failed: tstamp:13520433145 queue:0x0b4a7698
kworker/1:0-18 [001] .... 425.164375: rtos_queue_send_from_isr_failed: tstamp:13520433415 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 425.164377: rtos_queue_send_from_isr_failed: tstamp:13520433685 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 425.164378: rtos_queue_send_from_isr_failed: tstamp:13520433956 queue:0x0b4af718
kworker/1:0-18 [001] .... 425.164380: rtos_queue_send_from_isr_failed: tstamp:13520434224 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 425.164382: rtos_queue_send_from_isr_failed: tstamp:13520434493 queue:0x0b4b1298
kworker/1:0-18 [001] .... 425.164383: rtos_queue_send_from_isr_failed: tstamp:13520434760 queue:0x0b4b2058
kworker/1:0-18 [001] .... 425.164385: rtos_queue_send_failed: tstamp:13520435884 queue:0x0b4a7698
kworker/1:0-18 [001] .... 425.164387: rtos_queue_send_from_isr_failed: tstamp:13520441805 queue:0x0b4a7698
kworker/1:0-18 [001] .... 425.164388: rtos_queue_send_from_isr_failed: tstamp:13520442076 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 425.164390: rtos_queue_send_from_isr_failed: tstamp:13520442344 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 425.164391: rtos_queue_send_from_isr_failed: tstamp:13520442614 queue:0x0b4af718
kworker/1:0-18 [001] .... 425.164393: rtos_queue_send_from_isr_failed: tstamp:13520442881 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 425.164394: rtos_queue_send_from_isr_failed: tstamp:13520443148 queue:0x0b4b1298
kworker/1:0-18 [001] .... 425.164396: rtos_queue_send_from_isr_failed: tstamp:13520443415 queue:0x0b4b2058
kworker/1:0-18 [001] .... 425.164398: rtos_queue_send_failed: tstamp:13520444494 queue:0x0b4a7698
kworker/1:0-18 [001] .... 425.164399: rtos_queue_send_from_isr_failed: tstamp:13520447126 queue:0x0b4a7698
kworker/1:0-18 [001] .... 425.164402: rtos_queue_send_from_isr_failed: tstamp:13520447395 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 425.164404: rtos_queue_send_from_isr_failed: tstamp:13520447662 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 425.164406: rtos_queue_send_from_isr_failed: tstamp:13520447930 queue:0x0b4af718
kworker/1:0-18 [001] .... 425.164407: rtos_queue_send_from_isr_failed: tstamp:13520448197 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 425.164409: rtos_queue_send_from_isr_failed: tstamp:13520448462 queue:0x0b4b1298
kworker/1:0-18 [001] .... 425.164410: rtos_queue_send_from_isr_failed: tstamp:13520448728 queue:0x0b4b2058
kworker/1:0-18 [001] .... 425.164412: rtos_queue_send_failed: tstamp:13520452055 queue:0x0b4a7698
kworker/1:0-18 [001] .... 425.220320: rtos_queue_peek_from_isr_failed: tstamp:13522175923 queue:0x0b4b4940
vi-output, imx2-8842 [000] .... 425.346694: tegra_channel_capture_setup: vnc_id 0 W 3264 H 2464 fmt 20
vi-output, imx2-8842 [000] .... 425.346731: tegra_channel_capture_frame: sof:-549620698988.-271825995648
kworker/1:0-18 [001] .... 425.388515: rtos_queue_peek_from_isr_failed: tstamp:13527175916 queue:0x0b4b4940
kworker/1:0-18 [001] .... 425.388551: rtos_queue_send_from_isr_failed: tstamp:13527298332 queue:0x0b4a7698
kworker/1:0-18 [001] .... 425.388672: rtos_queue_send_from_isr_failed: tstamp:13527298441 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 425.388681: rtos_queue_send_from_isr_failed: tstamp:13527298548 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 425.388689: rtos_queue_send_from_isr_failed: tstamp:13527298658 queue:0x0b4af718
kworker/1:0-18 [001] .... 425.388697: rtos_queue_send_from_isr_failed: tstamp:13527298762 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 425.388705: rtos_queue_send_from_isr_failed: tstamp:13527298867 queue:0x0b4b1298
kworker/1:0-18 [001] .... 425.388712: rtos_queue_send_from_isr_failed: tstamp:13527298971 queue:0x0b4b2058
kworker/1:0-18 [001] .... 425.388726: rtos_queue_send_failed: tstamp:13527299584 queue:0x0b4a7698
kworker/1:0-18 [001] .... 425.388734: rtos_queue_send_from_isr_failed: tstamp:13527303439 queue:0x0b4a7698
kworker/1:0-18 [001] .... 425.388742: rtos_queue_send_from_isr_failed: tstamp:13527303547 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 425.388750: rtos_queue_send_from_isr_failed: tstamp:13527303653 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 425.388758: rtos_queue_send_from_isr_failed: tstamp:13527303761 queue:0x0b4af718
kworker/1:0-18 [001] .... 425.388766: rtos_queue_send_from_isr_failed: tstamp:13527303866 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 425.388774: rtos_queue_send_from_isr_failed: tstamp:13527303971 queue:0x0b4b1298
kworker/1:0-18 [001] .... 425.388782: rtos_queue_send_from_isr_failed: tstamp:13527304077 queue:0x0b4b2058
kworker/1:0-18 [001] .... 425.388790: rtos_queue_send_failed: tstamp:13527304497 queue:0x0b4a7698
kworker/1:0-18 [001] .... 425.388798: rtos_queue_send_from_isr_failed: tstamp:13527309186 queue:0x0b4a7698
kworker/1:0-18 [001] .... 425.388806: rtos_queue_send_from_isr_failed: tstamp:13527309291 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 425.388814: rtos_queue_send_from_isr_failed: tstamp:13527309397 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 425.388822: rtos_queue_send_from_isr_failed: tstamp:13527309504 queue:0x0b4af718
kworker/1:0-18 [001] .... 425.388830: rtos_queue_send_from_isr_failed: tstamp:13527309609 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 425.388838: rtos_queue_send_from_isr_failed: tstamp:13527309714 queue:0x0b4b1298
kworker/1:0-18 [001] .... 425.388845: rtos_queue_send_from_isr_failed: tstamp:13527309818 queue:0x0b4b2058
kworker/1:0-18 [001] .... 425.388853: rtos_queue_send_failed: tstamp:13527310247 queue:0x0b4a7698
kworker/1:0-18 [001] .... 425.388862: rtos_queue_send_from_isr_failed: tstamp:13527312358 queue:0x0b4a7698
kworker/1:0-18 [001] .... 425.388869: rtos_queue_send_from_isr_failed: tstamp:13527312464 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 425.388878: rtos_queue_send_from_isr_failed: tstamp:13527312570 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 425.388885: rtos_queue_send_from_isr_failed: tstamp:13527312678 queue:0x0b4af718
kworker/1:0-18 [001] .... 425.388894: rtos_queue_send_from_isr_failed: tstamp:13527312782 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 425.388901: rtos_queue_send_from_isr_failed: tstamp:13527312897 queue:0x0b4b1298
kworker/1:0-18 [001] .... 425.388910: rtos_queue_send_from_isr_failed: tstamp:13527313006 queue:0x0b4b2058
kworker/1:0-18 [001] .... 425.388917: rtos_queue_send_failed: tstamp:13527313929 queue:0x0b4a7698
kworker/1:0-18 [001] .... 425.556782: rtos_queue_peek_from_isr_failed: tstamp:13532176029 queue:0x0b4b4940
vi-output, imx2-8842 [002] .... 425.569371: tegra_channel_capture_setup: vnc_id 0 W 3264 H 2464 fmt 20
vi-output, imx2-8842 [002] .... 425.569414: tegra_channel_capture_frame: sof:-549620698988.-271825995648
kworker/1:0-18 [001] .... 425.612501: rtos_queue_send_from_isr_failed: tstamp:13534243869 queue:0x0b4a7698
kworker/1:0-18 [001] .... 425.612526: rtos_queue_send_from_isr_failed: tstamp:13534244140 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 425.612656: rtos_queue_send_from_isr_failed: tstamp:13534244407 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 425.612665: rtos_queue_send_from_isr_failed: tstamp:13534244674 queue:0x0b4af718
kworker/1:0-18 [001] .... 425.612673: rtos_queue_send_from_isr_failed: tstamp:13534244938 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 425.612681: rtos_queue_send_from_isr_failed: tstamp:13534245206 queue:0x0b4b1298
kworker/1:0-18 [001] .... 425.612689: rtos_queue_send_from_isr_failed: tstamp:13534245472 queue:0x0b4b2058
kworker/1:0-18 [001] .... 425.612702: rtos_queue_send_failed: tstamp:13534246690 queue:0x0b4a7698
kworker/1:0-18 [001] .... 425.612710: rtos_queue_send_from_isr_failed: tstamp:13534253518 queue:0x0b4a7698
kworker/1:0-18 [001] .... 425.612718: rtos_queue_send_from_isr_failed: tstamp:13534253624 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 425.612726: rtos_queue_send_from_isr_failed: tstamp:13534253732 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 425.612734: rtos_queue_send_from_isr_failed: tstamp:13534253839 queue:0x0b4af718
kworker/1:0-18 [001] .... 425.612742: rtos_queue_send_from_isr_failed: tstamp:13534253943 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 425.612750: rtos_queue_send_from_isr_failed: tstamp:13534254051 queue:0x0b4b1298
kworker/1:0-18 [001] .... 425.612758: rtos_queue_send_from_isr_failed: tstamp:13534254156 queue:0x0b4b2058
kworker/1:0-18 [001] .... 425.612766: rtos_queue_send_failed: tstamp:13534254577 queue:0x0b4a7698
kworker/1:0-18 [001] .... 425.612774: rtos_queue_send_from_isr_failed: tstamp:13534263138 queue:0x0b4a7698
kworker/1:0-18 [001] .... 425.612782: rtos_queue_send_from_isr_failed: tstamp:13534263244 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 425.612790: rtos_queue_send_from_isr_failed: tstamp:13534263351 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 425.612798: rtos_queue_send_from_isr_failed: tstamp:13534263458 queue:0x0b4af718
kworker/1:0-18 [001] .... 425.612806: rtos_queue_send_from_isr_failed: tstamp:13534263563 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 425.612814: rtos_queue_send_from_isr_failed: tstamp:13534263667 queue:0x0b4b1298
kworker/1:0-18 [001] .... 425.612822: rtos_queue_send_from_isr_failed: tstamp:13534263772 queue:0x0b4b2058
kworker/1:0-18 [001] .... 425.612829: rtos_queue_send_failed: tstamp:13534264248 queue:0x0b4a7698
kworker/1:0-18 [001] .... 425.612837: rtos_queue_send_from_isr_failed: tstamp:13534269248 queue:0x0b4a7698
kworker/1:0-18 [001] .... 425.612846: rtos_queue_send_from_isr_failed: tstamp:13534269354 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 425.612853: rtos_queue_send_from_isr_failed: tstamp:13534269459 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 425.612862: rtos_queue_send_from_isr_failed: tstamp:13534269577 queue:0x0b4af718
kworker/1:0-18 [001] .... 425.612869: rtos_queue_send_from_isr_failed: tstamp:13534269691 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 425.612878: rtos_queue_send_from_isr_failed: tstamp:13534269803 queue:0x0b4b1298
kworker/1:0-18 [001] .... 425.612885: rtos_queue_send_from_isr_failed: tstamp:13534269908 queue:0x0b4b2058
kworker/1:0-18 [001] .... 425.612893: rtos_queue_send_failed: tstamp:13534270830 queue:0x0b4a7698
kworker/1:0-18 [001] .... 425.668504: rtos_queue_peek_from_isr_failed: tstamp:13537176040 queue:0x0b4b4940
vi-output, imx2-8842 [001] .... 425.794603: tegra_channel_capture_setup: vnc_id 0 W 3264 H 2464 fmt 20
vi-output, imx2-8842 [001] .... 425.794679: tegra_channel_capture_frame: sof:-549620698988.-271825995648
kworker/1:0-18 [001] .... 425.836506: rtos_queue_send_from_isr_failed: tstamp:13541215862 queue:0x0b4a7698
kworker/1:0-18 [001] .... 425.836644: rtos_queue_send_from_isr_failed: tstamp:13541215971 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 425.836653: rtos_queue_send_from_isr_failed: tstamp:13541216078 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 425.836661: rtos_queue_send_from_isr_failed: tstamp:13541216186 queue:0x0b4af718
kworker/1:0-18 [001] .... 425.836669: rtos_queue_send_from_isr_failed: tstamp:13541216290 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 425.836677: rtos_queue_send_from_isr_failed: tstamp:13541216401 queue:0x0b4b1298
kworker/1:0-18 [001] .... 425.836685: rtos_queue_send_from_isr_failed: tstamp:13541216506 queue:0x0b4b2058
kworker/1:0-18 [001] .... 425.836699: rtos_queue_send_failed: tstamp:13541217099 queue:0x0b4a7698
kworker/1:0-18 [001] .... 425.836706: rtos_queue_send_from_isr_failed: tstamp:13541223602 queue:0x0b4a7698
kworker/1:0-18 [001] .... 425.836714: rtos_queue_send_from_isr_failed: tstamp:13541223708 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 425.836722: rtos_queue_send_from_isr_failed: tstamp:13541223813 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 425.836730: rtos_queue_send_from_isr_failed: tstamp:13541223921 queue:0x0b4af718
kworker/1:0-18 [001] .... 425.836738: rtos_queue_send_from_isr_failed: tstamp:13541224024 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 425.836746: rtos_queue_send_from_isr_failed: tstamp:13541224132 queue:0x0b4b1298
kworker/1:0-18 [001] .... 425.836754: rtos_queue_send_from_isr_failed: tstamp:13541224236 queue:0x0b4b2058
kworker/1:0-18 [001] .... 425.836762: rtos_queue_send_failed: tstamp:13541224652 queue:0x0b4a7698
kworker/1:0-18 [001] .... 425.836769: rtos_queue_send_from_isr_failed: tstamp:13541236217 queue:0x0b4a7698
kworker/1:0-18 [001] .... 425.836778: rtos_queue_send_from_isr_failed: tstamp:13541236324 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 425.836786: rtos_queue_send_from_isr_failed: tstamp:13541236430 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 425.836794: rtos_queue_send_from_isr_failed: tstamp:13541236537 queue:0x0b4af718
kworker/1:0-18 [001] .... 425.836801: rtos_queue_send_from_isr_failed: tstamp:13541236641 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 425.836810: rtos_queue_send_from_isr_failed: tstamp:13541236745 queue:0x0b4b1298
kworker/1:0-18 [001] .... 425.836817: rtos_queue_send_from_isr_failed: tstamp:13541236849 queue:0x0b4b2058
kworker/1:0-18 [001] .... 425.836825: rtos_queue_send_failed: tstamp:13541237282 queue:0x0b4a7698
kworker/1:0-18 [001] .... 425.836832: rtos_queue_send_from_isr_failed: tstamp:13541264124 queue:0x0b4a7698
kworker/1:0-18 [001] .... 425.836840: rtos_queue_send_from_isr_failed: tstamp:13541264394 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 425.836847: rtos_queue_send_from_isr_failed: tstamp:13541264666 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 425.836855: rtos_queue_send_from_isr_failed: tstamp:13541264937 queue:0x0b4af718
kworker/1:0-18 [001] .... 425.836864: rtos_queue_send_from_isr_failed: tstamp:13541265269 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 425.836871: rtos_queue_send_from_isr_failed: tstamp:13541265535 queue:0x0b4b1298
kworker/1:0-18 [001] .... 425.836880: rtos_queue_send_from_isr_failed: tstamp:13541265802 queue:0x0b4b2058
kworker/1:0-18 [001] .... 425.836888: rtos_queue_send_failed: tstamp:13541269070 queue:0x0b4a7698
kworker/1:0-18 [001] .... 425.836902: rtos_queue_peek_from_isr_failed: tstamp:13542176017 queue:0x0b4b4940
kworker/1:0-18 [001] .... 426.004472: rtos_queue_peek_from_isr_failed: tstamp:13547175972 queue:0x0b4b4940
vi-output, imx2-8842 [001] .... 426.017857: tegra_channel_capture_setup: vnc_id 0 W 3264 H 2464 fmt 20
vi-output, imx2-8842 [001] .... 426.017899: tegra_channel_capture_frame: sof:-549620698988.-271825995648
kworker/1:0-18 [001] .... 426.060523: rtos_queue_send_from_isr_failed: tstamp:13548253168 queue:0x0b4a7698
kworker/1:0-18 [001] .... 426.060547: rtos_queue_send_from_isr_failed: tstamp:13548253438 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 426.060556: rtos_queue_send_from_isr_failed: tstamp:13548253705 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 426.060689: rtos_queue_send_from_isr_failed: tstamp:13548253972 queue:0x0b4af718
kworker/1:0-18 [001] .... 426.060697: rtos_queue_send_from_isr_failed: tstamp:13548254237 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 426.060705: rtos_queue_send_from_isr_failed: tstamp:13548254501 queue:0x0b4b1298
kworker/1:0-18 [001] .... 426.060713: rtos_queue_send_from_isr_failed: tstamp:13548254767 queue:0x0b4b2058
kworker/1:0-18 [001] .... 426.060727: rtos_queue_send_failed: tstamp:13548256116 queue:0x0b4a7698
kworker/1:0-18 [001] .... 426.060734: rtos_queue_send_from_isr_failed: tstamp:13548263520 queue:0x0b4a7698
kworker/1:0-18 [001] .... 426.060742: rtos_queue_send_from_isr_failed: tstamp:13548263634 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 426.060750: rtos_queue_send_from_isr_failed: tstamp:13548263743 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 426.060758: rtos_queue_send_from_isr_failed: tstamp:13548263852 queue:0x0b4af718
kworker/1:0-18 [001] .... 426.060766: rtos_queue_send_from_isr_failed: tstamp:13548263957 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 426.060774: rtos_queue_send_from_isr_failed: tstamp:13548264062 queue:0x0b4b1298
kworker/1:0-18 [001] .... 426.060782: rtos_queue_send_from_isr_failed: tstamp:13548264167 queue:0x0b4b2058
kworker/1:0-18 [001] .... 426.060790: rtos_queue_send_failed: tstamp:13548264587 queue:0x0b4a7698
kworker/1:0-18 [001] .... 426.060799: rtos_queue_send_from_isr_failed: tstamp:13548277136 queue:0x0b4a7698
kworker/1:0-18 [001] .... 426.060806: rtos_queue_send_from_isr_failed: tstamp:13548277244 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 426.060814: rtos_queue_send_from_isr_failed: tstamp:13548277350 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 426.060822: rtos_queue_send_from_isr_failed: tstamp:13548277458 queue:0x0b4af718
kworker/1:0-18 [001] .... 426.060830: rtos_queue_send_from_isr_failed: tstamp:13548277563 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 426.060838: rtos_queue_send_from_isr_failed: tstamp:13548277668 queue:0x0b4b1298
kworker/1:0-18 [001] .... 426.060846: rtos_queue_send_from_isr_failed: tstamp:13548277773 queue:0x0b4b2058
kworker/1:0-18 [001] .... 426.060855: rtos_queue_send_failed: tstamp:13548278214 queue:0x0b4a7698
kworker/1:0-18 [001] .... 426.060862: rtos_queue_send_from_isr_failed: tstamp:13548284131 queue:0x0b4a7698
kworker/1:0-18 [001] .... 426.060870: rtos_queue_send_from_isr_failed: tstamp:13548284246 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 426.060878: rtos_queue_send_from_isr_failed: tstamp:13548284354 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 426.060886: rtos_queue_send_from_isr_failed: tstamp:13548284461 queue:0x0b4af718
kworker/1:0-18 [001] .... 426.060894: rtos_queue_send_from_isr_failed: tstamp:13548284565 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 426.060902: rtos_queue_send_from_isr_failed: tstamp:13548284669 queue:0x0b4b1298
kworker/1:0-18 [001] .... 426.060910: rtos_queue_send_from_isr_failed: tstamp:13548284772 queue:0x0b4b2058
kworker/1:0-18 [001] .... 426.060925: rtos_queue_send_failed: tstamp:13548285688 queue:0x0b4a7698
kworker/1:0-18 [001] .... 426.172673: rtos_queue_peek_from_isr_failed: tstamp:13552175999 queue:0x0b4b4940
vi-output, imx2-8842 [001] .... 426.239482: tegra_channel_capture_setup: vnc_id 0 W 3264 H 2464 fmt 20
vi-output, imx2-8842 [001] .... 426.239518: tegra_channel_capture_frame: sof:-549620698988.-271825995648
kworker/1:0-18 [001] .... 426.292340: rtos_queue_send_from_isr_failed: tstamp:13555190223 queue:0x0b4a7698
kworker/1:0-18 [001] .... 426.292345: rtos_queue_send_from_isr_failed: tstamp:13555190332 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 426.292346: rtos_queue_send_from_isr_failed: tstamp:13555190440 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 426.292348: rtos_queue_send_from_isr_failed: tstamp:13555190547 queue:0x0b4af718
kworker/1:0-18 [001] .... 426.292349: rtos_queue_send_from_isr_failed: tstamp:13555190650 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 426.292350: rtos_queue_send_from_isr_failed: tstamp:13555190755 queue:0x0b4b1298
kworker/1:0-18 [001] .... 426.292352: rtos_queue_send_from_isr_failed: tstamp:13555190860 queue:0x0b4b2058
kworker/1:0-18 [001] .... 426.292354: rtos_queue_send_failed: tstamp:13555191459 queue:0x0b4a7698
kworker/1:0-18 [001] .... 426.292356: rtos_queue_send_from_isr_failed: tstamp:13555196825 queue:0x0b4a7698
kworker/1:0-18 [001] .... 426.292357: rtos_queue_send_from_isr_failed: tstamp:13555196932 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 426.292359: rtos_queue_send_from_isr_failed: tstamp:13555197037 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 426.292360: rtos_queue_send_from_isr_failed: tstamp:13555197146 queue:0x0b4af718
kworker/1:0-18 [001] .... 426.292361: rtos_queue_send_from_isr_failed: tstamp:13555197251 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 426.292363: rtos_queue_send_from_isr_failed: tstamp:13555197356 queue:0x0b4b1298
kworker/1:0-18 [001] .... 426.292364: rtos_queue_send_from_isr_failed: tstamp:13555197461 queue:0x0b4b2058
kworker/1:0-18 [001] .... 426.292366: rtos_queue_send_failed: tstamp:13555197883 queue:0x0b4a7698
kworker/1:0-18 [001] .... 426.292367: rtos_queue_send_from_isr_failed: tstamp:13555204550 queue:0x0b4a7698
kworker/1:0-18 [001] .... 426.292369: rtos_queue_send_from_isr_failed: tstamp:13555204657 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 426.292370: rtos_queue_send_from_isr_failed: tstamp:13555204762 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 426.292371: rtos_queue_send_from_isr_failed: tstamp:13555204871 queue:0x0b4af718
kworker/1:0-18 [001] .... 426.292373: rtos_queue_send_from_isr_failed: tstamp:13555204977 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 426.292374: rtos_queue_send_from_isr_failed: tstamp:13555205082 queue:0x0b4b1298
kworker/1:0-18 [001] .... 426.292376: rtos_queue_send_from_isr_failed: tstamp:13555205187 queue:0x0b4b2058
kworker/1:0-18 [001] .... 426.292377: rtos_queue_send_failed: tstamp:13555205624 queue:0x0b4a7698
kworker/1:0-18 [001] .... 426.292378: rtos_queue_send_from_isr_failed: tstamp:13555210140 queue:0x0b4a7698
kworker/1:0-18 [001] .... 426.292380: rtos_queue_send_from_isr_failed: tstamp:13555210257 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 426.292381: rtos_queue_send_from_isr_failed: tstamp:13555210363 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 426.292383: rtos_queue_send_from_isr_failed: tstamp:13555210471 queue:0x0b4af718
kworker/1:0-18 [001] .... 426.292384: rtos_queue_send_from_isr_failed: tstamp:13555210575 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 426.292385: rtos_queue_send_from_isr_failed: tstamp:13555210680 queue:0x0b4b1298
kworker/1:0-18 [001] .... 426.292387: rtos_queue_send_from_isr_failed: tstamp:13555210783 queue:0x0b4b2058
kworker/1:0-18 [001] .... 426.292388: rtos_queue_send_failed: tstamp:13555211708 queue:0x0b4a7698
kworker/1:0-18 [001] .... 426.348408: rtos_queue_peek_from_isr_failed: tstamp:13557175875 queue:0x0b4b4940
kworker/1:0-18 [001] .... 426.460900: rtos_queue_send_from_isr_failed: tstamp:13562105171 queue:0x0b4a7698
kworker/1:0-18 [001] .... 426.460909: rtos_queue_send_from_isr_failed: tstamp:13562105447 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 426.460912: rtos_queue_send_from_isr_failed: tstamp:13562105719 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 426.460915: rtos_queue_send_from_isr_failed: tstamp:13562105989 queue:0x0b4af718
kworker/1:0-18 [001] .... 426.460917: rtos_queue_send_from_isr_failed: tstamp:13562106255 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 426.460920: rtos_queue_send_from_isr_failed: tstamp:13562106522 queue:0x0b4b1298
kworker/1:0-18 [001] .... 426.460923: rtos_queue_send_from_isr_failed: tstamp:13562106790 queue:0x0b4b2058
kworker/1:0-18 [001] .... 426.460927: rtos_queue_send_failed: tstamp:13562108102 queue:0x0b4a7698
kworker/1:0-18 [001] .... 426.460930: rtos_queue_send_from_isr_failed: tstamp:13562120465 queue:0x0b4a7698
kworker/1:0-18 [001] .... 426.461039: rtos_queue_send_from_isr_failed: tstamp:13562120732 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 426.461041: rtos_queue_send_from_isr_failed: tstamp:13562120999 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 426.461044: rtos_queue_send_from_isr_failed: tstamp:13562121268 queue:0x0b4af718
kworker/1:0-18 [001] .... 426.461046: rtos_queue_send_from_isr_failed: tstamp:13562121532 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 426.461048: rtos_queue_send_from_isr_failed: tstamp:13562121797 queue:0x0b4b1298
kworker/1:0-18 [001] .... 426.461051: rtos_queue_send_from_isr_failed: tstamp:13562122061 queue:0x0b4b2058
kworker/1:0-18 [001] .... 426.461053: rtos_queue_send_failed: tstamp:13562123118 queue:0x0b4a7698
kworker/1:0-18 [001] .... 426.461056: rtos_queue_send_from_isr_failed: tstamp:13562131299 queue:0x0b4a7698
kworker/1:0-18 [001] .... 426.461058: rtos_queue_send_from_isr_failed: tstamp:13562131405 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 426.461060: rtos_queue_send_from_isr_failed: tstamp:13562131510 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 426.461062: rtos_queue_send_from_isr_failed: tstamp:13562131618 queue:0x0b4af718
kworker/1:0-18 [001] .... 426.461065: rtos_queue_send_from_isr_failed: tstamp:13562131723 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 426.461067: rtos_queue_send_from_isr_failed: tstamp:13562131828 queue:0x0b4b1298
kworker/1:0-18 [001] .... 426.461069: rtos_queue_send_from_isr_failed: tstamp:13562131932 queue:0x0b4b2058
kworker/1:0-18 [001] .... 426.461072: rtos_queue_send_failed: tstamp:13562132360 queue:0x0b4a7698
vi-output, imx2-8842 [002] .... 426.461137: tegra_channel_capture_setup: vnc_id 0 W 3264 H 2464 fmt 20
vi-output, imx2-8842 [002] .... 426.461177: tegra_channel_capture_frame: sof:-549620698988.-271825995648
kworker/1:0-18 [001] .n.. 426.516579: rtos_queue_send_from_isr_failed: tstamp:13562136688 queue:0x0b4a7698
kworker/1:0-18 [001] .... 426.516663: rtos_queue_send_from_isr_failed: tstamp:13562136795 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 426.516672: rtos_queue_send_from_isr_failed: tstamp:13562136902 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 426.516679: rtos_queue_send_from_isr_failed: tstamp:13562137008 queue:0x0b4af718
kworker/1:0-18 [001] .... 426.516686: rtos_queue_send_from_isr_failed: tstamp:13562137113 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 426.516693: rtos_queue_send_from_isr_failed: tstamp:13562137226 queue:0x0b4b1298
kworker/1:0-18 [001] .... 426.516700: rtos_queue_send_from_isr_failed: tstamp:13562137330 queue:0x0b4b2058
kworker/1:0-18 [001] .... 426.516708: rtos_queue_send_failed: tstamp:13562138262 queue:0x0b4a7698
kworker/1:0-18 [001] .... 426.516718: rtos_queue_peek_from_isr_failed: tstamp:13562175867 queue:0x0b4b4940
kworker/1:0-18 [001] .... 426.628449: rtos_queue_peek_from_isr_failed: tstamp:13567175946 queue:0x0b4b4940
vi-output, imx2-8842 [001] .... 426.686500: tegra_channel_capture_setup: vnc_id 0 W 3264 H 2464 fmt 20
vi-output, imx2-8842 [001] .... 426.686544: tegra_channel_capture_frame: sof:-549620698988.-271825995648
kworker/1:0-18 [001] .... 426.740624: rtos_queue_send_from_isr_failed: tstamp:13569150567 queue:0x0b4a7698
kworker/1:0-18 [001] .... 426.740649: rtos_queue_send_from_isr_failed: tstamp:13569150838 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 426.740783: rtos_queue_send_from_isr_failed: tstamp:13569151108 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 426.740791: rtos_queue_send_from_isr_failed: tstamp:13569151382 queue:0x0b4af718
kworker/1:0-18 [001] .... 426.740799: rtos_queue_send_from_isr_failed: tstamp:13569151646 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 426.740808: rtos_queue_send_from_isr_failed: tstamp:13569151913 queue:0x0b4b1298
kworker/1:0-18 [001] .... 426.740815: rtos_queue_send_from_isr_failed: tstamp:13569152192 queue:0x0b4b2058
kworker/1:0-18 [001] .... 426.740829: rtos_queue_send_failed: tstamp:13569153419 queue:0x0b4a7698
kworker/1:0-18 [001] .... 426.740837: rtos_queue_send_from_isr_failed: tstamp:13569160366 queue:0x0b4a7698
kworker/1:0-18 [001] .... 426.740845: rtos_queue_send_from_isr_failed: tstamp:13569160473 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 426.740852: rtos_queue_send_from_isr_failed: tstamp:13569160578 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 426.740860: rtos_queue_send_from_isr_failed: tstamp:13569160685 queue:0x0b4af718
kworker/1:0-18 [001] .... 426.740868: rtos_queue_send_from_isr_failed: tstamp:13569160789 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 426.740876: rtos_queue_send_from_isr_failed: tstamp:13569160893 queue:0x0b4b1298
kworker/1:0-18 [001] .... 426.740884: rtos_queue_send_from_isr_failed: tstamp:13569160998 queue:0x0b4b2058
kworker/1:0-18 [001] .... 426.740892: rtos_queue_send_failed: tstamp:13569161422 queue:0x0b4a7698
kworker/1:0-18 [001] .... 426.740901: rtos_queue_send_from_isr_failed: tstamp:13569173712 queue:0x0b4a7698
kworker/1:0-18 [001] .... 426.740908: rtos_queue_send_from_isr_failed: tstamp:13569173819 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 426.740916: rtos_queue_send_from_isr_failed: tstamp:13569173924 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 426.740924: rtos_queue_send_from_isr_failed: tstamp:13569174032 queue:0x0b4af718
kworker/1:0-18 [001] .... 426.740932: rtos_queue_send_from_isr_failed: tstamp:13569174150 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 426.740940: rtos_queue_send_from_isr_failed: tstamp:13569174254 queue:0x0b4b1298
kworker/1:0-18 [001] .... 426.740949: rtos_queue_send_from_isr_failed: tstamp:13569174367 queue:0x0b4b2058
kworker/1:0-18 [001] .... 426.740957: rtos_queue_send_failed: tstamp:13569174800 queue:0x0b4a7698
kworker/1:0-18 [001] .... 426.740965: rtos_queue_send_from_isr_failed: tstamp:13569179280 queue:0x0b4a7698
kworker/1:0-18 [001] .... 426.740973: rtos_queue_send_from_isr_failed: tstamp:13569179386 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 426.740980: rtos_queue_send_from_isr_failed: tstamp:13569179491 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 426.740988: rtos_queue_send_from_isr_failed: tstamp:13569179608 queue:0x0b4af718
kworker/1:0-18 [001] .... 426.740996: rtos_queue_send_from_isr_failed: tstamp:13569179713 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 426.741004: rtos_queue_send_from_isr_failed: tstamp:13569179818 queue:0x0b4b1298
kworker/1:0-18 [001] .... 426.741012: rtos_queue_send_from_isr_failed: tstamp:13569179923 queue:0x0b4b2058
kworker/1:0-18 [001] .... 426.741020: rtos_queue_send_failed: tstamp:13569180838 queue:0x0b4a7698
kworker/1:0-18 [001] .... 426.796551: rtos_queue_peek_from_isr_failed: tstamp:13572175974 queue:0x0b4b4940
vi-output, imx2-8842 [000] .... 426.910728: tegra_channel_capture_setup: vnc_id 0 W 3264 H 2464 fmt 20
vi-output, imx2-8842 [000] .... 426.910772: tegra_channel_capture_frame: sof:-549620698988.-271825995648
kworker/1:0-18 [001] .... 426.964523: rtos_queue_send_from_isr_failed: tstamp:13576170380 queue:0x0b4a7698
kworker/1:0-18 [001] .... 426.964680: rtos_queue_send_from_isr_failed: tstamp:13576170489 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 426.964689: rtos_queue_send_from_isr_failed: tstamp:13576170597 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 426.964698: rtos_queue_send_from_isr_failed: tstamp:13576170704 queue:0x0b4af718
kworker/1:0-18 [001] .... 426.964705: rtos_queue_send_from_isr_failed: tstamp:13576170808 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 426.964713: rtos_queue_send_from_isr_failed: tstamp:13576170915 queue:0x0b4b1298
kworker/1:0-18 [001] .... 426.964721: rtos_queue_send_from_isr_failed: tstamp:13576171018 queue:0x0b4b2058
kworker/1:0-18 [001] .... 426.964734: rtos_queue_send_failed: tstamp:13576171633 queue:0x0b4a7698
kworker/1:0-18 [001] .... 426.964743: rtos_queue_send_from_isr_failed: tstamp:13576175300 queue:0x0b4a7698
kworker/1:0-18 [001] .... 426.964750: rtos_queue_send_from_isr_failed: tstamp:13576175406 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 426.964758: rtos_queue_send_from_isr_failed: tstamp:13576175513 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 426.964866: rtos_queue_send_from_isr_failed: tstamp:13576175620 queue:0x0b4af718
kworker/1:0-18 [001] .... 426.964874: rtos_queue_send_from_isr_failed: tstamp:13576175724 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 426.964882: rtos_queue_send_from_isr_failed: tstamp:13576175829 queue:0x0b4b1298
kworker/1:0-18 [001] .... 426.964890: rtos_queue_send_from_isr_failed: tstamp:13576175933 queue:0x0b4b2058
kworker/1:0-18 [001] .... 426.964898: rtos_queue_send_failed: tstamp:13576176361 queue:0x0b4a7698
kworker/1:0-18 [001] .... 426.964906: rtos_queue_send_from_isr_failed: tstamp:13576182747 queue:0x0b4a7698
kworker/1:0-18 [001] .... 426.964914: rtos_queue_send_from_isr_failed: tstamp:13576182853 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 426.964922: rtos_queue_send_from_isr_failed: tstamp:13576182958 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 426.964930: rtos_queue_send_from_isr_failed: tstamp:13576183067 queue:0x0b4af718
kworker/1:0-18 [001] .... 426.964938: rtos_queue_send_from_isr_failed: tstamp:13576183182 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 426.964946: rtos_queue_send_from_isr_failed: tstamp:13576183288 queue:0x0b4b1298
kworker/1:0-18 [001] .... 426.964954: rtos_queue_send_from_isr_failed: tstamp:13576183391 queue:0x0b4b2058
kworker/1:0-18 [001] .... 426.964962: rtos_queue_send_failed: tstamp:13576183824 queue:0x0b4a7698
kworker/1:0-18 [001] .... 426.964970: rtos_queue_send_from_isr_failed: tstamp:13576187411 queue:0x0b4a7698
kworker/1:0-18 [001] .... 426.964978: rtos_queue_send_from_isr_failed: tstamp:13576187516 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 426.964986: rtos_queue_send_from_isr_failed: tstamp:13576187622 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 426.964994: rtos_queue_send_from_isr_failed: tstamp:13576187731 queue:0x0b4af718
kworker/1:0-18 [001] .... 426.965001: rtos_queue_send_from_isr_failed: tstamp:13576187836 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 426.965010: rtos_queue_send_from_isr_failed: tstamp:13576187941 queue:0x0b4b1298
kworker/1:0-18 [001] .... 426.965018: rtos_queue_send_from_isr_failed: tstamp:13576188046 queue:0x0b4b2058
kworker/1:0-18 [001] .... 426.965026: rtos_queue_send_failed: tstamp:13576188975 queue:0x0b4a7698
kworker/1:0-18 [001] .... 426.965039: rtos_queue_peek_from_isr_failed: tstamp:13577175985 queue:0x0b4b4940
vi-output, imx2-8842 [000] .... 427.130990: tegra_channel_capture_setup: vnc_id 0 W 3264 H 2464 fmt 20
vi-output, imx2-8842 [000] .... 427.131036: tegra_channel_capture_frame: sof:-549620698988.-271825995648
kworker/1:0-18 [001] .... 427.132689: rtos_queue_peek_from_isr_failed: tstamp:13582175928 queue:0x0b4b4940
kworker/1:0-18 [001] .... 427.132710: rtos_queue_send_from_isr_failed: tstamp:13583046676 queue:0x0b4a7698
kworker/1:0-18 [001] .... 427.132718: rtos_queue_send_from_isr_failed: tstamp:13583046949 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 427.132725: rtos_queue_send_from_isr_failed: tstamp:13583047224 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 427.132732: rtos_queue_send_from_isr_failed: tstamp:13583047509 queue:0x0b4af718
kworker/1:0-18 [001] .... 427.132848: rtos_queue_send_from_isr_failed: tstamp:13583047775 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 427.132858: rtos_queue_send_from_isr_failed: tstamp:13583048041 queue:0x0b4b1298
kworker/1:0-18 [001] .... 427.132866: rtos_queue_send_from_isr_failed: tstamp:13583048308 queue:0x0b4b2058
kworker/1:0-18 [001] .... 427.132876: rtos_queue_send_failed: tstamp:13583049536 queue:0x0b4a7698
kworker/1:0-18 [001] .... 427.132884: rtos_queue_send_from_isr_failed: tstamp:13583053177 queue:0x0b4a7698
kworker/1:0-18 [001] .... 427.132891: rtos_queue_send_from_isr_failed: tstamp:13583053444 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 427.132898: rtos_queue_send_from_isr_failed: tstamp:13583053711 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 427.132905: rtos_queue_send_from_isr_failed: tstamp:13583053982 queue:0x0b4af718
kworker/1:0-18 [001] .... 427.132912: rtos_queue_send_from_isr_failed: tstamp:13583054248 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 427.132920: rtos_queue_send_from_isr_failed: tstamp:13583054512 queue:0x0b4b1298
kworker/1:0-18 [001] .... 427.132927: rtos_queue_send_from_isr_failed: tstamp:13583054778 queue:0x0b4b2058
kworker/1:0-18 [001] .... 427.132934: rtos_queue_send_failed: tstamp:13583055839 queue:0x0b4a7698
kworker/1:0-18 [001] .... 427.132941: rtos_queue_send_from_isr_failed: tstamp:13583062912 queue:0x0b4a7698
kworker/1:0-18 [001] .... 427.132948: rtos_queue_send_from_isr_failed: tstamp:13583063240 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 427.132955: rtos_queue_send_from_isr_failed: tstamp:13583063509 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 427.132963: rtos_queue_send_from_isr_failed: tstamp:13583063843 queue:0x0b4af718
kworker/1:0-18 [001] .... 427.132970: rtos_queue_send_from_isr_failed: tstamp:13583064109 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 427.132977: rtos_queue_send_from_isr_failed: tstamp:13583064375 queue:0x0b4b1298
kworker/1:0-18 [001] .... 427.132984: rtos_queue_send_from_isr_failed: tstamp:13583064642 queue:0x0b4b2058
kworker/1:0-18 [001] .... 427.132991: rtos_queue_send_failed: tstamp:13583065723 queue:0x0b4a7698
kworker/1:0-18 [001] .... 427.132998: rtos_queue_send_from_isr_failed: tstamp:13583068230 queue:0x0b4a7698
kworker/1:0-18 [001] .... 427.133006: rtos_queue_send_from_isr_failed: tstamp:13583068497 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 427.133012: rtos_queue_send_from_isr_failed: tstamp:13583068764 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 427.133019: rtos_queue_send_from_isr_failed: tstamp:13583069034 queue:0x0b4af718
kworker/1:0-18 [001] .... 427.133027: rtos_queue_send_from_isr_failed: tstamp:13583069301 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 427.133034: rtos_queue_send_from_isr_failed: tstamp:13583069567 queue:0x0b4b1298
kworker/1:0-18 [001] .... 427.133041: rtos_queue_send_from_isr_failed: tstamp:13583069840 queue:0x0b4b2058
kworker/1:0-18 [001] .... 427.133048: rtos_queue_send_failed: tstamp:13583073087 queue:0x0b4a7698
v4l2-ctl-8841 [001] .... 427.267748: tegra_channel_close: vi-output, imx219 0-0010
kworker/1:0-18 [001] .... 427.300534: rtos_queue_peek_from_isr_failed: tstamp:13587175833 queue:0x0b4b4940
vi-output, imx2-8842 [002] .... 427.351395: tegra_channel_capture_setup: vnc_id 0 W 3264 H 2464 fmt 20
vi-output, imx2-8842 [002] .... 427.351434: tegra_channel_capture_frame: sof:-549620698988.-271825995648
v4l2-ctl-8841 [002] .... 427.352698: tegra_channel_set_stream: enable : 0x0
v4l2-ctl-8841 [002] .... 427.352702: tegra_channel_set_stream: imx219 0-0010 : 0x0
kworker/1:0-18 [001] .... 427.356376: rtos_queue_send_from_isr_failed: tstamp:13589938234 queue:0x0b4a7698
kworker/1:0-18 [001] .... 427.356384: rtos_queue_send_from_isr_failed: tstamp:13589938342 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 427.356387: rtos_queue_send_from_isr_failed: tstamp:13589938450 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 427.356390: rtos_queue_send_from_isr_failed: tstamp:13589938557 queue:0x0b4af718
kworker/1:0-18 [001] .... 427.356394: rtos_queue_send_from_isr_failed: tstamp:13589938661 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 427.356397: rtos_queue_send_from_isr_failed: tstamp:13589938766 queue:0x0b4b1298
kworker/1:0-18 [001] .... 427.356400: rtos_queue_send_from_isr_failed: tstamp:13589938871 queue:0x0b4b2058
kworker/1:0-18 [001] .... 427.356494: rtos_queue_send_failed: tstamp:13589939460 queue:0x0b4a7698
kworker/1:0-18 [001] .... 427.356498: rtos_queue_send_from_isr_failed: tstamp:13589944680 queue:0x0b4a7698
kworker/1:0-18 [001] .... 427.356501: rtos_queue_send_from_isr_failed: tstamp:13589944788 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 427.356504: rtos_queue_send_from_isr_failed: tstamp:13589944893 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 427.356507: rtos_queue_send_from_isr_failed: tstamp:13589945002 queue:0x0b4af718
kworker/1:0-18 [001] .... 427.356510: rtos_queue_send_from_isr_failed: tstamp:13589945107 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 427.356513: rtos_queue_send_from_isr_failed: tstamp:13589945211 queue:0x0b4b1298
kworker/1:0-18 [001] .... 427.356516: rtos_queue_send_from_isr_failed: tstamp:13589945314 queue:0x0b4b2058
kworker/1:0-18 [001] .... 427.356520: rtos_queue_send_failed: tstamp:13589945737 queue:0x0b4a7698
kworker/1:0-18 [001] .... 427.356523: rtos_queue_send_from_isr_failed: tstamp:13589952346 queue:0x0b4a7698
kworker/1:0-18 [001] .... 427.356526: rtos_queue_send_from_isr_failed: tstamp:13589952466 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 427.356529: rtos_queue_send_from_isr_failed: tstamp:13589952573 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 427.356532: rtos_queue_send_from_isr_failed: tstamp:13589952681 queue:0x0b4af718
kworker/1:0-18 [001] .... 427.356536: rtos_queue_send_from_isr_failed: tstamp:13589952785 queue:0x0b4b04d8
kworker/1:0-18 [001] .n.. 427.356546: rtos_queue_send_from_isr_failed: tstamp:13589952890 queue:0x0b4b1298
kworker/1:0-18 [001] .... 427.356572: rtos_queue_send_from_isr_failed: tstamp:13589952993 queue:0x0b4b2058
kworker/1:0-18 [001] .... 427.356575: rtos_queue_send_failed: tstamp:13589953424 queue:0x0b4a7698
kworker/1:0-18 [001] .... 427.356579: rtos_queue_send_from_isr_failed: tstamp:13589957322 queue:0x0b4a7698
kworker/1:0-18 [001] .... 427.356582: rtos_queue_send_from_isr_failed: tstamp:13589957428 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 427.356585: rtos_queue_send_from_isr_failed: tstamp:13589957534 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 427.356588: rtos_queue_send_from_isr_failed: tstamp:13589957643 queue:0x0b4af718
kworker/1:0-18 [001] .... 427.356591: rtos_queue_send_from_isr_failed: tstamp:13589957749 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 427.356594: rtos_queue_send_from_isr_failed: tstamp:13589957853 queue:0x0b4b1298
kworker/1:0-18 [001] .... 427.356597: rtos_queue_send_from_isr_failed: tstamp:13589957958 queue:0x0b4b2058
kworker/1:0-18 [001] .... 427.356600: rtos_queue_send_failed: tstamp:13589958883 queue:0x0b4a7698
kworker/1:0-18 [001] .... 427.356604: rtos_queue_send_from_isr_failed: tstamp:13589993176 queue:0x0b4a7698
kworker/1:0-18 [001] .... 427.356607: rtos_queue_send_from_isr_failed: tstamp:13589993284 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 427.356610: rtos_queue_send_from_isr_failed: tstamp:13589993393 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 427.356613: rtos_queue_send_from_isr_failed: tstamp:13589993502 queue:0x0b4af718
kworker/1:0-18 [001] .... 427.356651: rtos_queue_send_from_isr_failed: tstamp:13589993605 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 427.356654: rtos_queue_send_from_isr_failed: tstamp:13589993710 queue:0x0b4b1298
kworker/1:0-18 [001] .... 427.356657: rtos_queue_send_from_isr_failed: tstamp:13589993814 queue:0x0b4b2058
kworker/1:0-18 [001] .... 427.356661: rtos_queue_send_failed: tstamp:13589994390 queue:0x0b4a7698
kworker/1:0-18 [001] .... 427.356664: rtos_queue_send_from_isr_failed: tstamp:13589998581 queue:0x0b4a7698
kworker/1:0-18 [001] .... 427.356667: rtos_queue_send_from_isr_failed: tstamp:13589998687 queue:0x0b4ab1a8
kworker/1:0-18 [001] .... 427.356670: rtos_queue_send_from_isr_failed: tstamp:13589998797 queue:0x0b4acdd8
kworker/1:0-18 [001] .... 427.356673: rtos_queue_send_from_isr_failed: tstamp:13589998906 queue:0x0b4af718
kworker/1:0-18 [001] .... 427.356676: rtos_queue_send_from_isr_failed: tstamp:13589999011 queue:0x0b4b04d8
kworker/1:0-18 [001] .... 427.356679: rtos_queue_send_from_isr_failed: tstamp:13589999118 queue:0x0b4b1298
kworker/1:0-18 [001] .... 427.356682: rtos_queue_send_from_isr_failed: tstamp:13589999225 queue:0x0b4b2058
kworker/1:0-18 [001] .... 427.356686: rtos_queue_send_failed: tstamp:13589999653 queue:0x0b4a7698
v4l2-ctl-8841 [002] .... 427.404612: tegra_channel_set_stream: 150c0000.nvcsi--1 : 0x0
v4l2-ctl-8841 [002] .... 427.404620: csi_s_stream: enable : 0x0
v4l2-ctl-8841 [000] .... 427.417879: tegra_channel_set_power: imx219 0-0010 : 0x0
v4l2-ctl-8841 [000] .... 427.417898: camera_common_s_power: status : 0x0
v4l2-ctl-8841 [002] .... 427.418065: tegra_channel_set_power: 150c0000.nvcsi--1 : 0x0
v4l2-ctl-8841 [002] .... 427.418074: csi_s_power: enable : 0x0
kworker/1:0-18 [001] .... 427.468367: rtos_queue_peek_from_isr_failed: tstamp:13592175831 queue:0x0b4b4940
kworker/1:0-18 [001] .... 427.636459: rtos_queue_peek_from_isr_failed: tstamp:13597175903 queue:0x0b4b4940
kworker/1:0-18 [001] .... 427.748366: rtos_queue_peek_from_isr_failed: tstamp:13602175961 queue:0x0b4b4940
kworker/1:0-18 [001] .... 427.916437: rtos_queue_peek_from_isr_failed: tstamp:13607175893 queue:0x0b4b4940
kworker/1:0-18 [001] .... 428.084460: rtos_queue_peek_from_isr_failed: tstamp:13612175885 queue:0x0b4b4940
kworker/1:0-18 [001] .... 428.252426: rtos_queue_peek_from_isr_failed: tstamp:13617175875 queue:0x0b4b4940
kworker/1:0-18 [001] .... 428.420384: rtos_queue_peek_from_isr_failed: tstamp:13622175783 queue:0x0b4b4940
kworker/1:0-18 [001] .... 428.588435: rtos_queue_peek_from_isr_failed: tstamp:13627175861 queue:0x0b4b4940
kworker/1:0-18 [001] .... 428.756435: rtos_queue_peek_from_isr_failed: tstamp:13632175855 queue:0x0b4b4940
kworker/1:0-18 [001] .... 428.868645: rtos_queue_peek_from_isr_failed: tstamp:13637175849 queue:0x0b4b4940
kworker/1:0-18 [001] .... 429.036566: rtos_queue_peek_from_isr_failed: tstamp:13642175843 queue:0x0b4b4940
kworker/1:0-18 [001] .... 429.205069: rtos_queue_peek_from_isr_failed: tstamp:13647175842 queue:0x0b4b4940
kworker/1:0-18 [001] .... 429.372542: rtos_queue_peek_from_isr_failed: tstamp:13652175828 queue:0x0b4b4940
kworker/1:0-18 [001] .... 429.540458: rtos_queue_peek_from_isr_failed: tstamp:13657175734 queue:0x0b4b4940
kworker/1:0-18 [001] .... 429.708654: rtos_queue_peek_from_isr_failed: tstamp:13662175814 queue:0x0b4b4940
kworker/1:0-18 [001] .... 429.876553: rtos_queue_peek_from_isr_failed: tstamp:13667175807 queue:0x0b4b4940
kworker/1:0-18 [001] .... 429.988404: rtos_queue_peek_from_isr_failed: tstamp:13672175802 queue:0x0b4b4940
kworker/1:0-18 [001] .... 430.156439: rtos_queue_peek_from_isr_failed: tstamp:13677175793 queue:0x0b4b4940
kworker/1:0-18 [001] .... 430.324428: rtos_queue_peek_from_isr_failed: tstamp:13682175803 queue:0x0b4b4940
kworker/1:0-18 [001] .... 430.492664: rtos_queue_peek_from_isr_failed: tstamp:13687175781 queue:0x0b4b4940
kworker/1:0-18 [001] .... 430.660467: rtos_queue_peek_from_isr_failed: tstamp:13692175775 queue:0x0b4b4940
kworker/1:0-18 [001] .... 430.828557: rtos_queue_peek_from_isr_failed: tstamp:13697175769 queue:0x0b4b4940
kworker/1:0-18 [001] .... 430.996456: rtos_queue_peek_from_isr_failed: tstamp:13702175763 queue:0x0b4b4940
kworker/1:0-18 [001] .... 431.108492: rtos_queue_peek_from_isr_failed: tstamp:13707175755 queue:0x0b4b4940
kworker/1:0-18 [001] .... 431.276355: rtos_queue_peek_from_isr_failed: tstamp:13712175659 queue:0x0b4b4940
kworker/1:0-18 [001] .... 431.444432: rtos_queue_peek_from_isr_failed: tstamp:13717175747 queue:0x0b4b4940
kworker/1:0-18 [001] .... 431.612596: rtos_queue_peek_from_isr_failed: tstamp:13722175736 queue:0x0b4b4940
kworker/1:0-18 [001] .n.. 431.780448: rtos_queue_peek_from_isr_failed: tstamp:13727175727 queue:0x0b4b4940
kworker/1:0-18 [001] .... 431.948576: rtos_queue_peek_from_isr_failed: tstamp:13732175722 queue:0x0b4b4940
kworker/1:0-18 [001] .... 432.116366: rtos_queue_peek_from_isr_failed: tstamp:13737175626 queue:0x0b4b4940
kworker/1:0-18 [001] .... 432.228485: rtos_queue_peek_from_isr_failed: tstamp:13742175705 queue:0x0b4b4940
kworker/1:0-18 [001] .... 432.396405: rtos_queue_peek_from_isr_failed: tstamp:13747175612 queue:0x0b4b4940
kworker/1:0-18 [001] .n.. 432.564468: rtos_queue_peek_from_isr_failed: tstamp:13752175693 queue:0x0b4b4940
kworker/1:0-18 [001] .... 432.732565: rtos_queue_peek_from_isr_failed: tstamp:13757175687 queue:0x0b4b4940
Thanks, Steve
Could you verify on latest r32 release.
Hi Shane,
meanwhile I installed R32.7.4, but the result unfortunatly is the same…
Thanks for your help, Steve
P.S. Here is the trace log for R32.7.4:
# tracer: nop
# entries-in-buffer/entries-written: 724/724 #P:6
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
kworker/0:2-1876 [000] .... 553.729174: rtos_queue_peek_from_isr_failed: tstamp:17540430847 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 553.897160: rtos_queue_peek_from_isr_failed: tstamp:17545430841 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 554.065192: rtos_queue_peek_from_isr_failed: tstamp:17550430835 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 554.233192: rtos_queue_peek_from_isr_failed: tstamp:17555430827 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 554.401182: rtos_queue_peek_from_isr_failed: tstamp:17560430818 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 554.569161: rtos_queue_peek_from_isr_failed: tstamp:17565430812 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 554.681171: rtos_queue_peek_from_isr_failed: tstamp:17570430806 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 554.849161: rtos_queue_peek_from_isr_failed: tstamp:17575430802 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 555.017096: rtos_queue_peek_from_isr_failed: tstamp:17580430793 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 555.185126: rtos_queue_peek_from_isr_failed: tstamp:17585430786 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 555.353119: rtos_queue_peek_from_isr_failed: tstamp:17590430777 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 555.521114: rtos_queue_peek_from_isr_failed: tstamp:17595430776 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 555.693183: rtos_queue_peek_from_isr_failed: tstamp:17600430765 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 555.805153: rtos_queue_peek_from_isr_failed: tstamp:17605430758 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 555.973177: rtos_queue_peek_from_isr_failed: tstamp:17610430752 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 556.141159: rtos_queue_peek_from_isr_failed: tstamp:17615430746 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 556.309184: rtos_queue_peek_from_isr_failed: tstamp:17620430740 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 556.477162: rtos_queue_peek_from_isr_failed: tstamp:17625430730 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 556.645152: rtos_queue_peek_from_isr_failed: tstamp:17630430724 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 556.813166: rtos_queue_peek_from_isr_failed: tstamp:17635430718 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 556.925156: rtos_queue_peek_from_isr_failed: tstamp:17640430708 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 557.093165: rtos_queue_peek_from_isr_failed: tstamp:17645430702 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 557.261178: rtos_queue_peek_from_isr_failed: tstamp:17650430696 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 557.429189: rtos_queue_peek_from_isr_failed: tstamp:17655430690 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 557.597155: rtos_queue_peek_from_isr_failed: tstamp:17660430683 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 557.765192: rtos_queue_peek_from_isr_failed: tstamp:17665430677 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 557.933173: rtos_queue_peek_from_isr_failed: tstamp:17670430669 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 558.045161: rtos_queue_peek_from_isr_failed: tstamp:17675430661 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 558.213157: rtos_queue_peek_from_isr_failed: tstamp:17680430654 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 558.381190: rtos_queue_peek_from_isr_failed: tstamp:17685430648 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 558.549197: rtos_queue_peek_from_isr_failed: tstamp:17690430643 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 558.717155: rtos_queue_peek_from_isr_failed: tstamp:17695430636 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 558.885174: rtos_queue_peek_from_isr_failed: tstamp:17700430638 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 558.941163: rtos_queue_peek_from_isr_failed: tstamp:17703104912 queue:0x0b4b4940
v4l2-ctl-7111 [002] .... 559.577820: tegra_channel_open: vi-output, imx219 0-0010
v4l2-ctl-7111 [002] .... 559.594823: tegra_channel_set_power: imx219 0-0010 : 0x1
v4l2-ctl-7111 [002] .... 559.594871: camera_common_s_power: status : 0x1
v4l2-ctl-7111 [002] .... 559.618123: tegra_channel_set_power: 150c0000.nvcsi--1 : 0x1
v4l2-ctl-7111 [002] .... 559.618139: csi_s_power: enable : 0x1
v4l2-ctl-7111 [001] .... 559.621468: tegra_channel_capture_setup: vnc_id 0 W 3264 H 2464 fmt 20
vi-output, imx2-7112 [005] .... 559.621746: tegra_channel_set_stream: enable : 0x1
vi-output, imx2-7112 [003] .... 559.623009: tegra_channel_set_stream: 150c0000.nvcsi--1 : 0x1
vi-output, imx2-7112 [003] .... 559.623014: csi_s_stream: enable : 0x1
vi-output, imx2-7112 [003] .... 559.623093: tegra_channel_set_stream: imx219 0-0010 : 0x1
kworker/0:2-1876 [000] .... 559.669104: rtos_queue_peek_from_isr_failed: tstamp:17724836294 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 559.669109: rtcpu_start: tstamp:17724838301
kworker/0:2-1876 [000] .... 559.669111: rtos_queue_send_from_isr_failed: tstamp:17724848348 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 559.669112: rtos_queue_send_from_isr_failed: tstamp:17724848457 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 559.669113: rtos_queue_send_from_isr_failed: tstamp:17724848564 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 559.669114: rtos_queue_send_from_isr_failed: tstamp:17724848673 queue:0x0b4af718
kworker/0:2-1876 [000] .... 559.669115: rtos_queue_send_from_isr_failed: tstamp:17724848778 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 559.669115: rtos_queue_send_from_isr_failed: tstamp:17724848882 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 559.669116: rtos_queue_send_from_isr_failed: tstamp:17724848986 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 559.669118: rtos_queue_send_failed: tstamp:17724849439 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 559.669118: rtos_queue_send_from_isr_failed: tstamp:17724855966 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 559.669119: rtos_queue_send_from_isr_failed: tstamp:17724856081 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 559.669120: rtos_queue_send_from_isr_failed: tstamp:17724856189 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 559.669121: rtos_queue_send_from_isr_failed: tstamp:17724856297 queue:0x0b4af718
kworker/0:2-1876 [000] .... 559.669122: rtos_queue_send_from_isr_failed: tstamp:17724856400 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 559.669122: rtos_queue_send_from_isr_failed: tstamp:17724856505 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 559.669123: rtos_queue_send_from_isr_failed: tstamp:17724856610 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 559.669124: rtos_queue_send_failed: tstamp:17724857531 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 559.781172: rtos_queue_peek_from_isr_failed: tstamp:17729836622 queue:0x0b4b4940
vi-output, imx2-7112 [005] .... 559.866548: tegra_channel_capture_setup: vnc_id 0 W 3264 H 2464 fmt 20
vi-output, imx2-7112 [005] .... 559.866594: tegra_channel_capture_frame: sof:-549620687220.-271857166464
kworker/0:2-1876 [000] .... 559.893144: rtos_queue_send_from_isr_failed: tstamp:17732480540 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 559.893150: rtos_queue_send_from_isr_failed: tstamp:17732480648 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 559.893152: rtos_queue_send_from_isr_failed: tstamp:17732480757 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 559.893155: rtos_queue_send_from_isr_failed: tstamp:17732480864 queue:0x0b4af718
kworker/0:2-1876 [000] .... 559.893157: rtos_queue_send_from_isr_failed: tstamp:17732480968 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 559.893159: rtos_queue_send_from_isr_failed: tstamp:17732481074 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 559.893161: rtos_queue_send_from_isr_failed: tstamp:17732481178 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 559.893164: rtos_queue_send_failed: tstamp:17732481777 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 559.893166: rtos_queue_send_from_isr_failed: tstamp:17732493043 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 559.893168: rtos_queue_send_from_isr_failed: tstamp:17732493149 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 559.893171: rtos_queue_send_from_isr_failed: tstamp:17732493257 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 559.893173: rtos_queue_send_from_isr_failed: tstamp:17732493366 queue:0x0b4af718
kworker/0:2-1876 [000] .... 559.893175: rtos_queue_send_from_isr_failed: tstamp:17732493470 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 559.893177: rtos_queue_send_from_isr_failed: tstamp:17732493580 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 559.893179: rtos_queue_send_from_isr_failed: tstamp:17732493682 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 559.893182: rtos_queue_send_failed: tstamp:17732494115 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 559.893184: rtos_queue_send_from_isr_failed: tstamp:17732508095 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 559.893186: rtos_queue_send_from_isr_failed: tstamp:17732508200 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 559.893188: rtos_queue_send_from_isr_failed: tstamp:17732508305 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 559.893190: rtos_queue_send_from_isr_failed: tstamp:17732508412 queue:0x0b4af718
kworker/0:2-1876 [000] .... 559.893193: rtos_queue_send_from_isr_failed: tstamp:17732508516 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 559.893195: rtos_queue_send_from_isr_failed: tstamp:17732508621 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 559.893197: rtos_queue_send_from_isr_failed: tstamp:17732508726 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 559.893199: rtos_queue_send_failed: tstamp:17732509154 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 559.893201: rtos_queue_send_from_isr_failed: tstamp:17732514914 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 559.893203: rtos_queue_send_from_isr_failed: tstamp:17732515019 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 559.893205: rtos_queue_send_from_isr_failed: tstamp:17732515127 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 559.893208: rtos_queue_send_from_isr_failed: tstamp:17732515236 queue:0x0b4af718
kworker/0:2-1876 [000] .... 559.893210: rtos_queue_send_from_isr_failed: tstamp:17732515339 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 559.893212: rtos_queue_send_from_isr_failed: tstamp:17732515447 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 559.893214: rtos_queue_send_from_isr_failed: tstamp:17732515553 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 559.893216: rtos_queue_send_failed: tstamp:17732516477 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 559.949173: rtos_queue_peek_from_isr_failed: tstamp:17734836614 queue:0x0b4b4940
vi-output, imx2-7112 [001] .... 560.088107: tegra_channel_capture_setup: vnc_id 0 W 3264 H 2464 fmt 20
vi-output, imx2-7112 [001] .... 560.088179: tegra_channel_capture_frame: sof:-549620687220.-271857166464
kworker/0:2-1876 [000] .... 560.117159: rtos_queue_send_from_isr_failed: tstamp:17739403910 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 560.117165: rtos_queue_send_from_isr_failed: tstamp:17739404019 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 560.117167: rtos_queue_send_from_isr_failed: tstamp:17739404126 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 560.117169: rtos_queue_send_from_isr_failed: tstamp:17739404234 queue:0x0b4af718
kworker/0:2-1876 [000] .... 560.117171: rtos_queue_send_from_isr_failed: tstamp:17739404338 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 560.117173: rtos_queue_send_from_isr_failed: tstamp:17739404443 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 560.117176: rtos_queue_send_from_isr_failed: tstamp:17739404547 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 560.117178: rtos_queue_send_failed: tstamp:17739405135 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 560.117181: rtos_queue_send_from_isr_failed: tstamp:17739411139 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 560.117183: rtos_queue_send_from_isr_failed: tstamp:17739411245 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 560.117185: rtos_queue_send_from_isr_failed: tstamp:17739411362 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 560.117187: rtos_queue_send_from_isr_failed: tstamp:17739411470 queue:0x0b4af718
kworker/0:2-1876 [000] .... 560.117190: rtos_queue_send_from_isr_failed: tstamp:17739411576 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 560.117192: rtos_queue_send_from_isr_failed: tstamp:17739411680 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 560.117194: rtos_queue_send_from_isr_failed: tstamp:17739411783 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 560.117196: rtos_queue_send_failed: tstamp:17739412223 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 560.117198: rtos_queue_send_from_isr_failed: tstamp:17739430378 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 560.117200: rtos_queue_send_from_isr_failed: tstamp:17739430484 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 560.117202: rtos_queue_send_from_isr_failed: tstamp:17739430589 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 560.117205: rtos_queue_send_from_isr_failed: tstamp:17739430697 queue:0x0b4af718
kworker/0:2-1876 [000] .... 560.117207: rtos_queue_send_from_isr_failed: tstamp:17739430799 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 560.117209: rtos_queue_send_from_isr_failed: tstamp:17739430904 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 560.117211: rtos_queue_send_from_isr_failed: tstamp:17739431008 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 560.117213: rtos_queue_send_failed: tstamp:17739431442 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 560.117216: rtos_queue_send_from_isr_failed: tstamp:17739437376 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 560.117218: rtos_queue_send_from_isr_failed: tstamp:17739437481 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 560.117220: rtos_queue_send_from_isr_failed: tstamp:17739437589 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 560.117222: rtos_queue_send_from_isr_failed: tstamp:17739437696 queue:0x0b4af718
kworker/0:2-1876 [000] .... 560.117225: rtos_queue_send_from_isr_failed: tstamp:17739437801 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 560.117227: rtos_queue_send_from_isr_failed: tstamp:17739437911 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 560.117229: rtos_queue_send_from_isr_failed: tstamp:17739438015 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 560.117231: rtos_queue_send_failed: tstamp:17739438929 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 560.117234: rtos_queue_peek_from_isr_failed: tstamp:17739836606 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 560.285213: rtos_queue_peek_from_isr_failed: tstamp:17744836601 queue:0x0b4b4940
vi-output, imx2-7112 [002] .... 560.307553: tegra_channel_capture_setup: vnc_id 0 W 3264 H 2464 fmt 20
vi-output, imx2-7112 [002] .... 560.307606: tegra_channel_capture_frame: sof:-549620687220.-271857166464
kworker/0:2-1876 [000] .... 560.341187: rtos_queue_send_from_isr_failed: tstamp:17746265752 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 560.341194: rtos_queue_send_from_isr_failed: tstamp:17746265861 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 560.341197: rtos_queue_send_from_isr_failed: tstamp:17746265968 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 560.341199: rtos_queue_send_from_isr_failed: tstamp:17746266076 queue:0x0b4af718
kworker/0:2-1876 [000] .... 560.341201: rtos_queue_send_from_isr_failed: tstamp:17746266181 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 560.341203: rtos_queue_send_from_isr_failed: tstamp:17746266285 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 560.341205: rtos_queue_send_from_isr_failed: tstamp:17746266390 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 560.341208: rtos_queue_send_failed: tstamp:17746266977 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 560.341211: rtos_queue_send_from_isr_failed: tstamp:17746272751 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 560.341213: rtos_queue_send_from_isr_failed: tstamp:17746272858 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 560.341215: rtos_queue_send_from_isr_failed: tstamp:17746272964 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 560.341217: rtos_queue_send_from_isr_failed: tstamp:17746273072 queue:0x0b4af718
kworker/0:2-1876 [000] .... 560.341219: rtos_queue_send_from_isr_failed: tstamp:17746273175 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 560.341222: rtos_queue_send_from_isr_failed: tstamp:17746273280 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 560.341224: rtos_queue_send_from_isr_failed: tstamp:17746273384 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 560.341226: rtos_queue_send_failed: tstamp:17746273842 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 560.341231: rtos_queue_send_from_isr_failed: tstamp:17746290066 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 560.341233: rtos_queue_send_from_isr_failed: tstamp:17746290172 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 560.341236: rtos_queue_send_from_isr_failed: tstamp:17746290285 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 560.341238: rtos_queue_send_from_isr_failed: tstamp:17746290393 queue:0x0b4af718
kworker/0:2-1876 [000] .... 560.341240: rtos_queue_send_from_isr_failed: tstamp:17746290495 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 560.341243: rtos_queue_send_from_isr_failed: tstamp:17746290600 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 560.341245: rtos_queue_send_from_isr_failed: tstamp:17746290704 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 560.341247: rtos_queue_send_failed: tstamp:17746291142 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 560.341249: rtos_queue_send_from_isr_failed: tstamp:17746296412 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 560.341251: rtos_queue_send_from_isr_failed: tstamp:17746296518 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 560.341253: rtos_queue_send_from_isr_failed: tstamp:17746296626 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 560.341255: rtos_queue_send_from_isr_failed: tstamp:17746296733 queue:0x0b4af718
kworker/0:2-1876 [000] .... 560.341258: rtos_queue_send_from_isr_failed: tstamp:17746296837 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 560.341260: rtos_queue_send_from_isr_failed: tstamp:17746296942 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 560.341262: rtos_queue_send_from_isr_failed: tstamp:17746297050 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 560.341264: rtos_queue_send_failed: tstamp:17746297974 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 560.453155: rtos_queue_peek_from_isr_failed: tstamp:17749836595 queue:0x0b4b4940
vi-output, imx2-7112 [001] .... 560.527726: tegra_channel_capture_setup: vnc_id 0 W 3264 H 2464 fmt 20
vi-output, imx2-7112 [001] .... 560.527810: tegra_channel_capture_frame: sof:-549620687220.-271857166464
kworker/0:2-1876 [000] .... 560.565142: rtos_queue_send_from_isr_failed: tstamp:17753145004 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 560.565146: rtos_queue_send_from_isr_failed: tstamp:17753145113 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 560.565147: rtos_queue_send_from_isr_failed: tstamp:17753145221 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 560.565148: rtos_queue_send_from_isr_failed: tstamp:17753145328 queue:0x0b4af718
kworker/0:2-1876 [000] .... 560.565149: rtos_queue_send_from_isr_failed: tstamp:17753145432 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 560.565150: rtos_queue_send_from_isr_failed: tstamp:17753145536 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 560.565151: rtos_queue_send_from_isr_failed: tstamp:17753145650 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 560.565153: rtos_queue_send_failed: tstamp:17753146257 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 560.565154: rtos_queue_send_from_isr_failed: tstamp:17753153285 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 560.565155: rtos_queue_send_from_isr_failed: tstamp:17753153391 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 560.565156: rtos_queue_send_from_isr_failed: tstamp:17753153496 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 560.565156: rtos_queue_send_from_isr_failed: tstamp:17753153604 queue:0x0b4af718
kworker/0:2-1876 [000] .... 560.565157: rtos_queue_send_from_isr_failed: tstamp:17753153709 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 560.565158: rtos_queue_send_from_isr_failed: tstamp:17753153814 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 560.565159: rtos_queue_send_from_isr_failed: tstamp:17753153918 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 560.565160: rtos_queue_send_failed: tstamp:17753154352 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 560.565161: rtos_queue_send_from_isr_failed: tstamp:17753170671 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 560.565162: rtos_queue_send_from_isr_failed: tstamp:17753170777 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 560.565162: rtos_queue_send_from_isr_failed: tstamp:17753170885 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 560.565163: rtos_queue_send_from_isr_failed: tstamp:17753170991 queue:0x0b4af718
kworker/0:2-1876 [000] .... 560.565164: rtos_queue_send_from_isr_failed: tstamp:17753171096 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 560.565165: rtos_queue_send_from_isr_failed: tstamp:17753171201 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 560.565166: rtos_queue_send_from_isr_failed: tstamp:17753171306 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 560.565167: rtos_queue_send_failed: tstamp:17753171741 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 560.565168: rtos_queue_send_from_isr_failed: tstamp:17753177023 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 560.565168: rtos_queue_send_from_isr_failed: tstamp:17753177130 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 560.565169: rtos_queue_send_from_isr_failed: tstamp:17753177236 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 560.565170: rtos_queue_send_from_isr_failed: tstamp:17753177344 queue:0x0b4af718
kworker/0:2-1876 [000] .... 560.565171: rtos_queue_send_from_isr_failed: tstamp:17753177447 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 560.565172: rtos_queue_send_from_isr_failed: tstamp:17753177552 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 560.565173: rtos_queue_send_from_isr_failed: tstamp:17753177656 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 560.565174: rtos_queue_send_failed: tstamp:17753178552 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 560.621214: rtos_queue_peek_from_isr_failed: tstamp:17754836589 queue:0x0b4b4940
vi-output, imx2-7112 [002] .n.. 560.750490: tegra_channel_capture_setup: vnc_id 0 W 3264 H 2464 fmt 20
vi-output, imx2-7112 [002] .... 560.750573: tegra_channel_capture_frame: sof:-549620687220.-271857166464
kworker/0:2-1876 [000] .... 560.789199: rtos_queue_peek_from_isr_failed: tstamp:17759836579 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 560.789209: rtos_queue_send_from_isr_failed: tstamp:17760108017 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 560.789211: rtos_queue_send_from_isr_failed: tstamp:17760108126 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 560.789213: rtos_queue_send_from_isr_failed: tstamp:17760108234 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 560.789216: rtos_queue_send_from_isr_failed: tstamp:17760108352 queue:0x0b4af718
kworker/0:2-1876 [000] .... 560.789218: rtos_queue_send_from_isr_failed: tstamp:17760108457 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 560.789220: rtos_queue_send_from_isr_failed: tstamp:17760108563 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 560.789222: rtos_queue_send_from_isr_failed: tstamp:17760108667 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 560.789226: rtos_queue_send_failed: tstamp:17760109256 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 560.789228: rtos_queue_send_from_isr_failed: tstamp:17760113186 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 560.789230: rtos_queue_send_from_isr_failed: tstamp:17760113292 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 560.789232: rtos_queue_send_from_isr_failed: tstamp:17760113399 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 560.789234: rtos_queue_send_from_isr_failed: tstamp:17760113506 queue:0x0b4af718
kworker/0:2-1876 [000] .... 560.789237: rtos_queue_send_from_isr_failed: tstamp:17760113611 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 560.789239: rtos_queue_send_from_isr_failed: tstamp:17760113716 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 560.789241: rtos_queue_send_from_isr_failed: tstamp:17760113821 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 560.789243: rtos_queue_send_failed: tstamp:17760114245 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 560.789245: rtos_queue_send_from_isr_failed: tstamp:17760129682 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 560.789247: rtos_queue_send_from_isr_failed: tstamp:17760129790 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 560.789250: rtos_queue_send_from_isr_failed: tstamp:17760129896 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 560.789252: rtos_queue_send_from_isr_failed: tstamp:17760130004 queue:0x0b4af718
kworker/0:2-1876 [000] .... 560.789254: rtos_queue_send_from_isr_failed: tstamp:17760130108 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 560.789256: rtos_queue_send_from_isr_failed: tstamp:17760130214 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 560.789258: rtos_queue_send_from_isr_failed: tstamp:17760130318 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 560.789278: rtos_queue_send_failed: tstamp:17760130761 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 560.789280: rtos_queue_send_from_isr_failed: tstamp:17760137715 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 560.789282: rtos_queue_send_from_isr_failed: tstamp:17760137823 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 560.789285: rtos_queue_send_from_isr_failed: tstamp:17760137929 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 560.789287: rtos_queue_send_from_isr_failed: tstamp:17760138037 queue:0x0b4af718
kworker/0:2-1876 [000] .... 560.789289: rtos_queue_send_from_isr_failed: tstamp:17760138141 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 560.789291: rtos_queue_send_from_isr_failed: tstamp:17760138245 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 560.789293: rtos_queue_send_from_isr_failed: tstamp:17760138348 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 560.789296: rtos_queue_send_failed: tstamp:17760139269 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 560.901176: rtos_queue_peek_from_isr_failed: tstamp:17764836579 queue:0x0b4b4940
vi-output, imx2-7112 [001] .... 560.971890: tegra_channel_capture_setup: vnc_id 0 W 3264 H 2464 fmt 20
vi-output, imx2-7112 [001] .... 560.971950: tegra_channel_capture_frame: sof:-549620687220.-271857166464
kworker/0:2-1876 [000] .... 561.013168: rtos_queue_send_from_isr_failed: tstamp:17767027139 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 561.013175: rtos_queue_send_from_isr_failed: tstamp:17767027248 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 561.013178: rtos_queue_send_from_isr_failed: tstamp:17767027354 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 561.013180: rtos_queue_send_from_isr_failed: tstamp:17767027462 queue:0x0b4af718
kworker/0:2-1876 [000] .... 561.013182: rtos_queue_send_from_isr_failed: tstamp:17767027573 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 561.013184: rtos_queue_send_from_isr_failed: tstamp:17767027678 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 561.013186: rtos_queue_send_from_isr_failed: tstamp:17767027782 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 561.013189: rtos_queue_send_failed: tstamp:17767028388 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 561.013191: rtos_queue_send_from_isr_failed: tstamp:17767033257 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 561.013193: rtos_queue_send_from_isr_failed: tstamp:17767033363 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 561.013195: rtos_queue_send_from_isr_failed: tstamp:17767033468 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 561.013198: rtos_queue_send_from_isr_failed: tstamp:17767033576 queue:0x0b4af718
kworker/0:2-1876 [000] .... 561.013200: rtos_queue_send_from_isr_failed: tstamp:17767033681 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 561.013202: rtos_queue_send_from_isr_failed: tstamp:17767033785 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 561.013204: rtos_queue_send_from_isr_failed: tstamp:17767033888 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 561.013206: rtos_queue_send_failed: tstamp:17767034317 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 561.013208: rtos_queue_send_from_isr_failed: tstamp:17767049490 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 561.013210: rtos_queue_send_from_isr_failed: tstamp:17767049596 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 561.013213: rtos_queue_send_from_isr_failed: tstamp:17767049704 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 561.013215: rtos_queue_send_from_isr_failed: tstamp:17767049812 queue:0x0b4af718
kworker/0:2-1876 [000] .... 561.013217: rtos_queue_send_from_isr_failed: tstamp:17767049918 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 561.013219: rtos_queue_send_from_isr_failed: tstamp:17767050023 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 561.013222: rtos_queue_send_from_isr_failed: tstamp:17767050128 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 561.013224: rtos_queue_send_failed: tstamp:17767050570 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 561.013226: rtos_queue_send_from_isr_failed: tstamp:17767056736 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 561.013228: rtos_queue_send_from_isr_failed: tstamp:17767056842 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 561.013230: rtos_queue_send_from_isr_failed: tstamp:17767056948 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 561.013232: rtos_queue_send_from_isr_failed: tstamp:17767057056 queue:0x0b4af718
kworker/0:2-1876 [000] .... 561.013235: rtos_queue_send_from_isr_failed: tstamp:17767057160 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 561.013237: rtos_queue_send_from_isr_failed: tstamp:17767057265 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 561.013239: rtos_queue_send_from_isr_failed: tstamp:17767057370 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 561.013241: rtos_queue_send_failed: tstamp:17767058297 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 561.069168: rtos_queue_peek_from_isr_failed: tstamp:17769836567 queue:0x0b4b4940
vi-output, imx2-7112 [001] .... 561.193956: tegra_channel_capture_setup: vnc_id 0 W 3264 H 2464 fmt 20
vi-output, imx2-7112 [001] .... 561.194003: tegra_channel_capture_frame: sof:-549620687220.-271857166464
kworker/0:2-1876 [000] .... 561.237130: rtos_queue_send_from_isr_failed: tstamp:17773971348 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 561.237137: rtos_queue_send_from_isr_failed: tstamp:17773971455 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 561.237140: rtos_queue_send_from_isr_failed: tstamp:17773971564 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 561.237142: rtos_queue_send_from_isr_failed: tstamp:17773971674 queue:0x0b4af718
kworker/0:2-1876 [000] .... 561.237144: rtos_queue_send_from_isr_failed: tstamp:17773971778 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 561.237146: rtos_queue_send_from_isr_failed: tstamp:17773971883 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 561.237148: rtos_queue_send_from_isr_failed: tstamp:17773971988 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 561.237151: rtos_queue_send_failed: tstamp:17773972587 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 561.237154: rtos_queue_send_from_isr_failed: tstamp:17773979982 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 561.237156: rtos_queue_send_from_isr_failed: tstamp:17773980089 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 561.237158: rtos_queue_send_from_isr_failed: tstamp:17773980195 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 561.237160: rtos_queue_send_from_isr_failed: tstamp:17773980301 queue:0x0b4af718
kworker/0:2-1876 [000] .... 561.237162: rtos_queue_send_from_isr_failed: tstamp:17773980406 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 561.237164: rtos_queue_send_from_isr_failed: tstamp:17773980511 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 561.237167: rtos_queue_send_from_isr_failed: tstamp:17773980616 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 561.237169: rtos_queue_send_failed: tstamp:17773981053 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 561.237171: rtos_queue_send_from_isr_failed: tstamp:17773991397 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 561.237173: rtos_queue_send_from_isr_failed: tstamp:17773991503 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 561.237175: rtos_queue_send_from_isr_failed: tstamp:17773991608 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 561.237177: rtos_queue_send_from_isr_failed: tstamp:17773991721 queue:0x0b4af718
kworker/0:2-1876 [000] .... 561.237179: rtos_queue_send_from_isr_failed: tstamp:17773991825 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 561.237182: rtos_queue_send_from_isr_failed: tstamp:17773991929 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 561.237184: rtos_queue_send_from_isr_failed: tstamp:17773992032 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 561.237186: rtos_queue_send_failed: tstamp:17773992491 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 561.237188: rtos_queue_send_from_isr_failed: tstamp:17773997214 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 561.237190: rtos_queue_send_from_isr_failed: tstamp:17773997320 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 561.237193: rtos_queue_send_from_isr_failed: tstamp:17773997427 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 561.237195: rtos_queue_send_from_isr_failed: tstamp:17773997533 queue:0x0b4af718
kworker/0:2-1876 [000] .... 561.237199: rtos_queue_send_from_isr_failed: tstamp:17773997642 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 561.237202: rtos_queue_send_from_isr_failed: tstamp:17773997747 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 561.237205: rtos_queue_send_from_isr_failed: tstamp:17773997852 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 561.237207: rtos_queue_send_failed: tstamp:17773998770 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 561.237210: rtos_queue_peek_from_isr_failed: tstamp:17774836565 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 561.405127: rtos_queue_peek_from_isr_failed: tstamp:17779836552 queue:0x0b4b4940
vi-output, imx2-7112 [002] .... 561.416332: tegra_channel_capture_setup: vnc_id 0 W 3264 H 2464 fmt 20
vi-output, imx2-7112 [002] .... 561.416394: tegra_channel_capture_frame: sof:-549620687220.-271857166464
kworker/0:2-1876 [000] .... 561.461167: rtos_queue_send_from_isr_failed: tstamp:17780902740 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 561.461173: rtos_queue_send_from_isr_failed: tstamp:17780902858 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 561.461175: rtos_queue_send_from_isr_failed: tstamp:17780902967 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 561.461177: rtos_queue_send_from_isr_failed: tstamp:17780903074 queue:0x0b4af718
kworker/0:2-1876 [000] .... 561.461180: rtos_queue_send_from_isr_failed: tstamp:17780903185 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 561.461182: rtos_queue_send_from_isr_failed: tstamp:17780903288 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 561.461184: rtos_queue_send_from_isr_failed: tstamp:17780903401 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 561.461187: rtos_queue_send_failed: tstamp:17780903999 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 561.461190: rtos_queue_send_from_isr_failed: tstamp:17780919048 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 561.461192: rtos_queue_send_from_isr_failed: tstamp:17780919154 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 561.461194: rtos_queue_send_from_isr_failed: tstamp:17780919261 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 561.461196: rtos_queue_send_from_isr_failed: tstamp:17780919375 queue:0x0b4af718
kworker/0:2-1876 [000] .... 561.461198: rtos_queue_send_from_isr_failed: tstamp:17780919480 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 561.461201: rtos_queue_send_from_isr_failed: tstamp:17780919585 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 561.461203: rtos_queue_send_from_isr_failed: tstamp:17780919689 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 561.461205: rtos_queue_send_failed: tstamp:17780920109 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 561.461207: rtos_queue_send_from_isr_failed: tstamp:17780937965 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 561.461209: rtos_queue_send_from_isr_failed: tstamp:17780938074 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 561.461212: rtos_queue_send_from_isr_failed: tstamp:17780938181 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 561.461214: rtos_queue_send_from_isr_failed: tstamp:17780938288 queue:0x0b4af718
kworker/0:2-1876 [000] .... 561.461216: rtos_queue_send_from_isr_failed: tstamp:17780938393 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 561.461218: rtos_queue_send_from_isr_failed: tstamp:17780938497 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 561.461221: rtos_queue_send_from_isr_failed: tstamp:17780938601 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 561.461223: rtos_queue_send_failed: tstamp:17780939031 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 561.461225: rtos_queue_send_from_isr_failed: tstamp:17780944387 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 561.461227: rtos_queue_send_from_isr_failed: tstamp:17780944493 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 561.461229: rtos_queue_send_from_isr_failed: tstamp:17780944599 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 561.461231: rtos_queue_send_from_isr_failed: tstamp:17780944707 queue:0x0b4af718
kworker/0:2-1876 [000] .... 561.461234: rtos_queue_send_from_isr_failed: tstamp:17780944812 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 561.461236: rtos_queue_send_from_isr_failed: tstamp:17780944917 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 561.461238: rtos_queue_send_from_isr_failed: tstamp:17780945022 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 561.461240: rtos_queue_send_failed: tstamp:17780945961 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 561.573171: rtos_queue_peek_from_isr_failed: tstamp:17784836558 queue:0x0b4b4940
vi-output, imx2-7112 [001] .... 561.635477: tegra_channel_capture_setup: vnc_id 0 W 3264 H 2464 fmt 20
vi-output, imx2-7112 [001] .... 561.635531: tegra_channel_capture_frame: sof:-549620687220.-271857166464
kworker/0:2-1876 [000] .... 561.685156: rtos_queue_send_from_isr_failed: tstamp:17787765124 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 561.685162: rtos_queue_send_from_isr_failed: tstamp:17787765231 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 561.685165: rtos_queue_send_from_isr_failed: tstamp:17787765347 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 561.685167: rtos_queue_send_from_isr_failed: tstamp:17787765454 queue:0x0b4af718
kworker/0:2-1876 [000] .... 561.685169: rtos_queue_send_from_isr_failed: tstamp:17787765558 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 561.685171: rtos_queue_send_from_isr_failed: tstamp:17787765662 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 561.685173: rtos_queue_send_from_isr_failed: tstamp:17787765767 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 561.685176: rtos_queue_send_failed: tstamp:17787766363 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 561.685178: rtos_queue_send_from_isr_failed: tstamp:17787770959 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 561.685180: rtos_queue_send_from_isr_failed: tstamp:17787771065 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 561.685182: rtos_queue_send_from_isr_failed: tstamp:17787771173 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 561.685185: rtos_queue_send_from_isr_failed: tstamp:17787771280 queue:0x0b4af718
kworker/0:2-1876 [000] .... 561.685187: rtos_queue_send_from_isr_failed: tstamp:17787771384 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 561.685189: rtos_queue_send_from_isr_failed: tstamp:17787771488 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 561.685191: rtos_queue_send_from_isr_failed: tstamp:17787771593 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 561.685193: rtos_queue_send_failed: tstamp:17787772021 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 561.685196: rtos_queue_send_from_isr_failed: tstamp:17787788577 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 561.685198: rtos_queue_send_from_isr_failed: tstamp:17787788683 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 561.685200: rtos_queue_send_from_isr_failed: tstamp:17787788788 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 561.685202: rtos_queue_send_from_isr_failed: tstamp:17787788896 queue:0x0b4af718
kworker/0:2-1876 [000] .... 561.685204: rtos_queue_send_from_isr_failed: tstamp:17787789001 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 561.685206: rtos_queue_send_from_isr_failed: tstamp:17787789106 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 561.685209: rtos_queue_send_from_isr_failed: tstamp:17787789210 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 561.685211: rtos_queue_send_failed: tstamp:17787789644 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 561.685213: rtos_queue_send_from_isr_failed: tstamp:17787794101 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 561.685215: rtos_queue_send_from_isr_failed: tstamp:17787794206 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 561.685217: rtos_queue_send_from_isr_failed: tstamp:17787794311 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 561.685219: rtos_queue_send_from_isr_failed: tstamp:17787794418 queue:0x0b4af718
kworker/0:2-1876 [000] .... 561.685222: rtos_queue_send_from_isr_failed: tstamp:17787794522 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 561.685224: rtos_queue_send_from_isr_failed: tstamp:17787794626 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 561.685226: rtos_queue_send_from_isr_failed: tstamp:17787794731 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 561.685228: rtos_queue_send_failed: tstamp:17787795644 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 561.741131: rtos_queue_peek_from_isr_failed: tstamp:17789836551 queue:0x0b4b4940
vi-output, imx2-7112 [002] .... 561.856534: tegra_channel_capture_setup: vnc_id 0 W 3264 H 2464 fmt 20
vi-output, imx2-7112 [002] .... 561.856597: tegra_channel_capture_frame: sof:-549620687220.-271857166464
kworker/0:2-1876 [000] .... 561.909163: rtos_queue_send_from_isr_failed: tstamp:17794662501 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 561.909170: rtos_queue_send_from_isr_failed: tstamp:17794662610 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 561.909172: rtos_queue_send_from_isr_failed: tstamp:17794662718 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 561.909175: rtos_queue_send_from_isr_failed: tstamp:17794662825 queue:0x0b4af718
kworker/0:2-1876 [000] .... 561.909177: rtos_queue_send_from_isr_failed: tstamp:17794662938 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 561.909179: rtos_queue_send_from_isr_failed: tstamp:17794663043 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 561.909181: rtos_queue_send_from_isr_failed: tstamp:17794663148 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 561.909184: rtos_queue_send_failed: tstamp:17794663747 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 561.909261: rtos_queue_send_from_isr_failed: tstamp:17794675342 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 561.909263: rtos_queue_send_from_isr_failed: tstamp:17794675449 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 561.909265: rtos_queue_send_from_isr_failed: tstamp:17794675554 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 561.909267: rtos_queue_send_from_isr_failed: tstamp:17794675661 queue:0x0b4af718
kworker/0:2-1876 [000] .... 561.909269: rtos_queue_send_from_isr_failed: tstamp:17794675766 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 561.909272: rtos_queue_send_from_isr_failed: tstamp:17794675871 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 561.909274: rtos_queue_send_from_isr_failed: tstamp:17794675975 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 561.909276: rtos_queue_send_failed: tstamp:17794676395 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 561.909278: rtos_queue_send_from_isr_failed: tstamp:17794692429 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 561.909281: rtos_queue_send_from_isr_failed: tstamp:17794692534 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 561.909283: rtos_queue_send_from_isr_failed: tstamp:17794692641 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 561.909285: rtos_queue_send_from_isr_failed: tstamp:17794692749 queue:0x0b4af718
kworker/0:2-1876 [000] .... 561.909287: rtos_queue_send_from_isr_failed: tstamp:17794692854 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 561.909289: rtos_queue_send_from_isr_failed: tstamp:17794692958 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 561.909292: rtos_queue_send_from_isr_failed: tstamp:17794693063 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 561.909294: rtos_queue_send_failed: tstamp:17794693495 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 561.909296: rtos_queue_send_from_isr_failed: tstamp:17794701053 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 561.909298: rtos_queue_send_from_isr_failed: tstamp:17794701159 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 561.909300: rtos_queue_send_from_isr_failed: tstamp:17794701264 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 561.909302: rtos_queue_send_from_isr_failed: tstamp:17794701372 queue:0x0b4af718
kworker/0:2-1876 [000] .... 561.909305: rtos_queue_send_from_isr_failed: tstamp:17794701477 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 561.909307: rtos_queue_send_from_isr_failed: tstamp:17794701591 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 561.909309: rtos_queue_send_from_isr_failed: tstamp:17794701695 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 561.909311: rtos_queue_send_failed: tstamp:17794702623 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 561.909314: rtos_queue_peek_from_isr_failed: tstamp:17794836538 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 562.021158: rtos_queue_peek_from_isr_failed: tstamp:17799836526 queue:0x0b4b4940
vi-output, imx2-7112 [001] .... 562.075537: tegra_channel_capture_setup: vnc_id 0 W 3264 H 2464 fmt 20
vi-output, imx2-7112 [001] .... 562.075591: tegra_channel_capture_frame: sof:-549620687220.-271857166464
kworker/0:2-1876 [000] .... 562.077109: rtos_queue_send_from_isr_failed: tstamp:17801521345 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 562.077114: rtos_queue_send_from_isr_failed: tstamp:17801521454 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 562.077116: rtos_queue_send_from_isr_failed: tstamp:17801521562 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 562.077119: rtos_queue_send_from_isr_failed: tstamp:17801521668 queue:0x0b4af718
kworker/0:2-1876 [000] .... 562.077121: rtos_queue_send_from_isr_failed: tstamp:17801521772 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 562.077123: rtos_queue_send_from_isr_failed: tstamp:17801521877 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 562.077125: rtos_queue_send_from_isr_failed: tstamp:17801521981 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 562.077128: rtos_queue_send_failed: tstamp:17801522569 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 562.077130: rtos_queue_send_from_isr_failed: tstamp:17801526549 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 562.077132: rtos_queue_send_from_isr_failed: tstamp:17801526654 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 562.077134: rtos_queue_send_from_isr_failed: tstamp:17801526761 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 562.077136: rtos_queue_send_from_isr_failed: tstamp:17801526869 queue:0x0b4af718
kworker/0:2-1876 [000] .... 562.077139: rtos_queue_send_from_isr_failed: tstamp:17801526974 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 562.077141: rtos_queue_send_from_isr_failed: tstamp:17801527081 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 562.077143: rtos_queue_send_from_isr_failed: tstamp:17801527184 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 562.077145: rtos_queue_send_failed: tstamp:17801527608 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 562.077148: rtos_queue_send_from_isr_failed: tstamp:17801540107 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 562.077150: rtos_queue_send_from_isr_failed: tstamp:17801540213 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 562.077152: rtos_queue_send_from_isr_failed: tstamp:17801540318 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 562.077154: rtos_queue_send_from_isr_failed: tstamp:17801540428 queue:0x0b4af718
kworker/0:2-1876 [000] .... 562.077157: rtos_queue_send_from_isr_failed: tstamp:17801540534 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 562.077159: rtos_queue_send_from_isr_failed: tstamp:17801540637 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 562.077161: rtos_queue_send_from_isr_failed: tstamp:17801540741 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 562.077163: rtos_queue_send_failed: tstamp:17801541169 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 562.077165: rtos_queue_send_from_isr_failed: tstamp:17801546321 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 562.077167: rtos_queue_send_from_isr_failed: tstamp:17801546426 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 562.077170: rtos_queue_send_from_isr_failed: tstamp:17801546531 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 562.077172: rtos_queue_send_from_isr_failed: tstamp:17801546638 queue:0x0b4af718
kworker/0:2-1876 [000] .... 562.077174: rtos_queue_send_from_isr_failed: tstamp:17801546751 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 562.077176: rtos_queue_send_from_isr_failed: tstamp:17801546865 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 562.077179: rtos_queue_send_from_isr_failed: tstamp:17801546970 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 562.077181: rtos_queue_send_failed: tstamp:17801547873 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 562.189163: rtos_queue_peek_from_isr_failed: tstamp:17804836518 queue:0x0b4b4940
vi-output, imx2-7112 [001] .... 562.298725: tegra_channel_capture_setup: vnc_id 0 W 3264 H 2464 fmt 20
vi-output, imx2-7112 [001] .... 562.298813: tegra_channel_capture_frame: sof:-549620687220.-271857166464
kworker/0:2-1876 [000] .... 562.301168: rtos_queue_send_from_isr_failed: tstamp:17808479470 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 562.301176: rtos_queue_send_from_isr_failed: tstamp:17808479588 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 562.301179: rtos_queue_send_from_isr_failed: tstamp:17808479695 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 562.301181: rtos_queue_send_from_isr_failed: tstamp:17808479803 queue:0x0b4af718
kworker/0:2-1876 [000] .... 562.301183: rtos_queue_send_from_isr_failed: tstamp:17808479908 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 562.301185: rtos_queue_send_from_isr_failed: tstamp:17808480013 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 562.301190: rtos_queue_send_from_isr_failed: tstamp:17808480118 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 562.301193: rtos_queue_send_failed: tstamp:17808480730 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 562.301195: rtos_queue_send_from_isr_failed: tstamp:17808487455 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 562.301198: rtos_queue_send_from_isr_failed: tstamp:17808487561 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 562.301200: rtos_queue_send_from_isr_failed: tstamp:17808487668 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 562.301202: rtos_queue_send_from_isr_failed: tstamp:17808487775 queue:0x0b4af718
kworker/0:2-1876 [000] .... 562.301204: rtos_queue_send_from_isr_failed: tstamp:17808487881 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 562.301207: rtos_queue_send_from_isr_failed: tstamp:17808487985 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 562.301209: rtos_queue_send_from_isr_failed: tstamp:17808488090 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 562.301211: rtos_queue_send_failed: tstamp:17808488510 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 562.301213: rtos_queue_send_from_isr_failed: tstamp:17808509746 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 562.301215: rtos_queue_send_from_isr_failed: tstamp:17808509851 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 562.301218: rtos_queue_send_from_isr_failed: tstamp:17808509959 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 562.301220: rtos_queue_send_from_isr_failed: tstamp:17808510066 queue:0x0b4af718
kworker/0:2-1876 [000] .... 562.301222: rtos_queue_send_from_isr_failed: tstamp:17808510170 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 562.301224: rtos_queue_send_from_isr_failed: tstamp:17808510275 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 562.301226: rtos_queue_send_from_isr_failed: tstamp:17808510380 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 562.301228: rtos_queue_send_failed: tstamp:17808510811 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 562.301231: rtos_queue_send_from_isr_failed: tstamp:17808519212 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 562.301233: rtos_queue_send_from_isr_failed: tstamp:17808519320 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 562.301235: rtos_queue_send_from_isr_failed: tstamp:17808519427 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 562.301237: rtos_queue_send_from_isr_failed: tstamp:17808519535 queue:0x0b4af718
kworker/0:2-1876 [000] .... 562.301239: rtos_queue_send_from_isr_failed: tstamp:17808519642 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 562.301241: rtos_queue_send_from_isr_failed: tstamp:17808519746 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 562.301244: rtos_queue_send_from_isr_failed: tstamp:17808519850 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 562.301246: rtos_queue_send_failed: tstamp:17808520771 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 562.357176: rtos_queue_peek_from_isr_failed: tstamp:17809836513 queue:0x0b4b4940
vi-output, imx2-7112 [001] .... 562.521919: tegra_channel_capture_setup: vnc_id 0 W 3264 H 2464 fmt 20
vi-output, imx2-7112 [001] .... 562.521985: tegra_channel_capture_frame: sof:-549620687220.-271857166464
kworker/0:2-1876 [000] .... 562.529131: rtos_queue_peek_from_isr_failed: tstamp:17814836506 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 562.529138: rtos_queue_send_from_isr_failed: tstamp:17815469954 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 562.529141: rtos_queue_send_from_isr_failed: tstamp:17815470062 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 562.529143: rtos_queue_send_from_isr_failed: tstamp:17815470170 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 562.529146: rtos_queue_send_from_isr_failed: tstamp:17815470276 queue:0x0b4af718
kworker/0:2-1876 [000] .... 562.529148: rtos_queue_send_from_isr_failed: tstamp:17815470380 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 562.529150: rtos_queue_send_from_isr_failed: tstamp:17815470485 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 562.529152: rtos_queue_send_from_isr_failed: tstamp:17815470590 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 562.529156: rtos_queue_send_failed: tstamp:17815471184 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 562.529158: rtos_queue_send_from_isr_failed: tstamp:17815477146 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 562.529160: rtos_queue_send_from_isr_failed: tstamp:17815477252 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 562.529162: rtos_queue_send_from_isr_failed: tstamp:17815477360 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 562.529165: rtos_queue_send_from_isr_failed: tstamp:17815477469 queue:0x0b4af718
kworker/0:2-1876 [000] .... 562.529167: rtos_queue_send_from_isr_failed: tstamp:17815477573 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 562.529169: rtos_queue_send_from_isr_failed: tstamp:17815477676 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 562.529171: rtos_queue_send_from_isr_failed: tstamp:17815477781 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 562.529173: rtos_queue_send_failed: tstamp:17815478201 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 562.529175: rtos_queue_send_from_isr_failed: tstamp:17815489398 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 562.529178: rtos_queue_send_from_isr_failed: tstamp:17815489505 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 562.529180: rtos_queue_send_from_isr_failed: tstamp:17815489611 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 562.529182: rtos_queue_send_from_isr_failed: tstamp:17815489717 queue:0x0b4af718
kworker/0:2-1876 [000] .... 562.529184: rtos_queue_send_from_isr_failed: tstamp:17815489822 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 562.529186: rtos_queue_send_from_isr_failed: tstamp:17815489927 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 562.529189: rtos_queue_send_from_isr_failed: tstamp:17815490032 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 562.529191: rtos_queue_send_failed: tstamp:17815490463 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 562.529193: rtos_queue_send_from_isr_failed: tstamp:17815495691 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 562.529195: rtos_queue_send_from_isr_failed: tstamp:17815495796 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 562.529197: rtos_queue_send_from_isr_failed: tstamp:17815495911 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 562.529200: rtos_queue_send_from_isr_failed: tstamp:17815496019 queue:0x0b4af718
kworker/0:2-1876 [000] .... 562.529202: rtos_queue_send_from_isr_failed: tstamp:17815496124 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 562.529204: rtos_queue_send_from_isr_failed: tstamp:17815496229 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 562.529206: rtos_queue_send_from_isr_failed: tstamp:17815496334 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 562.529208: rtos_queue_send_failed: tstamp:17815497252 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 562.697161: rtos_queue_peek_from_isr_failed: tstamp:17819836498 queue:0x0b4b4940
vi-output, imx2-7112 [002] .... 562.745479: tegra_channel_capture_setup: vnc_id 0 W 3264 H 2464 fmt 20
vi-output, imx2-7112 [002] .... 562.745541: tegra_channel_capture_frame: sof:-549620687220.-271857166464
kworker/0:2-1876 [000] .... 562.753128: rtos_queue_send_from_isr_failed: tstamp:17822447310 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 562.753133: rtos_queue_send_from_isr_failed: tstamp:17822447419 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 562.753135: rtos_queue_send_from_isr_failed: tstamp:17822447527 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 562.753137: rtos_queue_send_from_isr_failed: tstamp:17822447634 queue:0x0b4af718
kworker/0:2-1876 [000] .... 562.753139: rtos_queue_send_from_isr_failed: tstamp:17822447739 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 562.753142: rtos_queue_send_from_isr_failed: tstamp:17822447843 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 562.753144: rtos_queue_send_from_isr_failed: tstamp:17822447947 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 562.753146: rtos_queue_send_failed: tstamp:17822448543 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 562.753149: rtos_queue_send_from_isr_failed: tstamp:17822456645 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 562.753151: rtos_queue_send_from_isr_failed: tstamp:17822456754 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 562.753153: rtos_queue_send_from_isr_failed: tstamp:17822456859 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 562.753155: rtos_queue_send_from_isr_failed: tstamp:17822456967 queue:0x0b4af718
kworker/0:2-1876 [000] .... 562.753157: rtos_queue_send_from_isr_failed: tstamp:17822457070 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 562.753159: rtos_queue_send_from_isr_failed: tstamp:17822457175 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 562.753162: rtos_queue_send_from_isr_failed: tstamp:17822457280 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 562.753164: rtos_queue_send_failed: tstamp:17822457704 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 562.753166: rtos_queue_send_from_isr_failed: tstamp:17822472887 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 562.753168: rtos_queue_send_from_isr_failed: tstamp:17822472995 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 562.753170: rtos_queue_send_from_isr_failed: tstamp:17822473101 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 562.753173: rtos_queue_send_from_isr_failed: tstamp:17822473209 queue:0x0b4af718
kworker/0:2-1876 [000] .... 562.753175: rtos_queue_send_from_isr_failed: tstamp:17822473314 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 562.753177: rtos_queue_send_from_isr_failed: tstamp:17822473418 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 562.753179: rtos_queue_send_from_isr_failed: tstamp:17822473521 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 562.753181: rtos_queue_send_failed: tstamp:17822473952 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 562.753183: rtos_queue_send_from_isr_failed: tstamp:17822480774 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 562.753186: rtos_queue_send_from_isr_failed: tstamp:17822480880 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 562.753188: rtos_queue_send_from_isr_failed: tstamp:17822480986 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 562.753190: rtos_queue_send_from_isr_failed: tstamp:17822481094 queue:0x0b4af718
kworker/0:2-1876 [000] .... 562.753192: rtos_queue_send_from_isr_failed: tstamp:17822481199 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 562.753194: rtos_queue_send_from_isr_failed: tstamp:17822481309 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 562.753196: rtos_queue_send_from_isr_failed: tstamp:17822481414 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 562.753199: rtos_queue_send_failed: tstamp:17822482331 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 562.865183: rtos_queue_peek_from_isr_failed: tstamp:17824836492 queue:0x0b4b4940
vi-output, imx2-7112 [001] .... 562.967651: tegra_channel_capture_setup: vnc_id 0 W 3264 H 2464 fmt 20
vi-output, imx2-7112 [001] .... 562.967704: tegra_channel_capture_frame: sof:-549620687220.-271857166464
kworker/0:2-1876 [000] .... 562.977125: rtos_queue_send_from_isr_failed: tstamp:17829376868 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 562.977130: rtos_queue_send_from_isr_failed: tstamp:17829376978 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 562.977133: rtos_queue_send_from_isr_failed: tstamp:17829377085 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 562.977135: rtos_queue_send_from_isr_failed: tstamp:17829377194 queue:0x0b4af718
kworker/0:2-1876 [000] .... 562.977137: rtos_queue_send_from_isr_failed: tstamp:17829377299 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 562.977139: rtos_queue_send_from_isr_failed: tstamp:17829377404 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 562.977141: rtos_queue_send_from_isr_failed: tstamp:17829377509 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 562.977144: rtos_queue_send_failed: tstamp:17829378102 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 562.977147: rtos_queue_send_from_isr_failed: tstamp:17829383766 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 562.977149: rtos_queue_send_from_isr_failed: tstamp:17829383872 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 562.977151: rtos_queue_send_from_isr_failed: tstamp:17829383977 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 562.977153: rtos_queue_send_from_isr_failed: tstamp:17829384085 queue:0x0b4af718
kworker/0:2-1876 [000] .... 562.977155: rtos_queue_send_from_isr_failed: tstamp:17829384194 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 562.977157: rtos_queue_send_from_isr_failed: tstamp:17829384299 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 562.977160: rtos_queue_send_from_isr_failed: tstamp:17829384404 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 562.977162: rtos_queue_send_failed: tstamp:17829384822 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 562.977164: rtos_queue_send_from_isr_failed: tstamp:17829396799 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 562.977166: rtos_queue_send_from_isr_failed: tstamp:17829396905 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 562.977168: rtos_queue_send_from_isr_failed: tstamp:17829397010 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 562.977171: rtos_queue_send_from_isr_failed: tstamp:17829397123 queue:0x0b4af718
kworker/0:2-1876 [000] .... 562.977173: rtos_queue_send_from_isr_failed: tstamp:17829397227 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 562.977175: rtos_queue_send_from_isr_failed: tstamp:17829397330 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 562.977177: rtos_queue_send_from_isr_failed: tstamp:17829397434 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 562.977179: rtos_queue_send_failed: tstamp:17829397862 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 562.977182: rtos_queue_send_from_isr_failed: tstamp:17829424798 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 562.977184: rtos_queue_send_from_isr_failed: tstamp:17829424903 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 562.977186: rtos_queue_send_from_isr_failed: tstamp:17829425009 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 562.977188: rtos_queue_send_from_isr_failed: tstamp:17829425116 queue:0x0b4af718
kworker/0:2-1876 [000] .... 562.977190: rtos_queue_send_from_isr_failed: tstamp:17829425221 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 562.977193: rtos_queue_send_from_isr_failed: tstamp:17829425325 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 562.977195: rtos_queue_send_from_isr_failed: tstamp:17829425428 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 562.977197: rtos_queue_send_failed: tstamp:17829426341 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 563.033173: rtos_queue_peek_from_isr_failed: tstamp:17829836490 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 563.145159: rtos_queue_peek_from_isr_failed: tstamp:17834836477 queue:0x0b4b4940
vi-output, imx2-7112 [005] .... 563.189975: tegra_channel_capture_setup: vnc_id 0 W 3264 H 2464 fmt 20
vi-output, imx2-7112 [005] .... 563.190020: tegra_channel_capture_frame: sof:-549620687220.-271857166464
v4l2-ctl-7111 [001] .... 563.195462: tegra_channel_close: vi-output, imx219 0-0010
kworker/0:2-1876 [000] .... 563.201096: rtos_queue_send_from_isr_failed: tstamp:17836278590 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 563.201100: rtos_queue_send_from_isr_failed: tstamp:17836278699 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 563.201100: rtos_queue_send_from_isr_failed: tstamp:17836278807 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 563.201101: rtos_queue_send_from_isr_failed: tstamp:17836278913 queue:0x0b4af718
kworker/0:2-1876 [000] .... 563.201102: rtos_queue_send_from_isr_failed: tstamp:17836279018 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 563.201103: rtos_queue_send_from_isr_failed: tstamp:17836279123 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 563.201104: rtos_queue_send_from_isr_failed: tstamp:17836279227 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 563.201106: rtos_queue_send_failed: tstamp:17836279834 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 563.201106: rtos_queue_send_from_isr_failed: tstamp:17836342444 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 563.201107: rtos_queue_send_from_isr_failed: tstamp:17836342552 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 563.201108: rtos_queue_send_from_isr_failed: tstamp:17836342658 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 563.201109: rtos_queue_send_from_isr_failed: tstamp:17836342766 queue:0x0b4af718
kworker/0:2-1876 [000] .... 563.201110: rtos_queue_send_from_isr_failed: tstamp:17836342871 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 563.201110: rtos_queue_send_from_isr_failed: tstamp:17836342974 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 563.201111: rtos_queue_send_from_isr_failed: tstamp:17836343078 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 563.201112: rtos_queue_send_failed: tstamp:17836343504 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 563.201113: rtos_queue_send_from_isr_failed: tstamp:17836361538 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 563.201115: rtos_queue_send_from_isr_failed: tstamp:17836361644 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 563.201115: rtos_queue_send_from_isr_failed: tstamp:17836361749 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 563.201116: rtos_queue_send_from_isr_failed: tstamp:17836361857 queue:0x0b4af718
kworker/0:2-1876 [000] .... 563.201117: rtos_queue_send_from_isr_failed: tstamp:17836361962 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 563.201118: rtos_queue_send_from_isr_failed: tstamp:17836362076 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 563.201119: rtos_queue_send_from_isr_failed: tstamp:17836362182 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 563.201120: rtos_queue_send_failed: tstamp:17836362609 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 563.201120: rtos_queue_send_from_isr_failed: tstamp:17836369746 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 563.201121: rtos_queue_send_from_isr_failed: tstamp:17836369852 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 563.201122: rtos_queue_send_from_isr_failed: tstamp:17836369957 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 563.201123: rtos_queue_send_from_isr_failed: tstamp:17836370065 queue:0x0b4af718
kworker/0:2-1876 [000] .... 563.201124: rtos_queue_send_from_isr_failed: tstamp:17836370170 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 563.201124: rtos_queue_send_from_isr_failed: tstamp:17836370275 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 563.201125: rtos_queue_send_from_isr_failed: tstamp:17836370380 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 563.201126: rtos_queue_send_failed: tstamp:17836371299 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 563.313192: rtos_queue_peek_from_isr_failed: tstamp:17839836478 queue:0x0b4b4940
vi-output, imx2-7112 [002] .... 563.411826: tegra_channel_capture_setup: vnc_id 0 W 3264 H 2464 fmt 20
vi-output, imx2-7112 [002] .... 563.411880: tegra_channel_capture_frame: sof:-549620687220.-271857166464
v4l2-ctl-7111 [002] .... 563.417494: tegra_channel_set_stream: enable : 0x0
v4l2-ctl-7111 [002] .... 563.417500: tegra_channel_set_stream: imx219 0-0010 : 0x0
kworker/0:2-1876 [000] .... 563.425143: rtos_queue_send_from_isr_failed: tstamp:17843269472 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 563.425150: rtos_queue_send_from_isr_failed: tstamp:17843269579 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 563.425152: rtos_queue_send_from_isr_failed: tstamp:17843269687 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 563.425155: rtos_queue_send_from_isr_failed: tstamp:17843269795 queue:0x0b4af718
kworker/0:2-1876 [000] .... 563.425157: rtos_queue_send_from_isr_failed: tstamp:17843269898 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 563.425159: rtos_queue_send_from_isr_failed: tstamp:17843270006 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 563.425162: rtos_queue_send_from_isr_failed: tstamp:17843270111 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 563.425165: rtos_queue_send_failed: tstamp:17843270697 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 563.425167: rtos_queue_send_from_isr_failed: tstamp:17843282410 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 563.425169: rtos_queue_send_from_isr_failed: tstamp:17843282516 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 563.425172: rtos_queue_send_from_isr_failed: tstamp:17843282628 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 563.425174: rtos_queue_send_from_isr_failed: tstamp:17843282735 queue:0x0b4af718
kworker/0:2-1876 [000] .... 563.425176: rtos_queue_send_from_isr_failed: tstamp:17843282839 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 563.425178: rtos_queue_send_from_isr_failed: tstamp:17843282944 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 563.425180: rtos_queue_send_from_isr_failed: tstamp:17843283048 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 563.425182: rtos_queue_send_failed: tstamp:17843283477 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 563.425185: rtos_queue_send_from_isr_failed: tstamp:17843297598 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 563.425187: rtos_queue_send_from_isr_failed: tstamp:17843297704 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 563.425189: rtos_queue_send_from_isr_failed: tstamp:17843297811 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 563.425191: rtos_queue_send_from_isr_failed: tstamp:17843297917 queue:0x0b4af718
kworker/0:2-1876 [000] .... 563.425193: rtos_queue_send_from_isr_failed: tstamp:17843298021 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 563.425196: rtos_queue_send_from_isr_failed: tstamp:17843298136 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 563.425198: rtos_queue_send_from_isr_failed: tstamp:17843298241 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 563.425200: rtos_queue_send_failed: tstamp:17843298678 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 563.425202: rtos_queue_send_from_isr_failed: tstamp:17843305090 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 563.425205: rtos_queue_send_from_isr_failed: tstamp:17843305198 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 563.425207: rtos_queue_send_from_isr_failed: tstamp:17843305304 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 563.425209: rtos_queue_send_from_isr_failed: tstamp:17843305412 queue:0x0b4af718
kworker/0:2-1876 [000] .... 563.425211: rtos_queue_send_from_isr_failed: tstamp:17843305517 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 563.425213: rtos_queue_send_from_isr_failed: tstamp:17843305622 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 563.425216: rtos_queue_send_from_isr_failed: tstamp:17843305726 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 563.425218: rtos_queue_send_failed: tstamp:17843306662 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 563.425220: rtos_queue_send_from_isr_failed: tstamp:17843354381 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 563.425222: rtos_queue_send_from_isr_failed: tstamp:17843354486 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 563.425224: rtos_queue_send_from_isr_failed: tstamp:17843354592 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 563.425226: rtos_queue_send_from_isr_failed: tstamp:17843354699 queue:0x0b4af718
kworker/0:2-1876 [000] .... 563.425229: rtos_queue_send_from_isr_failed: tstamp:17843354802 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 563.425231: rtos_queue_send_from_isr_failed: tstamp:17843354909 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 563.425233: rtos_queue_send_from_isr_failed: tstamp:17843355014 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 563.425235: rtos_queue_send_failed: tstamp:17843355575 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 563.425237: rtos_queue_send_from_isr_failed: tstamp:17843481394 queue:0x0b4a7698
kworker/0:2-1876 [000] .... 563.425239: rtos_queue_send_from_isr_failed: tstamp:17843481500 queue:0x0b4ab1a8
kworker/0:2-1876 [000] .... 563.425242: rtos_queue_send_from_isr_failed: tstamp:17843481605 queue:0x0b4acdd8
kworker/0:2-1876 [000] .... 563.425244: rtos_queue_send_from_isr_failed: tstamp:17843481714 queue:0x0b4af718
kworker/0:2-1876 [000] .... 563.425246: rtos_queue_send_from_isr_failed: tstamp:17843481818 queue:0x0b4b04d8
kworker/0:2-1876 [000] .... 563.425248: rtos_queue_send_from_isr_failed: tstamp:17843481923 queue:0x0b4b1298
kworker/0:2-1876 [000] .... 563.425250: rtos_queue_send_from_isr_failed: tstamp:17843482028 queue:0x0b4b2058
kworker/0:2-1876 [000] .... 563.425252: rtos_queue_send_failed: tstamp:17843482456 queue:0x0b4a7698
v4l2-ctl-7111 [002] .... 563.468768: tegra_channel_set_stream: 150c0000.nvcsi--1 : 0x0
v4l2-ctl-7111 [002] .... 563.468778: csi_s_stream: enable : 0x0
v4l2-ctl-7111 [004] .... 563.470639: tegra_channel_set_power: imx219 0-0010 : 0x0
v4l2-ctl-7111 [004] .... 563.470675: camera_common_s_power: status : 0x0
v4l2-ctl-7111 [004] .... 563.470794: tegra_channel_set_power: 150c0000.nvcsi--1 : 0x0
v4l2-ctl-7111 [004] .... 563.470799: csi_s_power: enable : 0x0
kworker/0:2-1876 [000] .... 563.485135: rtos_queue_peek_from_isr_failed: tstamp:17844836467 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 563.653174: rtos_queue_peek_from_isr_failed: tstamp:17849836456 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 563.821185: rtos_queue_peek_from_isr_failed: tstamp:17854836448 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 563.989086: rtos_queue_peek_from_isr_failed: tstamp:17859836441 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 564.101171: rtos_queue_peek_from_isr_failed: tstamp:17864836436 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 564.269194: rtos_queue_peek_from_isr_failed: tstamp:17869836430 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 564.437181: rtos_queue_peek_from_isr_failed: tstamp:17874836422 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 564.605134: rtos_queue_peek_from_isr_failed: tstamp:17879836415 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 564.773176: rtos_queue_peek_from_isr_failed: tstamp:17884836407 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 564.941169: rtos_queue_peek_from_isr_failed: tstamp:17889836401 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 565.109167: rtos_queue_peek_from_isr_failed: tstamp:17894836395 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 565.221171: rtos_queue_peek_from_isr_failed: tstamp:17899836389 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 565.393208: rtos_queue_peek_from_isr_failed: tstamp:17904836381 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 565.561173: rtos_queue_peek_from_isr_failed: tstamp:17909836376 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 565.729144: rtos_queue_peek_from_isr_failed: tstamp:17914836366 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 565.901174: rtos_queue_peek_from_isr_failed: tstamp:17919836364 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 566.069154: rtos_queue_peek_from_isr_failed: tstamp:17924836353 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 566.181165: rtos_queue_peek_from_isr_failed: tstamp:17929836348 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 566.349166: rtos_queue_peek_from_isr_failed: tstamp:17934836340 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 566.521194: rtos_queue_peek_from_isr_failed: tstamp:17939836332 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 566.689169: rtos_queue_peek_from_isr_failed: tstamp:17944836325 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 566.857161: rtos_queue_peek_from_isr_failed: tstamp:17949836322 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 567.025178: rtos_queue_peek_from_isr_failed: tstamp:17954836313 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 567.193159: rtos_queue_peek_from_isr_failed: tstamp:17959836306 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 567.305200: rtos_queue_peek_from_isr_failed: tstamp:17964836299 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 567.473169: rtos_queue_peek_from_isr_failed: tstamp:17969836292 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 567.641166: rtos_queue_peek_from_isr_failed: tstamp:17974836285 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 567.809154: rtos_queue_peek_from_isr_failed: tstamp:17979836279 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 567.977160: rtos_queue_peek_from_isr_failed: tstamp:17984836272 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 568.145156: rtos_queue_peek_from_isr_failed: tstamp:17989836265 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 568.313157: rtos_queue_peek_from_isr_failed: tstamp:17994836258 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 568.425175: rtos_queue_peek_from_isr_failed: tstamp:17999836251 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 568.593170: rtos_queue_peek_from_isr_failed: tstamp:18004836244 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 568.761141: rtos_queue_peek_from_isr_failed: tstamp:18009836238 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 568.929113: rtos_queue_peek_from_isr_failed: tstamp:18014836232 queue:0x0b4b4940
kworker/0:2-1876 [000] .... 568.929118: rtos_queue_peek_from_isr_failed: tstamp:18015102825 queue:0x0b4b4940
Do you have any customized for the sensor driver.
I just confirm the v4l2-ctl for imx219 on TX2-NX working without problem.
Hi Shane,
yeah, its customized. The carrier board (Auvidea-JNX30D) is by Auvidea. They support this board in two configurations: one with a Jetson Xavier NX and one with a Jetson TX2 NX. According to them the imx219 is only tested with the Xavier NX board variant. Therefore I created my own DTS based on their description of the hardware changes and modified tegra186-camera-lanai-rbpcv2-imx219.dts and tegra186-camera-rbpcv2-imx219.dts in platform/t18x/lainai/kernel-dts/common. The main diffence to the nvidia reference is that they have cameras connected to two i2c busses (@0x31600000 and @0x31800000 ) instead of one bus with a i2cmux in between (like the nvidia reference does).
But I2C-access is not a problem since the camera is working perfectly with Argus.
Do you have some tips on what to specifically have a look in the DTS what can cause the v4l2-ctl problem? Can you figure what the problem might be according to the trace I’ve provided? Are these rtos_queue_send_from_isr_failed messages normal?
Thanks,
Steve
Could you flash pure r32.7.4 and configurate the IMX219 by jetson-io to try.
Hi Shane,
now I flashed original dtb again onto the device and startet sudo /opt/nvidia/jetson-io/jetson-io.py. However Iam little bit lost with the tool since it only allows me to configure pins but there’s no imx219 option or so. Do you have an advise howto configure the camera using the tool?
=================== Jetson Expansion Header Tool ===================
| Select one of the following: |
| Configure Jetson 40pin Header |
| Configure Jetson M.2 Key E Slot |
| Exit |
Thanks, Steve
Did you flash the device by sdkmanager?
Actually I reverted by DTS changes, recompiled the DT and only reflashed kernel-dtb Partition. However I followed your advise but installation using sdkmanager fails with following error log:
3:53:38 INFO: Flash Jetson TX2 - flash: [ 2.0933 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/nvidia/nvidia/nvidia_sdk/JetPack_4.6.4_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/cvm.bin
13:53:38 INFO: Flash Jetson TX2 - flash: [ 2.0939 ] Applet version 01.00.0000
13:53:38 INFO: Flash Jetson TX2 - flash: [ 2.2147 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 0 --download rcm /home/nvidia/nvidia/nvidia_sdk/JetPack_4.6.4_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin 0 0
13:53:38 INFO: Flash Jetson TX2 - flash: [ 2.2153 ] RCM 0 is saved as rcm_0.rcm
13:53:38 INFO: Flash Jetson TX2 - flash: [ 2.2176 ] Assuming zero filled SBK key
13:53:38 INFO: Flash Jetson TX2 - flash: [ 2.2237 ] tegrarcm_v2 --chip 0x18 0 --updatesig rcm_list_signed.xml
13:53:43 INFO: Flash Jetson TX2 - flash: [ 2.2262 ] tegrarcm_v2 --chip 0x18 0 --rcm rcm_list_signed.xml
13:53:44 INFO: Flash Jetson TX2 - flash: [ 8.4595 ] tegrarcm_v2 --isapplet
13:53:45 INFO: Flash Jetson TX2 - flash: [ 8.4927 ] tegrarcm_v2 --oem platformdetails eeprom cvb /home/nvidia/nvidia/nvidia_sdk/JetPack_4.6.4_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/bbd.bin
13:53:45 INFO: Flash Jetson TX2 - flash: [ 8.4932 ] Applet version 01.00.0000
13:53:45 ERROR: Flash Jetson TX2 - flash: UnicodeDecodeError: 'utf-8' codec can't decode byte 0xa4 in position 16: invalid start byte
13:53:45 ERROR: Flash Jetson TX2 - flash: command terminated with error
13:53:45 SUMMARY: DateTime Target Setup - target: Depends on failed component
Python on host tells me following version:
nvidia@nvidia-OptiPlex-5090:~$ python --version
Python 2.7.17
Is this correct?
Thanks, Steve
What’s your host version.
Please using ubuntu 18.04 for sdkmanager installed.
Hi Shane,
my Ubuntu version should be 18.04LTS, I ran an apt-get update; apt-get dist-upgrade after installation, but this shouldn’t update major release:
nvidia@nvidia-OptiPlex-5090:~$ uname -a
Linux nvidia-OptiPlex-5090 5.4.0-150-generic #167~18.04.1-Ubuntu SMP Wed May 24 00:51:42 UTC 2023 x86_64 x86_64 x86_64 GNU/Linux
Did you work on devkit?
If no you may need specific board configuration file to perform image flash.
Hi Shane,
no. The board is a custom board by auvidea. Where those config files stored?
The board can be easily flashed with the nvidia_sdk/Linux_for_Tegra/flash.sh script, only via sdkmanager I have such problems…
Thanks,
Steve
I would suggest checking with Auvidea for this customized board.
system
Closed
June 19, 2024, 5:59am
23
