I’d like to add a custom camera module on tx2.
I added LKM and device-tree. However, it doesn’t work well.
I have two type of problems.
First, I run v4l command, it performs different results in the same environment.
sometimes it works(Capture success) but a few moments later it doesn’t work without any code changes.
Second, captued image is strange as below.
v4l command is below :
v4l2-ctl -d /dev/video0 --set-fmt-video=width=3264,height=2448,pixelformat=BG10 --stream-mmap --stream-count=10 --stream-to=test.raw --verbose
Log for the first problem when it works as below :
root@ubuntu-desktop:/home/ubuntu# v4l2-ctl -d /dev/video0 --set-fmt-video=width=3264,height=2448,pixelformat=BG10 --stream-mmap --stream-count=10 --stream-to=test.raw --verbose
VIDIOC_QUERYCAP: ok
VIDIOC_G_FMT: ok
VIDIOC_S_FMT: ok
Format Video Capture:
Width/Height : 3264/2448
Pixel Format : 'BG10'
Field : None
Bytes per Line : 6656
Size Image : 16293888
Colorspace : sRGB
Transfer Function : Default (maps to sRGB)
YCbCr/HSV Encoding: Default (maps to ITU-R 601)
Quantization : Default (maps to Full Range)
Flags :
VIDIOC_REQBUFS: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QBUF: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QBUF: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QBUF: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QBUF: ok
VIDIOC_STREAMON: ok
Index : 0
Type : Video Capture
Flags : mapped
Field : None
Sequence : 0
Length : 16293888
Bytesused: 16293888
Timestamp: 996.330322s (Monotonic, End-of-Frame)
Index : 1
Flags : mapped
Field : None
Sequence : 1
Length : 16293888
Bytesused: 16293888
Timestamp: 996.385512s (Monotonic, End-of-Frame)
Index : 2
Flags : mapped
Field : None
Sequence : 2
Length : 16293888
Bytesused: 16293888
Timestamp: 996.440702s (Monotonic, End-of-Frame)
Index : 3
Flags : mapped
Field : None
Sequence : 3
Length : 16293888
Bytesused: 16293888
Timestamp: 996.495893s (Monotonic, End-of-Frame)
Index : 0
Flags : mapped
Field : None
Sequence : 4
Length : 16293888
Bytesused: 16293888
Timestamp: 996.551083s (Monotonic, End-of-Frame)
Index : 1
Flags : mapped
Field : None
Sequence : 5
Length : 16293888
Bytesused: 16293888
Timestamp: 996.606273s (Monotonic, End-of-Frame)
Index : 2
Flags : mapped
Field : None
Sequence : 6
Length : 16293888
Bytesused: 16293888
Timestamp: 996.661463s (Monotonic, End-of-Frame)
Index : 3
Flags : mapped
Field : None
Sequence : 7
Length : 16293888
Bytesused: 16293888
Timestamp: 996.716654s (Monotonic, End-of-Frame)
Index : 0
Flags : mapped
Field : None
Sequence : 8
Length : 16293888
Bytesused: 16293888
Timestamp: 996.771844s (Monotonic, End-of-Frame)
Index : 1
Flags : mapped
Field : None
Sequence : 9
Length : 16293888
Bytesused: 16293888
Timestamp: 996.827034s (Monotonic, End-of-Frame)
VIDIOC_STREAMOFF: ok
Log for the first problem when it fails as below :
VIDIOC_QUERYCAP: ok
VIDIOC_G_FMT: ok
VIDIOC_S_FMT: ok
Field : None
Colorspace : sRGB
Flags :
VIDIOC_REQBUFS: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QBUF: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QBUF: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QBUF: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QBUF: ok
VIDIOC_STREAMON: ok
^C
Dmesg log for the first problem :
[ 253.041995] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 253.048541] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 253.261981] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 253.268543] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 253.481995] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 253.488512] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 253.702001] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 253.708504] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 253.921981] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 253.928865] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 254.142004] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 254.148516] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
Trace log for the first problem :
# tracer: nop
# entries-in-buffer/entries-written: 335/335 #P:4
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
kworker/4:2-3132 [004] .... 244.421912: rtos_queue_peek_from_isr_failed: tstamp:7920284802 queue:0x0b4b4500
kworker/4:2-3132 [004] .... 244.589905: rtos_queue_peek_from_isr_failed: tstamp:7925284807 queue:0x0b4b4500
kworker/4:2-3132 [004] .... 244.701912: rtos_queue_peek_from_isr_failed: tstamp:7930284799 queue:0x0b4b4500
kworker/4:2-3132 [004] .... 244.869928: rtos_queue_peek_from_isr_failed: tstamp:7935284823 queue:0x0b4b4500
kworker/4:2-3132 [004] .... 245.037915: rtos_queue_peek_from_isr_failed: tstamp:7940284813 queue:0x0b4b4500
kworker/4:2-3132 [004] .... 245.205911: rtos_queue_peek_from_isr_failed: tstamp:7945284858 queue:0x0b4b4500
kworker/4:2-3132 [004] .... 245.373906: rtos_queue_peek_from_isr_failed: tstamp:7950284829 queue:0x0b4b4500
kworker/4:2-3132 [004] .... 245.541873: rtos_queue_peek_from_isr_failed: tstamp:7955284837 queue:0x0b4b4500
kworker/4:2-3132 [004] .... 245.709843: rtos_queue_peek_from_isr_failed: tstamp:7960284876 queue:0x0b4b4500
kworker/4:2-3132 [004] .... 245.821863: rtos_queue_peek_from_isr_failed: tstamp:7965284833 queue:0x0b4b4500
kworker/4:2-3132 [004] .... 245.989933: rtos_queue_peek_from_isr_failed: tstamp:7970284869 queue:0x0b4b4500
kworker/4:2-3132 [004] .... 246.157848: rtos_queue_peek_from_isr_failed: tstamp:7975284864 queue:0x0b4b4500
kworker/4:2-3132 [004] .... 246.325905: rtos_queue_peek_from_isr_failed: tstamp:7980284870 queue:0x0b4b4500
kworker/4:2-3132 [004] .... 246.493874: rtos_queue_peek_from_isr_failed: tstamp:7985284888 queue:0x0b4b4500
kworker/4:2-3132 [004] .... 246.661932: rtos_queue_peek_from_isr_failed: tstamp:7990284925 queue:0x0b4b4500
kworker/4:2-3132 [004] .... 246.829938: rtos_queue_peek_from_isr_failed: tstamp:7995284890 queue:0x0b4b4500
kworker/4:2-3132 [004] .... 246.941850: rtos_queue_peek_from_isr_failed: tstamp:8000284897 queue:0x0b4b4500
kworker/4:2-3132 [004] .... 247.109983: rtos_queue_peek_from_isr_failed: tstamp:8005284906 queue:0x0b4b4500
kworker/4:2-3132 [004] .... 247.277991: rtos_queue_peek_from_isr_failed: tstamp:8010284915 queue:0x0b4b4500
kworker/4:2-3132 [004] .... 247.445900: rtos_queue_peek_from_isr_failed: tstamp:8015284895 queue:0x0b4b4500
kworker/4:2-3132 [004] .... 247.613902: rtos_queue_peek_from_isr_failed: tstamp:8020284957 queue:0x0b4b4500
kworker/4:2-3132 [004] .... 247.781899: rtos_queue_peek_from_isr_failed: tstamp:8025284942 queue:0x0b4b4500
kworker/4:2-3132 [004] .... 247.949928: rtos_queue_peek_from_isr_failed: tstamp:8030284977 queue:0x0b4b4500
kworker/4:2-3132 [004] .... 248.061895: rtos_queue_peek_from_isr_failed: tstamp:8035284945 queue:0x0b4b4500
kworker/4:2-3132 [004] .... 248.229958: rtos_queue_peek_from_isr_failed: tstamp:8040284952 queue:0x0b4b4500
kworker/4:2-3132 [004] .... 248.397965: rtos_queue_peek_from_isr_failed: tstamp:8045284958 queue:0x0b4b4500
kworker/4:2-3132 [004] .... 248.565928: rtos_queue_peek_from_isr_failed: tstamp:8050284963 queue:0x0b4b4500
kworker/4:2-3132 [004] .... 248.733923: rtos_queue_peek_from_isr_failed: tstamp:8055284985 queue:0x0b4b4500
kworker/4:2-3132 [004] .... 248.901849: rtos_queue_peek_from_isr_failed: tstamp:8060284989 queue:0x0b4b4500
kworker/4:2-3132 [004] .... 249.069919: rtos_queue_peek_from_isr_failed: tstamp:8065284969 queue:0x0b4b4500
kworker/4:2-3132 [004] .... 249.181860: rtos_queue_peek_from_isr_failed: tstamp:8070284975 queue:0x0b4b4500
kworker/4:2-3132 [004] .... 249.237930: rtos_queue_peek_from_isr_failed: tstamp:8071670572 queue:0x0b4b4500
v4l2-ctl-9610 [003] .... 252.786535: tegra_channel_open: vi-output, s5k4hayx 2-002d
v4l2-ctl-9610 [003] .... 252.791300: tegra_channel_set_power: s5k4hayx 2-002d : 0x1
v4l2-ctl-9610 [003] .... 252.791332: camera_common_s_power: status : 0x1
v4l2-ctl-9610 [003] .... 252.796029: tegra_channel_set_power: 150c0000.nvcsi--1 : 0x1
v4l2-ctl-9610 [003] .... 252.796037: csi_s_power: enable : 0x1
v4l2-ctl-9610 [000] .... 252.819501: tegra_channel_capture_setup: vnc_id 0 W 3264 H 2448 fmt 20
vi-output, s5k4-9611 [003] .... 252.819609: tegra_channel_set_stream: enable : 0x1
vi-output, s5k4-9611 [003] .... 252.820952: tegra_channel_set_stream: 150c0000.nvcsi--1 : 0x1
vi-output, s5k4-9611 [003] .... 252.820954: csi_s_stream: enable : 0x1
vi-output, s5k4-9611 [003] .... 252.820981: tegra_channel_set_stream: s5k4hayx 2-002d : 0x1
kworker/4:2-3132 [004] .... 252.821862: rtos_queue_peek_from_isr_failed: tstamp:8183955013 queue:0x0b4b4500
kworker/4:2-3132 [004] .... 252.821866: rtcpu_start: tstamp:8183955974
kworker/4:2-3132 [004] .... 252.821868: rtos_queue_send_from_isr_failed: tstamp:8183964439 queue:0x0b4a7258
kworker/4:2-3132 [004] .... 252.821869: rtos_queue_send_from_isr_failed: tstamp:8183964548 queue:0x0b4aad68
kworker/4:2-3132 [004] .... 252.821869: rtos_queue_send_from_isr_failed: tstamp:8183964655 queue:0x0b4ac998
kworker/4:2-3132 [004] .... 252.821870: rtos_queue_send_from_isr_failed: tstamp:8183964764 queue:0x0b4ae518
kworker/4:2-3132 [004] .... 252.821871: rtos_queue_send_from_isr_failed: tstamp:8183964869 queue:0x0b4af2d8
kworker/4:2-3132 [004] .... 252.821871: rtos_queue_send_from_isr_failed: tstamp:8183964973 queue:0x0b4b0098
kworker/4:2-3132 [004] .... 252.821872: rtos_queue_send_from_isr_failed: tstamp:8183965077 queue:0x0b4b0e58
kworker/4:2-3132 [004] .... 252.821873: rtos_queue_send_from_isr_failed: tstamp:8183965182 queue:0x0b4b1c18
kworker/4:2-3132 [004] .... 252.821874: rtos_queue_send_failed: tstamp:8183965654 queue:0x0b4a7258
kworker/4:2-3132 [004] .... 252.821875: rtos_queue_send_from_isr_failed: tstamp:8183967241 queue:0x0b4a7258
kworker/4:2-3132 [004] .... 252.821876: rtos_queue_send_from_isr_failed: tstamp:8183967349 queue:0x0b4aad68
kworker/4:2-3132 [004] .... 252.821876: rtos_queue_send_from_isr_failed: tstamp:8183967455 queue:0x0b4ac998
kworker/4:2-3132 [004] .... 252.821877: rtos_queue_send_from_isr_failed: tstamp:8183967561 queue:0x0b4ae518
kworker/4:2-3132 [004] .... 252.821877: rtos_queue_send_from_isr_failed: tstamp:8183967666 queue:0x0b4af2d8
kworker/4:2-3132 [004] .... 252.821878: rtos_queue_send_from_isr_failed: tstamp:8183967771 queue:0x0b4b0098
kworker/4:2-3132 [004] .... 252.821879: rtos_queue_send_from_isr_failed: tstamp:8183967876 queue:0x0b4b0e58
kworker/4:2-3132 [004] .... 252.821879: rtos_queue_send_from_isr_failed: tstamp:8183967980 queue:0x0b4b1c18
kworker/4:2-3132 [004] .... 252.821880: rtos_queue_send_failed: tstamp:8183968941 queue:0x0b4a7258
kworker/4:2-3132 [004] .... 252.989934: rtos_queue_peek_from_isr_failed: tstamp:8188955382 queue:0x0b4b4500
vi-output, s5k4-9611 [000] .... 253.058898: tegra_channel_capture_setup: vnc_id 0 W 3264 H 2448 fmt 20
vi-output, s5k4-9611 [000] .... 253.058935: tegra_channel_capture_frame: sof:-549620695332.-269227597952
kworker/4:2-3132 [004] .... 253.101955: rtos_queue_send_from_isr_failed: tstamp:8191434001 queue:0x0b4a7258
kworker/4:2-3132 [004] .... 253.101961: rtos_queue_send_from_isr_failed: tstamp:8191434118 queue:0x0b4aad68
kworker/4:2-3132 [004] .... 253.101963: rtos_queue_send_from_isr_failed: tstamp:8191434231 queue:0x0b4ac998
kworker/4:2-3132 [004] .... 253.101966: rtos_queue_send_from_isr_failed: tstamp:8191434342 queue:0x0b4ae518
kworker/4:2-3132 [004] .... 253.101968: rtos_queue_send_from_isr_failed: tstamp:8191434451 queue:0x0b4af2d8
kworker/4:2-3132 [004] .... 253.101970: rtos_queue_send_from_isr_failed: tstamp:8191434561 queue:0x0b4b0098
kworker/4:2-3132 [004] .... 253.101973: rtos_queue_send_from_isr_failed: tstamp:8191434686 queue:0x0b4b0e58
kworker/4:2-3132 [004] .... 253.101975: rtos_queue_send_from_isr_failed: tstamp:8191434800 queue:0x0b4b1c18
kworker/4:2-3132 [004] .... 253.101979: rtos_queue_send_failed: tstamp:8191435423 queue:0x0b4a7258
kworker/4:2-3132 [004] .... 253.101981: rtos_queue_send_from_isr_failed: tstamp:8191437922 queue:0x0b4a7258
kworker/4:2-3132 [004] .... 253.101983: rtos_queue_send_from_isr_failed: tstamp:8191438034 queue:0x0b4aad68
kworker/4:2-3132 [004] .... 253.101985: rtos_queue_send_from_isr_failed: tstamp:8191438144 queue:0x0b4ac998
kworker/4:2-3132 [004] .... 253.101988: rtos_queue_send_from_isr_failed: tstamp:8191438267 queue:0x0b4ae518
kworker/4:2-3132 [004] .... 253.101990: rtos_queue_send_from_isr_failed: tstamp:8191438376 queue:0x0b4af2d8
kworker/4:2-3132 [004] .... 253.101992: rtos_queue_send_from_isr_failed: tstamp:8191438485 queue:0x0b4b0098
kworker/4:2-3132 [004] .... 253.101994: rtos_queue_send_from_isr_failed: tstamp:8191438594 queue:0x0b4b0e58
kworker/4:2-3132 [004] .... 253.101997: rtos_queue_send_from_isr_failed: tstamp:8191438704 queue:0x0b4b1c18
kworker/4:2-3132 [004] .... 253.101999: rtos_queue_send_failed: tstamp:8191439158 queue:0x0b4a7258
kworker/4:2-3132 [004] .... 253.102001: rtos_queue_send_from_isr_failed: tstamp:8191444124 queue:0x0b4a7258
kworker/4:2-3132 [004] .... 253.102003: rtos_queue_send_from_isr_failed: tstamp:8191444236 queue:0x0b4aad68
kworker/4:2-3132 [004] .... 253.102005: rtos_queue_send_from_isr_failed: tstamp:8191444349 queue:0x0b4ac998
kworker/4:2-3132 [004] .... 253.102008: rtos_queue_send_from_isr_failed: tstamp:8191444460 queue:0x0b4ae518
kworker/4:2-3132 [004] .... 253.102010: rtos_queue_send_from_isr_failed: tstamp:8191444569 queue:0x0b4af2d8
kworker/4:2-3132 [004] .... 253.102012: rtos_queue_send_from_isr_failed: tstamp:8191444682 queue:0x0b4b0098
kworker/4:2-3132 [004] .... 253.102014: rtos_queue_send_from_isr_failed: tstamp:8191444792 queue:0x0b4b0e58
kworker/4:2-3132 [004] .... 253.102017: rtos_queue_send_from_isr_failed: tstamp:8191444902 queue:0x0b4b1c18
kworker/4:2-3132 [004] .... 253.102019: rtos_queue_send_failed: tstamp:8191445354 queue:0x0b4a7258
kworker/4:2-3132 [004] .... 253.102021: rtos_queue_send_from_isr_failed: tstamp:8191447541 queue:0x0b4a7258
kworker/4:2-3132 [004] .... 253.102023: rtos_queue_send_from_isr_failed: tstamp:8191447654 queue:0x0b4aad68
kworker/4:2-3132 [004] .... 253.102026: rtos_queue_send_from_isr_failed: tstamp:8191447764 queue:0x0b4ac998
kworker/4:2-3132 [004] .... 253.102028: rtos_queue_send_from_isr_failed: tstamp:8191447881 queue:0x0b4ae518
kworker/4:2-3132 [004] .... 253.102030: rtos_queue_send_from_isr_failed: tstamp:8191447990 queue:0x0b4af2d8
kworker/4:2-3132 [004] .... 253.102032: rtos_queue_send_from_isr_failed: tstamp:8191448100 queue:0x0b4b0098
kworker/4:2-3132 [004] .... 253.102035: rtos_queue_send_from_isr_failed: tstamp:8191448209 queue:0x0b4b0e58
kworker/4:2-3132 [004] .... 253.102037: rtos_queue_send_from_isr_failed: tstamp:8191448318 queue:0x0b4b1c18
kworker/4:2-3132 [004] .... 253.102039: rtos_queue_send_failed: tstamp:8191449302 queue:0x0b4a7258
kworker/4:2-3132 [004] .... 253.157958: rtos_queue_peek_from_isr_failed: tstamp:8193955370 queue:0x0b4b4500
vi-output, s5k4-9611 [000] .... 253.278816: tegra_channel_capture_setup: vnc_id 0 W 3264 H 2448 fmt 20
vi-output, s5k4-9611 [000] .... 253.278849: tegra_channel_capture_frame: sof:-549620695332.-269227597952
kworker/4:2-3132 [004] .... 253.325946: rtos_queue_send_from_isr_failed: tstamp:8198304519 queue:0x0b4a7258
kworker/4:2-3132 [004] .... 253.325953: rtos_queue_send_from_isr_failed: tstamp:8198304636 queue:0x0b4aad68
kworker/4:2-3132 [004] .... 253.325955: rtos_queue_send_from_isr_failed: tstamp:8198304750 queue:0x0b4ac998
kworker/4:2-3132 [004] .... 253.325958: rtos_queue_send_from_isr_failed: tstamp:8198304862 queue:0x0b4ae518
kworker/4:2-3132 [004] .... 253.325961: rtos_queue_send_from_isr_failed: tstamp:8198304974 queue:0x0b4af2d8
kworker/4:2-3132 [004] .... 253.325963: rtos_queue_send_from_isr_failed: tstamp:8198305083 queue:0x0b4b0098
kworker/4:2-3132 [004] .... 253.325965: rtos_queue_send_from_isr_failed: tstamp:8198305192 queue:0x0b4b0e58
kworker/4:2-3132 [004] .... 253.325967: rtos_queue_send_from_isr_failed: tstamp:8198305301 queue:0x0b4b1c18
kworker/4:2-3132 [004] .... 253.325970: rtos_queue_send_failed: tstamp:8198305931 queue:0x0b4a7258
kworker/4:2-3132 [004] .... 253.325972: rtos_queue_send_from_isr_failed: tstamp:8198309885 queue:0x0b4a7258
kworker/4:2-3132 [004] .... 253.325975: rtos_queue_send_from_isr_failed: tstamp:8198309996 queue:0x0b4aad68
kworker/4:2-3132 [004] .... 253.325977: rtos_queue_send_from_isr_failed: tstamp:8198310108 queue:0x0b4ac998
kworker/4:2-3132 [004] .... 253.325979: rtos_queue_send_from_isr_failed: tstamp:8198310218 queue:0x0b4ae518
kworker/4:2-3132 [004] .... 253.325981: rtos_queue_send_from_isr_failed: tstamp:8198310328 queue:0x0b4af2d8
kworker/4:2-3132 [004] .... 253.325983: rtos_queue_send_from_isr_failed: tstamp:8198310437 queue:0x0b4b0098
kworker/4:2-3132 [004] .... 253.325986: rtos_queue_send_from_isr_failed: tstamp:8198310546 queue:0x0b4b0e58
kworker/4:2-3132 [004] .... 253.325988: rtos_queue_send_from_isr_failed: tstamp:8198310656 queue:0x0b4b1c18
kworker/4:2-3132 [004] .... 253.325990: rtos_queue_send_failed: tstamp:8198311114 queue:0x0b4a7258
kworker/4:2-3132 [004] .... 253.325992: rtos_queue_send_from_isr_failed: tstamp:8198316342 queue:0x0b4a7258
kworker/4:2-3132 [004] .... 253.325995: rtos_queue_send_from_isr_failed: tstamp:8198316454 queue:0x0b4aad68
kworker/4:2-3132 [004] .... 253.325997: rtos_queue_send_from_isr_failed: tstamp:8198316565 queue:0x0b4ac998
kworker/4:2-3132 [004] .... 253.325999: rtos_queue_send_from_isr_failed: tstamp:8198316681 queue:0x0b4ae518
kworker/4:2-3132 [004] .... 253.326001: rtos_queue_send_from_isr_failed: tstamp:8198316790 queue:0x0b4af2d8
kworker/4:2-3132 [004] .... 253.326004: rtos_queue_send_from_isr_failed: tstamp:8198316900 queue:0x0b4b0098
kworker/4:2-3132 [004] .... 253.326006: rtos_queue_send_from_isr_failed: tstamp:8198317009 queue:0x0b4b0e58
kworker/4:2-3132 [004] .... 253.326008: rtos_queue_send_from_isr_failed: tstamp:8198317120 queue:0x0b4b1c18
kworker/4:2-3132 [004] .... 253.326010: rtos_queue_send_failed: tstamp:8198317579 queue:0x0b4a7258
kworker/4:2-3132 [004] .... 253.326013: rtos_queue_send_from_isr_failed: tstamp:8198319999 queue:0x0b4a7258
kworker/4:2-3132 [004] .... 253.326015: rtos_queue_send_from_isr_failed: tstamp:8198320112 queue:0x0b4aad68
kworker/4:2-3132 [004] .... 253.326017: rtos_queue_send_from_isr_failed: tstamp:8198320222 queue:0x0b4ac998
kworker/4:2-3132 [004] .... 253.326019: rtos_queue_send_from_isr_failed: tstamp:8198320332 queue:0x0b4ae518
kworker/4:2-3132 [004] .... 253.326021: rtos_queue_send_from_isr_failed: tstamp:8198320442 queue:0x0b4af2d8
kworker/4:2-3132 [004] .... 253.326023: rtos_queue_send_from_isr_failed: tstamp:8198320564 queue:0x0b4b0098
kworker/4:2-3132 [004] .... 253.326026: rtos_queue_send_from_isr_failed: tstamp:8198320673 queue:0x0b4b0e58
kworker/4:2-3132 [004] .... 253.326028: rtos_queue_send_from_isr_failed: tstamp:8198320789 queue:0x0b4b1c18
kworker/4:2-3132 [004] .... 253.326030: rtos_queue_send_failed: tstamp:8198321783 queue:0x0b4a7258
kworker/4:2-3132 [004] .... 253.326034: rtos_queue_peek_from_isr_failed: tstamp:8198955376 queue:0x0b4b4500
kworker/4:2-3132 [004] .... 253.497897: rtos_queue_peek_from_isr_failed: tstamp:8203955385 queue:0x0b4b4500
vi-output, s5k4-9611 [000] .... 253.498729: tegra_channel_capture_setup: vnc_id 0 W 3264 H 2448 fmt 20
vi-output, s5k4-9611 [000] .... 253.498761: tegra_channel_capture_frame: sof:-549620695332.-269227597952
kworker/4:2-3132 [004] .... 253.553989: rtos_queue_send_from_isr_failed: tstamp:8205178835 queue:0x0b4a7258
kworker/4:2-3132 [004] .... 253.553996: rtos_queue_send_from_isr_failed: tstamp:8205178952 queue:0x0b4aad68
kworker/4:2-3132 [004] .... 253.553998: rtos_queue_send_from_isr_failed: tstamp:8205179065 queue:0x0b4ac998
kworker/4:2-3132 [004] .... 253.554000: rtos_queue_send_from_isr_failed: tstamp:8205179179 queue:0x0b4ae518
kworker/4:2-3132 [004] .... 253.554002: rtos_queue_send_from_isr_failed: tstamp:8205179289 queue:0x0b4af2d8
kworker/4:2-3132 [004] .... 253.554005: rtos_queue_send_from_isr_failed: tstamp:8205179398 queue:0x0b4b0098
kworker/4:2-3132 [004] .... 253.554007: rtos_queue_send_from_isr_failed: tstamp:8205179508 queue:0x0b4b0e58
kworker/4:2-3132 [004] .... 253.554009: rtos_queue_send_from_isr_failed: tstamp:8205179618 queue:0x0b4b1c18
kworker/4:2-3132 [004] .... 253.554013: rtos_queue_send_failed: tstamp:8205180251 queue:0x0b4a7258
kworker/4:2-3132 [004] .... 253.554018: rtos_queue_send_from_isr_failed: tstamp:8205183519 queue:0x0b4a7258
kworker/4:2-3132 [004] .... 253.554020: rtos_queue_send_from_isr_failed: tstamp:8205183630 queue:0x0b4aad68
kworker/4:2-3132 [004] .... 253.554023: rtos_queue_send_from_isr_failed: tstamp:8205183742 queue:0x0b4ac998
kworker/4:2-3132 [004] .... 253.554025: rtos_queue_send_from_isr_failed: tstamp:8205183856 queue:0x0b4ae518
kworker/4:2-3132 [004] .... 253.554027: rtos_queue_send_from_isr_failed: tstamp:8205183965 queue:0x0b4af2d8
kworker/4:2-3132 [004] .... 253.554030: rtos_queue_send_from_isr_failed: tstamp:8205184075 queue:0x0b4b0098
kworker/4:2-3132 [004] .... 253.554032: rtos_queue_send_from_isr_failed: tstamp:8205184185 queue:0x0b4b0e58
kworker/4:2-3132 [004] .... 253.554034: rtos_queue_send_from_isr_failed: tstamp:8205184294 queue:0x0b4b1c18
kworker/4:2-3132 [004] .... 253.554036: rtos_queue_send_failed: tstamp:8205184744 queue:0x0b4a7258
kworker/4:2-3132 [004] .... 253.554038: rtos_queue_send_from_isr_failed: tstamp:8205189307 queue:0x0b4a7258
kworker/4:2-3132 [004] .... 253.554041: rtos_queue_send_from_isr_failed: tstamp:8205189419 queue:0x0b4aad68
kworker/4:2-3132 [004] .... 253.554043: rtos_queue_send_from_isr_failed: tstamp:8205189530 queue:0x0b4ac998
kworker/4:2-3132 [004] .... 253.554045: rtos_queue_send_from_isr_failed: tstamp:8205189643 queue:0x0b4ae518
kworker/4:2-3132 [004] .... 253.554047: rtos_queue_send_from_isr_failed: tstamp:8205189752 queue:0x0b4af2d8
kworker/4:2-3132 [004] .... 253.554049: rtos_queue_send_from_isr_failed: tstamp:8205189861 queue:0x0b4b0098
kworker/4:2-3132 [004] .... 253.554052: rtos_queue_send_from_isr_failed: tstamp:8205189970 queue:0x0b4b0e58
kworker/4:2-3132 [004] .... 253.554054: rtos_queue_send_from_isr_failed: tstamp:8205190080 queue:0x0b4b1c18
kworker/4:2-3132 [004] .... 253.554056: rtos_queue_send_failed: tstamp:8205190536 queue:0x0b4a7258
kworker/4:2-3132 [004] .... 253.554058: rtos_queue_send_from_isr_failed: tstamp:8205192365 queue:0x0b4a7258
kworker/4:2-3132 [004] .... 253.554061: rtos_queue_send_from_isr_failed: tstamp:8205192478 queue:0x0b4aad68
kworker/4:2-3132 [004] .... 253.554063: rtos_queue_send_from_isr_failed: tstamp:8205192590 queue:0x0b4ac998
kworker/4:2-3132 [004] .... 253.554065: rtos_queue_send_from_isr_failed: tstamp:8205192702 queue:0x0b4ae518
kworker/4:2-3132 [004] .... 253.554067: rtos_queue_send_from_isr_failed: tstamp:8205192813 queue:0x0b4af2d8
kworker/4:2-3132 [004] .... 253.554069: rtos_queue_send_from_isr_failed: tstamp:8205192929 queue:0x0b4b0098
kworker/4:2-3132 [004] .... 253.554072: rtos_queue_send_from_isr_failed: tstamp:8205193038 queue:0x0b4b0e58
kworker/4:2-3132 [004] .... 253.554074: rtos_queue_send_from_isr_failed: tstamp:8205193149 queue:0x0b4b1c18
kworker/4:2-3132 [004] .... 253.554076: rtos_queue_send_failed: tstamp:8205194172 queue:0x0b4a7258
kworker/4:2-3132 [004] .... 253.666016: rtos_queue_peek_from_isr_failed: tstamp:8208955384 queue:0x0b4b4500
vi-output, s5k4-9611 [000] .... 253.718651: tegra_channel_capture_setup: vnc_id 0 W 3264 H 2448 fmt 20
vi-output, s5k4-9611 [000] .... 253.718683: tegra_channel_capture_frame: sof:-549620695332.-269227597952
kworker/4:2-3132 [004] .... 253.721876: rtos_queue_send_from_isr_failed: tstamp:8212051402 queue:0x0b4a7258
kworker/4:2-3132 [004] .... 253.721879: rtos_queue_send_from_isr_failed: tstamp:8212051517 queue:0x0b4aad68
kworker/4:2-3132 [004] .... 253.721880: rtos_queue_send_from_isr_failed: tstamp:8212051629 queue:0x0b4ac998
kworker/4:2-3132 [004] .... 253.721880: rtos_queue_send_from_isr_failed: tstamp:8212051740 queue:0x0b4ae518
kworker/4:2-3132 [004] .... 253.721881: rtos_queue_send_from_isr_failed: tstamp:8212051849 queue:0x0b4af2d8
kworker/4:2-3132 [004] .... 253.721882: rtos_queue_send_from_isr_failed: tstamp:8212051958 queue:0x0b4b0098
kworker/4:2-3132 [004] .... 253.721883: rtos_queue_send_from_isr_failed: tstamp:8212052070 queue:0x0b4b0e58
kworker/4:2-3132 [004] .... 253.721884: rtos_queue_send_from_isr_failed: tstamp:8212052180 queue:0x0b4b1c18
kworker/4:2-3132 [004] .... 253.721886: rtos_queue_send_failed: tstamp:8212052819 queue:0x0b4a7258
kworker/4:2-3132 [004] .... 253.721886: rtos_queue_send_from_isr_failed: tstamp:8212055709 queue:0x0b4a7258
kworker/4:2-3132 [004] .... 253.721887: rtos_queue_send_from_isr_failed: tstamp:8212055834 queue:0x0b4aad68
kworker/4:2-3132 [004] .... 253.721888: rtos_queue_send_from_isr_failed: tstamp:8212055946 queue:0x0b4ac998
kworker/4:2-3132 [004] .... 253.721889: rtos_queue_send_from_isr_failed: tstamp:8212056058 queue:0x0b4ae518
kworker/4:2-3132 [004] .... 253.721890: rtos_queue_send_from_isr_failed: tstamp:8212056171 queue:0x0b4af2d8
kworker/4:2-3132 [004] .... 253.721891: rtos_queue_send_from_isr_failed: tstamp:8212056280 queue:0x0b4b0098
kworker/4:2-3132 [004] .... 253.721892: rtos_queue_send_from_isr_failed: tstamp:8212056389 queue:0x0b4b0e58
kworker/4:2-3132 [004] .... 253.721893: rtos_queue_send_from_isr_failed: tstamp:8212056499 queue:0x0b4b1c18
kworker/4:2-3132 [004] .... 253.721894: rtos_queue_send_failed: tstamp:8212056944 queue:0x0b4a7258
kworker/4:2-3132 [004] .... 253.721895: rtos_queue_send_from_isr_failed: tstamp:8212062081 queue:0x0b4a7258
kworker/4:2-3132 [004] .... 253.721895: rtos_queue_send_from_isr_failed: tstamp:8212062199 queue:0x0b4aad68
kworker/4:2-3132 [004] .... 253.721896: rtos_queue_send_from_isr_failed: tstamp:8212062311 queue:0x0b4ac998
kworker/4:2-3132 [004] .... 253.721897: rtos_queue_send_from_isr_failed: tstamp:8212062424 queue:0x0b4ae518
kworker/4:2-3132 [004] .... 253.721898: rtos_queue_send_from_isr_failed: tstamp:8212062533 queue:0x0b4af2d8
kworker/4:2-3132 [004] .... 253.721899: rtos_queue_send_from_isr_failed: tstamp:8212062654 queue:0x0b4b0098
kworker/4:2-3132 [004] .... 253.721900: rtos_queue_send_from_isr_failed: tstamp:8212062763 queue:0x0b4b0e58
kworker/4:2-3132 [004] .... 253.721901: rtos_queue_send_from_isr_failed: tstamp:8212062872 queue:0x0b4b1c18
kworker/4:2-3132 [004] .... 253.721902: rtos_queue_send_failed: tstamp:8212063396 queue:0x0b4a7258
kworker/4:2-3132 [004] .... 253.721903: rtos_queue_send_from_isr_failed: tstamp:8212065139 queue:0x0b4a7258
kworker/4:2-3132 [004] .... 253.721904: rtos_queue_send_from_isr_failed: tstamp:8212065250 queue:0x0b4aad68
kworker/4:2-3132 [004] .... 253.721905: rtos_queue_send_from_isr_failed: tstamp:8212065361 queue:0x0b4ac998
kworker/4:2-3132 [004] .... 253.721905: rtos_queue_send_from_isr_failed: tstamp:8212065471 queue:0x0b4ae518
kworker/4:2-3132 [004] .... 253.721906: rtos_queue_send_from_isr_failed: tstamp:8212065582 queue:0x0b4af2d8
kworker/4:2-3132 [004] .... 253.721907: rtos_queue_send_from_isr_failed: tstamp:8212065691 queue:0x0b4b0098
kworker/4:2-3132 [004] .... 253.721908: rtos_queue_send_from_isr_failed: tstamp:8212065802 queue:0x0b4b0e58
kworker/4:2-3132 [004] .... 253.721909: rtos_queue_send_from_isr_failed: tstamp:8212065910 queue:0x0b4b1c18
kworker/4:2-3132 [004] .... 253.721910: rtos_queue_send_failed: tstamp:8212066889 queue:0x0b4a7258
kworker/4:2-3132 [004] .... 253.833940: rtos_queue_peek_from_isr_failed: tstamp:8213955404 queue:0x0b4b4500
vi-output, s5k4-9611 [003] .... 253.940430: tegra_channel_capture_setup: vnc_id 0 W 3264 H 2448 fmt 20
vi-output, s5k4-9611 [003] .... 253.940464: tegra_channel_capture_frame: sof:-549620695332.-269227597952
kworker/4:2-3132 [004] .... 253.945912: rtos_queue_peek_from_isr_failed: tstamp:8218955398 queue:0x0b4b4500
kworker/4:2-3132 [004] .... 253.945976: rtos_queue_send_from_isr_failed: tstamp:8218965656 queue:0x0b4a7258
kworker/4:2-3132 [004] .... 253.945977: rtos_queue_send_from_isr_failed: tstamp:8218965772 queue:0x0b4aad68
kworker/4:2-3132 [004] .... 253.945978: rtos_queue_send_from_isr_failed: tstamp:8218965885 queue:0x0b4ac998
kworker/4:2-3132 [004] .... 253.945979: rtos_queue_send_from_isr_failed: tstamp:8218965997 queue:0x0b4ae518
kworker/4:2-3132 [004] .... 253.945979: rtos_queue_send_from_isr_failed: tstamp:8218966105 queue:0x0b4af2d8
kworker/4:2-3132 [004] .... 253.945980: rtos_queue_send_from_isr_failed: tstamp:8218966214 queue:0x0b4b0098
kworker/4:2-3132 [004] .... 253.945981: rtos_queue_send_from_isr_failed: tstamp:8218966323 queue:0x0b4b0e58
kworker/4:2-3132 [004] .... 253.945982: rtos_queue_send_from_isr_failed: tstamp:8218966432 queue:0x0b4b1c18
kworker/4:2-3132 [004] .... 253.945984: rtos_queue_send_failed: tstamp:8218967062 queue:0x0b4a7258
kworker/4:2-3132 [004] .... 253.945984: rtos_queue_send_from_isr_failed: tstamp:8218969734 queue:0x0b4a7258
kworker/4:2-3132 [004] .... 253.945985: rtos_queue_send_from_isr_failed: tstamp:8218969844 queue:0x0b4aad68
kworker/4:2-3132 [004] .... 253.945986: rtos_queue_send_from_isr_failed: tstamp:8218969954 queue:0x0b4ac998
kworker/4:2-3132 [004] .... 253.945987: rtos_queue_send_from_isr_failed: tstamp:8218970066 queue:0x0b4ae518
kworker/4:2-3132 [004] .... 253.945988: rtos_queue_send_from_isr_failed: tstamp:8218970173 queue:0x0b4af2d8
kworker/4:2-3132 [004] .... 253.945988: rtos_queue_send_from_isr_failed: tstamp:8218970283 queue:0x0b4b0098
kworker/4:2-3132 [004] .... 253.945989: rtos_queue_send_from_isr_failed: tstamp:8218970392 queue:0x0b4b0e58
kworker/4:2-3132 [004] .... 253.945990: rtos_queue_send_from_isr_failed: tstamp:8218970501 queue:0x0b4b1c18
kworker/4:2-3132 [004] .... 253.945991: rtos_queue_send_failed: tstamp:8218970965 queue:0x0b4a7258
kworker/4:2-3132 [004] .... 253.945991: rtos_queue_send_from_isr_failed: tstamp:8218993201 queue:0x0b4a7258
kworker/4:2-3132 [004] .... 253.945992: rtos_queue_send_from_isr_failed: tstamp:8218993314 queue:0x0b4aad68
kworker/4:2-3132 [004] .... 253.945993: rtos_queue_send_from_isr_failed: tstamp:8218993424 queue:0x0b4ac998
kworker/4:2-3132 [004] .... 253.945994: rtos_queue_send_from_isr_failed: tstamp:8218993535 queue:0x0b4ae518
kworker/4:2-3132 [004] .... 253.945995: rtos_queue_send_from_isr_failed: tstamp:8218993644 queue:0x0b4af2d8
kworker/4:2-3132 [004] .... 253.945995: rtos_queue_send_from_isr_failed: tstamp:8218993753 queue:0x0b4b0098
kworker/4:2-3132 [004] .... 253.945996: rtos_queue_send_from_isr_failed: tstamp:8218993863 queue:0x0b4b0e58
kworker/4:2-3132 [004] .... 253.945997: rtos_queue_send_from_isr_failed: tstamp:8218993974 queue:0x0b4b1c18
kworker/4:2-3132 [004] .... 253.945997: rtos_queue_send_failed: tstamp:8218994442 queue:0x0b4a7258
kworker/4:2-3132 [004] .... 253.945998: rtos_queue_send_from_isr_failed: tstamp:8218995993 queue:0x0b4a7258
kworker/4:2-3132 [004] .... 253.945999: rtos_queue_send_from_isr_failed: tstamp:8218996104 queue:0x0b4aad68
kworker/4:2-3132 [004] .... 253.946000: rtos_queue_send_from_isr_failed: tstamp:8218996214 queue:0x0b4ac998
kworker/4:2-3132 [004] .... 253.946001: rtos_queue_send_from_isr_failed: tstamp:8218996326 queue:0x0b4ae518
kworker/4:2-3132 [004] .... 253.946001: rtos_queue_send_from_isr_failed: tstamp:8218996435 queue:0x0b4af2d8
kworker/4:2-3132 [004] .... 253.946002: rtos_queue_send_from_isr_failed: tstamp:8218996545 queue:0x0b4b0098
kworker/4:2-3132 [004] .... 253.946003: rtos_queue_send_from_isr_failed: tstamp:8218996656 queue:0x0b4b0e58
kworker/4:2-3132 [004] .... 253.946003: rtos_queue_send_from_isr_failed: tstamp:8218996764 queue:0x0b4b1c18
kworker/4:2-3132 [004] .... 253.946004: rtos_queue_send_failed: tstamp:8218997755 queue:0x0b4a7258
v4l2-ctl-9610 [000] .... 253.963356: tegra_channel_close: vi-output, s5k4hayx 2-002d
kworker/4:2-3132 [004] .... 254.113962: rtos_queue_peek_from_isr_failed: tstamp:8223955436 queue:0x0b4b4500
vi-output, s5k4-9611 [000] .... 254.158961: tegra_channel_capture_setup: vnc_id 0 W 3264 H 2448 fmt 20
vi-output, s5k4-9611 [000] .... 254.158998: tegra_channel_capture_frame: sof:-549620695332.-269227597952
v4l2-ctl-9610 [000] .... 254.159363: tegra_channel_set_stream: enable : 0x0
v4l2-ctl-9610 [000] .... 254.159366: tegra_channel_set_stream: s5k4hayx 2-002d : 0x0
v4l2-ctl-9610 [000] .... 254.159574: tegra_channel_set_stream: 150c0000.nvcsi--1 : 0x0
v4l2-ctl-9610 [000] .... 254.159578: csi_s_stream: enable : 0x0
kworker/4:2-3132 [004] .... 254.169926: rtos_queue_send_from_isr_failed: tstamp:8225806696 queue:0x0b4a7258
kworker/4:2-3132 [004] .... 254.169929: rtos_queue_send_from_isr_failed: tstamp:8225806812 queue:0x0b4aad68
kworker/4:2-3132 [004] .... 254.169930: rtos_queue_send_from_isr_failed: tstamp:8225806923 queue:0x0b4ac998
kworker/4:2-3132 [004] .... 254.169931: rtos_queue_send_from_isr_failed: tstamp:8225807038 queue:0x0b4ae518
kworker/4:2-3132 [004] .... 254.169932: rtos_queue_send_from_isr_failed: tstamp:8225807147 queue:0x0b4af2d8
kworker/4:2-3132 [004] .... 254.169933: rtos_queue_send_from_isr_failed: tstamp:8225807256 queue:0x0b4b0098
kworker/4:2-3132 [004] .... 254.169934: rtos_queue_send_from_isr_failed: tstamp:8225807368 queue:0x0b4b0e58
kworker/4:2-3132 [004] .... 254.169936: rtos_queue_send_from_isr_failed: tstamp:8225807477 queue:0x0b4b1c18
kworker/4:2-3132 [004] .... 254.169938: rtos_queue_send_failed: tstamp:8225808100 queue:0x0b4a7258
kworker/4:2-3132 [004] .... 254.169939: rtos_queue_send_from_isr_failed: tstamp:8225812613 queue:0x0b4a7258
kworker/4:2-3132 [004] .... 254.169940: rtos_queue_send_from_isr_failed: tstamp:8225812724 queue:0x0b4aad68
kworker/4:2-3132 [004] .... 254.169941: rtos_queue_send_from_isr_failed: tstamp:8225812835 queue:0x0b4ac998
kworker/4:2-3132 [004] .... 254.169942: rtos_queue_send_from_isr_failed: tstamp:8225812951 queue:0x0b4ae518
kworker/4:2-3132 [004] .... 254.169943: rtos_queue_send_from_isr_failed: tstamp:8225813062 queue:0x0b4af2d8
kworker/4:2-3132 [004] .... 254.169944: rtos_queue_send_from_isr_failed: tstamp:8225813170 queue:0x0b4b0098
kworker/4:2-3132 [004] .... 254.169945: rtos_queue_send_from_isr_failed: tstamp:8225813280 queue:0x0b4b0e58
kworker/4:2-3132 [004] .... 254.169946: rtos_queue_send_from_isr_failed: tstamp:8225813389 queue:0x0b4b1c18
kworker/4:2-3132 [004] .... 254.169947: rtos_queue_send_failed: tstamp:8225813890 queue:0x0b4a7258
kworker/4:2-3132 [004] .... 254.169948: rtos_queue_send_from_isr_failed: tstamp:8225819607 queue:0x0b4a7258
kworker/4:2-3132 [004] .... 254.169949: rtos_queue_send_from_isr_failed: tstamp:8225819720 queue:0x0b4aad68
kworker/4:2-3132 [004] .... 254.169950: rtos_queue_send_from_isr_failed: tstamp:8225819830 queue:0x0b4ac998
kworker/4:2-3132 [004] .... 254.169951: rtos_queue_send_from_isr_failed: tstamp:8225819942 queue:0x0b4ae518
kworker/4:2-3132 [004] .... 254.169952: rtos_queue_send_from_isr_failed: tstamp:8225820055 queue:0x0b4af2d8
kworker/4:2-3132 [004] .... 254.169953: rtos_queue_send_from_isr_failed: tstamp:8225820163 queue:0x0b4b0098
kworker/4:2-3132 [004] .... 254.169954: rtos_queue_send_from_isr_failed: tstamp:8225820275 queue:0x0b4b0e58
kworker/4:2-3132 [004] .... 254.169955: rtos_queue_send_from_isr_failed: tstamp:8225820384 queue:0x0b4b1c18
kworker/4:2-3132 [004] .... 254.169956: rtos_queue_send_failed: tstamp:8225820840 queue:0x0b4a7258
kworker/4:2-3132 [004] .... 254.169957: rtos_queue_send_from_isr_failed: tstamp:8225823846 queue:0x0b4a7258
kworker/4:2-3132 [004] .... 254.169958: rtos_queue_send_from_isr_failed: tstamp:8225823960 queue:0x0b4aad68
kworker/4:2-3132 [004] .... 254.169959: rtos_queue_send_from_isr_failed: tstamp:8225824072 queue:0x0b4ac998
kworker/4:2-3132 [004] .... 254.169960: rtos_queue_send_from_isr_failed: tstamp:8225824182 queue:0x0b4ae518
kworker/4:2-3132 [004] .... 254.169961: rtos_queue_send_from_isr_failed: tstamp:8225824291 queue:0x0b4af2d8
kworker/4:2-3132 [004] .... 254.169962: rtos_queue_send_from_isr_failed: tstamp:8225824401 queue:0x0b4b0098
kworker/4:2-3132 [004] .... 254.169963: rtos_queue_send_from_isr_failed: tstamp:8225824512 queue:0x0b4b0e58
kworker/4:2-3132 [004] .... 254.169964: rtos_queue_send_from_isr_failed: tstamp:8225824621 queue:0x0b4b1c18
kworker/4:2-3132 [004] .... 254.169965: rtos_queue_send_failed: tstamp:8225825595 queue:0x0b4a7258
kworker/4:2-3132 [004] .... 254.169966: rtos_queue_send_from_isr_failed: tstamp:8225831773 queue:0x0b4a7258
kworker/4:2-3132 [004] .... 254.169967: rtos_queue_send_from_isr_failed: tstamp:8225831896 queue:0x0b4aad68
kworker/4:2-3132 [004] .... 254.169968: rtos_queue_send_from_isr_failed: tstamp:8225832009 queue:0x0b4ac998
kworker/4:2-3132 [004] .... 254.169969: rtos_queue_send_from_isr_failed: tstamp:8225832119 queue:0x0b4ae518
kworker/4:2-3132 [004] .... 254.169970: rtos_queue_send_from_isr_failed: tstamp:8225832229 queue:0x0b4af2d8
kworker/4:2-3132 [004] .... 254.169971: rtos_queue_send_from_isr_failed: tstamp:8225832338 queue:0x0b4b0098
kworker/4:2-3132 [004] .... 254.169973: rtos_queue_send_from_isr_failed: tstamp:8225832447 queue:0x0b4b0e58
kworker/4:2-3132 [004] .... 254.169974: rtos_queue_send_from_isr_failed: tstamp:8225832556 queue:0x0b4b1c18
kworker/4:2-3132 [004] .... 254.169975: rtos_queue_send_failed: tstamp:8225833143 queue:0x0b4a7258
kworker/4:2-3132 [004] .... 254.169976: rtos_queue_send_from_isr_failed: tstamp:8225835984 queue:0x0b4a7258
kworker/4:2-3132 [004] .... 254.169977: rtos_queue_send_from_isr_failed: tstamp:8225836107 queue:0x0b4aad68
kworker/4:2-3132 [004] .... 254.169979: rtos_queue_send_from_isr_failed: tstamp:8225836219 queue:0x0b4ac998
kworker/4:2-3132 [004] .... 254.169980: rtos_queue_send_from_isr_failed: tstamp:8225836329 queue:0x0b4ae518
kworker/4:2-3132 [004] .... 254.169981: rtos_queue_send_from_isr_failed: tstamp:8225836438 queue:0x0b4af2d8
kworker/4:2-3132 [004] .... 254.169982: rtos_queue_send_from_isr_failed: tstamp:8225836548 queue:0x0b4b0098
kworker/4:2-3132 [004] .... 254.169983: rtos_queue_send_from_isr_failed: tstamp:8225836660 queue:0x0b4b0e58
kworker/4:2-3132 [004] .... 254.169984: rtos_queue_send_from_isr_failed: tstamp:8225836770 queue:0x0b4b1c18
kworker/4:2-3132 [004] .... 254.169985: rtos_queue_send_failed: tstamp:8225837217 queue:0x0b4a7258
v4l2-ctl-9610 [000] .... 254.173030: tegra_channel_set_power: s5k4hayx 2-002d : 0x0
v4l2-ctl-9610 [000] .... 254.173052: camera_common_s_power: status : 0x0
v4l2-ctl-9610 [004] .... 254.175265: tegra_channel_set_power: 150c0000.nvcsi--1 : 0x0
v4l2-ctl-9610 [004] .... 254.175269: csi_s_power: enable : 0x0
kworker/4:2-3132 [004] .... 254.281968: rtos_queue_peek_from_isr_failed: tstamp:8228955422 queue:0x0b4b4500
kworker/4:2-3132 [004] .... 254.449978: rtos_queue_peek_from_isr_failed: tstamp:8233955419 queue:0x0b4b4500
kworker/4:2-3132 [004] .... 254.617982: rtos_queue_peek_from_isr_failed: tstamp:8238955423 queue:0x0b4b4500
kworker/4:1-719 [004] .... 254.785917: rtos_queue_peek_from_isr_failed: tstamp:8243955435 queue:0x0b4b4500
kworker/4:1-719 [004] .... 254.953971: rtos_queue_peek_from_isr_failed: tstamp:8248955450 queue:0x0b4b4500
kworker/4:1-719 [004] .... 255.065943: rtos_queue_peek_from_isr_failed: tstamp:8253955443 queue:0x0b4b4500
kworker/4:1-719 [004] .... 255.233964: rtos_queue_peek_from_isr_failed: tstamp:8258955458 queue:0x0b4b4500
kworker/4:1-719 [004] .... 255.401954: rtos_queue_peek_from_isr_failed: tstamp:8263955458 queue:0x0b4b4500
kworker/4:1-719 [004] .... 255.569963: rtos_queue_peek_from_isr_failed: tstamp:8268955464 queue:0x0b4b4500
kworker/4:1-719 [004] .... 255.737958: rtos_queue_peek_from_isr_failed: tstamp:8273955524 queue:0x0b4b4500
Trace log for the second problem :
# tracer: nop
# _-----=> irqs-off
# ||| / delay
v4l2-ctl-12003 [003] .... 3648.110756: tegra_channel_open: vi-output, s5k4hayx 2-002d
v4l2-ctl-12003 [000] .... 3648.112706: tegra_channel_set_power: s5k4hayx 2-002d : 0x1
v4l2-ctl-12003 [000] .... 3648.112726: camera_common_s_power: status : 0x1
v4l2-ctl-12003 [000] .... 3648.117136: tegra_channel_set_power: 150c0000.nvcsi--1 : 0x1
v4l2-ctl-12003 [000] .... 3648.117140: csi_s_power: enable : 0x1
v4l2-ctl-12003 [000] .... 3648.143705: tegra_channel_capture_setup: vnc_id 0 W 3264 H 2448 fmt 20
vi-output, s5k4-12004 [004] .... 3648.143816: tegra_channel_set_stream: enable : 0x1
vi-output, s5k4-12004 [004] .... 3648.145178: tegra_channel_set_stream: 150c0000.nvcsi--1 : 0x1
vi-output, s5k4-12004 [004] .... 3648.145180: csi_s_stream: enable : 0x1
vi-output, s5k4-12004 [004] .... 3648.145206: tegra_channel_set_stream: s5k4hayx 2-002d : 0x1
vi-output, s5k4-12004 [004] .... 3648.167391: tegra_channel_capture_frame: sof:3647.941221846
kworker/4:0-11715 [004] .... 3648.190143: rtos_queue_peek_from_isr_failed: tstamp:114287836352 queue:0x0b4b4500
kworker/4:0-11715 [004] .... 3648.190148: rtcpu_start: tstamp:114287837230
kworker/4:0-11715 [004] .... 3648.190149: rtos_queue_send_from_isr_failed: tstamp:114287845635 queue:0x0b4a7258
kworker/4:0-11715 [004] .... 3648.190150: rtos_queue_send_from_isr_failed: tstamp:114287845742 queue:0x0b4aad68
kworker/4:0-11715 [004] .... 3648.190151: rtos_queue_send_from_isr_failed: tstamp:114287845849 queue:0x0b4ac998
kworker/4:0-11715 [004] .... 3648.190152: rtos_queue_send_from_isr_failed: tstamp:114287845959 queue:0x0b4ae518
kworker/4:0-11715 [004] .... 3648.190152: rtos_queue_send_from_isr_failed: tstamp:114287846064 queue:0x0b4af2d8
kworker/4:0-11715 [004] .... 3648.190153: rtos_queue_send_from_isr_failed: tstamp:114287846169 queue:0x0b4b0098
kworker/4:0-11715 [004] .... 3648.190154: rtos_queue_send_from_isr_failed: tstamp:114287846273 queue:0x0b4b0e58
kworker/4:0-11715 [004] .... 3648.190155: rtos_queue_send_from_isr_failed: tstamp:114287846379 queue:0x0b4b1c18
kworker/4:0-11715 [004] .... 3648.190157: rtos_queue_send_failed: tstamp:114287846843 queue:0x0b4a7258
kworker/4:0-11715 [004] .... 3648.190157: rtos_queue_send_from_isr_failed: tstamp:114287848551 queue:0x0b4a7258
kworker/4:0-11715 [004] .... 3648.190158: rtos_queue_send_from_isr_failed: tstamp:114287848669 queue:0x0b4aad68
kworker/4:0-11715 [004] .... 3648.190159: rtos_queue_send_from_isr_failed: tstamp:114287848775 queue:0x0b4ac998
kworker/4:0-11715 [004] .... 3648.190159: rtos_queue_send_from_isr_failed: tstamp:114287848882 queue:0x0b4ae518
kworker/4:0-11715 [004] .... 3648.190160: rtos_queue_send_from_isr_failed: tstamp:114287848985 queue:0x0b4af2d8
kworker/4:0-11715 [004] .... 3648.190161: rtos_queue_send_from_isr_failed: tstamp:114287849089 queue:0x0b4b0098
kworker/4:0-11715 [004] .... 3648.190161: rtos_queue_send_from_isr_failed: tstamp:114287849195 queue:0x0b4b0e58
kworker/4:0-11715 [004] .... 3648.190162: rtos_queue_send_from_isr_failed: tstamp:114287849307 queue:0x0b4b1c18
kworker/4:0-11715 [004] .... 3648.190163: rtos_queue_send_failed: tstamp:114287850248 queue:0x0b4a7258
kworker/4:0-11715 [004] .... 3648.190165: rtcpu_vinotify_event: tstamp:114288588415 tag:CHANSEL_PXL_SOF channel:0x00 frame:1 vi_tstamp:114288587901 data:0x00000001
kworker/4:0-11715 [004] .... 3648.190165: rtcpu_vinotify_event: tstamp:114288588617 tag:ATOMP_FS channel:0x00 frame:1 vi_tstamp:114288587907 data:0x00000000
kworker/4:0-11715 [004] .... 3648.190166: rtcpu_vinotify_event: tstamp:114288592778 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:1 vi_tstamp:114288592398 data:0x08000000
vi-output, s5k4-12004 [004] .... 3648.222567: tegra_channel_capture_frame: sof:3647.996412022
kworker/4:0-11715 [004] .... 3648.246153: rtcpu_vinotify_event: tstamp:114290257323 tag:CHANSEL_PXL_EOF channel:0x00 frame:1 vi_tstamp:114290256650 data:0x098f0002
kworker/4:0-11715 [004] .... 3648.246159: rtcpu_vinotify_event: tstamp:114290257455 tag:ATOMP_FE channel:0x00 frame:1 vi_tstamp:114290256672 data:0x00000000
kworker/4:0-11715 [004] .... 3648.246160: rtcpu_vinotify_event: tstamp:114290313092 tag:CHANSEL_PXL_SOF channel:0x00 frame:2 vi_tstamp:114290312594 data:0x00000001
kworker/4:0-11715 [004] .... 3648.246161: rtcpu_vinotify_event: tstamp:114290313259 tag:ATOMP_FS channel:0x00 frame:2 vi_tstamp:114290312601 data:0x00000000
kworker/4:0-11715 [004] .... 3648.246162: rtcpu_vinotify_event: tstamp:114290317067 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:2 vi_tstamp:114290316703 data:0x08000000
vi-output, s5k4-12004 [004] .... 3648.277940: tegra_channel_capture_frame: sof:3648.51602230
kworker/4:0-11715 [004] .... 3648.302107: rtcpu_vinotify_event: tstamp:114291982005 tag:CHANSEL_PXL_EOF channel:0x00 frame:2 vi_tstamp:114291981343 data:0x098f0002
kworker/4:0-11715 [004] .... 3648.302110: rtcpu_vinotify_event: tstamp:114291982129 tag:ATOMP_FE channel:0x00 frame:2 vi_tstamp:114291981368 data:0x00000000
kworker/4:0-11715 [004] .... 3648.302110: rtcpu_vinotify_event: tstamp:114292037786 tag:CHANSEL_PXL_SOF channel:0x00 frame:3 vi_tstamp:114292037288 data:0x00000001
kworker/4:0-11715 [004] .... 3648.302110: rtcpu_vinotify_event: tstamp:114292037955 tag:ATOMP_FS channel:0x00 frame:3 vi_tstamp:114292037296 data:0x00000000
kworker/4:0-11715 [004] .... 3648.302111: rtcpu_vinotify_event: tstamp:114292050075 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:3 vi_tstamp:114292049706 data:0x08000000
vi-output, s5k4-12004 [004] .... 3648.332931: tegra_channel_capture_frame: sof:3648.106792470
kworker/4:0-11715 [004] .... 3648.358522: rtos_queue_peek_from_isr_failed: tstamp:114292836686 queue:0x0b4b4500
kworker/4:0-11715 [004] .... 3648.358527: rtcpu_vinotify_event: tstamp:114293706697 tag:CHANSEL_PXL_EOF channel:0x00 frame:3 vi_tstamp:114293706037 data:0x098f0002
kworker/4:0-11715 [004] .... 3648.358528: rtcpu_vinotify_event: tstamp:114293706815 tag:ATOMP_FE channel:0x00 frame:3 vi_tstamp:114293706061 data:0x00000000
kworker/4:0-11715 [004] .... 3648.358528: rtcpu_vinotify_event: tstamp:114293762479 tag:CHANSEL_PXL_SOF channel:0x00 frame:4 vi_tstamp:114293761983 data:0x00000001
kworker/4:0-11715 [004] .... 3648.358528: rtcpu_vinotify_event: tstamp:114293762642 tag:ATOMP_FS channel:0x00 frame:4 vi_tstamp:114293761990 data:0x00000000
kworker/4:0-11715 [004] .... 3648.358529: rtcpu_vinotify_event: tstamp:114293831830 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:4 vi_tstamp:114293831464 data:0x08000000
vi-output, s5k4-12004 [004] .... 3648.388141: tegra_channel_capture_frame: sof:3648.161982710
kworker/4:0-11715 [004] .... 3648.414138: rtcpu_vinotify_event: tstamp:114295431395 tag:CHANSEL_PXL_EOF channel:0x00 frame:4 vi_tstamp:114295430731 data:0x098f0002
kworker/4:0-11715 [004] .... 3648.414142: rtcpu_vinotify_event: tstamp:114295431521 tag:ATOMP_FE channel:0x00 frame:4 vi_tstamp:114295430756 data:0x00000000
kworker/4:0-11715 [004] .... 3648.414142: rtcpu_vinotify_event: tstamp:114295487181 tag:CHANSEL_PXL_SOF channel:0x00 frame:5 vi_tstamp:114295486678 data:0x00000001
kworker/4:0-11715 [004] .... 3648.414143: rtcpu_vinotify_event: tstamp:114295487358 tag:ATOMP_FS channel:0x00 frame:5 vi_tstamp:114295486684 data:0x00000000
kworker/4:0-11715 [004] .... 3648.414143: rtcpu_vinotify_event: tstamp:114295566159 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:5 vi_tstamp:114295565793 data:0x08000000
vi-output, s5k4-12004 [004] .... 3648.443317: tegra_channel_capture_frame: sof:3648.217172918
kworker/4:0-11715 [004] .... 3648.470109: rtcpu_vinotify_event: tstamp:114297156092 tag:CHANSEL_PXL_EOF channel:0x00 frame:5 vi_tstamp:114297155426 data:0x098f0002
kworker/4:0-11715 [004] .... 3648.470112: rtcpu_vinotify_event: tstamp:114297156212 tag:ATOMP_FE channel:0x00 frame:5 vi_tstamp:114297155450 data:0x00000000
kworker/4:0-11715 [004] .... 3648.470113: rtcpu_vinotify_event: tstamp:114297211866 tag:CHANSEL_PXL_SOF channel:0x00 frame:6 vi_tstamp:114297211372 data:0x00000001
kworker/4:0-11715 [004] .... 3648.470114: rtcpu_vinotify_event: tstamp:114297212028 tag:ATOMP_FS channel:0x00 frame:6 vi_tstamp:114297211378 data:0x00000000
kworker/4:0-11715 [004] .... 3648.470115: rtcpu_vinotify_event: tstamp:114297395273 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:6 vi_tstamp:114297394870 data:0x08000000
kworker/4:0-11715 [004] .... 3648.470117: rtos_queue_peek_from_isr_failed: tstamp:114297836705 queue:0x0b4b4500
vi-output, s5k4-12004 [004] .... 3648.498499: tegra_channel_capture_frame: sof:3648.272363158
kworker/4:0-11715 [004] .... 3648.526105: rtcpu_vinotify_event: tstamp:114298880798 tag:CHANSEL_PXL_EOF channel:0x00 frame:6 vi_tstamp:114298880120 data:0x098f0002
kworker/4:0-11715 [004] .... 3648.526108: rtcpu_vinotify_event: tstamp:114298880919 tag:ATOMP_FE channel:0x00 frame:6 vi_tstamp:114298880144 data:0x00000000
kworker/4:0-11715 [004] .... 3648.526109: rtcpu_vinotify_event: tstamp:114298936570 tag:CHANSEL_PXL_SOF channel:0x00 frame:7 vi_tstamp:114298936067 data:0x00000001
kworker/4:0-11715 [004] .... 3648.526110: rtcpu_vinotify_event: tstamp:114298936732 tag:ATOMP_FS channel:0x00 frame:7 vi_tstamp:114298936073 data:0x00000000
kworker/4:0-11715 [004] .... 3648.526110: rtcpu_vinotify_event: tstamp:114299180671 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:7 vi_tstamp:114299180298 data:0x08000000
vi-output, s5k4-12004 [004] .... 3648.553690: tegra_channel_capture_frame: sof:3648.327553334
kworker/4:0-11715 [004] .... 3648.582087: rtcpu_vinotify_event: tstamp:114300605497 tag:CHANSEL_PXL_EOF channel:0x00 frame:7 vi_tstamp:114300604815 data:0x098f0002
kworker/4:0-11715 [004] .... 3648.582090: rtcpu_vinotify_event: tstamp:114300605619 tag:ATOMP_FE channel:0x00 frame:7 vi_tstamp:114300604839 data:0x00000000
kworker/4:0-11715 [004] .... 3648.582091: rtcpu_vinotify_event: tstamp:114300661262 tag:CHANSEL_PXL_SOF channel:0x00 frame:8 vi_tstamp:114300660760 data:0x00000001
kworker/4:0-11715 [004] .... 3648.582091: rtcpu_vinotify_event: tstamp:114300661425 tag:ATOMP_FS channel:0x00 frame:8 vi_tstamp:114300660767 data:0x00000000
kworker/4:0-11715 [004] .... 3648.582092: rtcpu_vinotify_event: tstamp:114300936974 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:8 vi_tstamp:114300936599 data:0x08000000
vi-output, s5k4-12004 [005] .... 3648.608900: tegra_channel_capture_frame: sof:3648.382743574
kworker/4:0-11715 [004] .... 3648.638106: rtcpu_vinotify_event: tstamp:114302330183 tag:CHANSEL_PXL_EOF channel:0x00 frame:8 vi_tstamp:114302329509 data:0x098f0002
kworker/4:0-11715 [004] .... 3648.638110: rtcpu_vinotify_event: tstamp:114302330306 tag:ATOMP_FE channel:0x00 frame:8 vi_tstamp:114302329533 data:0x00000000
kworker/4:0-11715 [004] .... 3648.638110: rtcpu_vinotify_event: tstamp:114302385957 tag:CHANSEL_PXL_SOF channel:0x00 frame:9 vi_tstamp:114302385455 data:0x00000001
kworker/4:0-11715 [004] .... 3648.638111: rtcpu_vinotify_event: tstamp:114302386119 tag:ATOMP_FS channel:0x00 frame:9 vi_tstamp:114302385462 data:0x00000000
kworker/4:0-11715 [004] .... 3648.638111: rtcpu_vinotify_event: tstamp:114302635151 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:9 vi_tstamp:114302634778 data:0x08000000
kworker/4:0-11715 [004] .... 3648.638113: rtos_queue_peek_from_isr_failed: tstamp:114302836707 queue:0x0b4b4500
vi-output, s5k4-12004 [005] .... 3648.664072: tegra_channel_capture_frame: sof:3648.437933782
kworker/4:0-11715 [004] .... 3648.694093: rtcpu_vinotify_event: tstamp:114304054882 tag:CHANSEL_PXL_EOF channel:0x00 frame:9 vi_tstamp:114304054203 data:0x098f0002
kworker/4:0-11715 [004] .... 3648.694097: rtcpu_vinotify_event: tstamp:114304055004 tag:ATOMP_FE channel:0x00 frame:9 vi_tstamp:114304054228 data:0x00000000
kworker/4:0-11715 [004] .... 3648.694097: rtcpu_vinotify_event: tstamp:114304110650 tag:CHANSEL_PXL_SOF channel:0x00 frame:10 vi_tstamp:114304110149 data:0x00000001
kworker/4:0-11715 [004] .... 3648.694098: rtcpu_vinotify_event: tstamp:114304110813 tag:ATOMP_FS channel:0x00 frame:10 vi_tstamp:114304110156 data:0x00000000
kworker/4:0-11715 [004] .... 3648.694099: rtcpu_vinotify_event: tstamp:114304404289 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:10 vi_tstamp:114304403914 data:0x08000000
vi-output, s5k4-12004 [005] .... 3648.719260: tegra_channel_capture_frame: sof:3648.493124022
kworker/4:0-11715 [004] .... 3648.750095: rtcpu_vinotify_event: tstamp:114305779574 tag:CHANSEL_PXL_EOF channel:0x00 frame:10 vi_tstamp:114305778898 data:0x098f0002
kworker/4:0-11715 [004] .... 3648.750098: rtcpu_vinotify_event: tstamp:114305779696 tag:ATOMP_FE channel:0x00 frame:10 vi_tstamp:114305778922 data:0x00000000
kworker/4:0-11715 [004] .... 3648.750099: rtcpu_vinotify_event: tstamp:114305835345 tag:CHANSEL_PXL_SOF channel:0x00 frame:11 vi_tstamp:114305834844 data:0x00000001
kworker/4:0-11715 [004] .... 3648.750100: rtcpu_vinotify_event: tstamp:114305835506 tag:ATOMP_FS channel:0x00 frame:11 vi_tstamp:114305834850 data:0x00000000
kworker/4:0-11715 [004] .... 3648.750101: rtcpu_vinotify_event: tstamp:114306120543 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:11 vi_tstamp:114306120170 data:0x08000000
vi-output, s5k4-12004 [004] .... 3648.774454: tegra_channel_capture_frame: sof:3648.548314230
kworker/4:0-11715 [004] .... 3648.806114: rtcpu_vinotify_event: tstamp:114307504264 tag:CHANSEL_PXL_EOF channel:0x00 frame:11 vi_tstamp:114307503592 data:0x098f0002
kworker/4:0-11715 [004] .... 3648.806117: rtcpu_vinotify_event: tstamp:114307504386 tag:ATOMP_FE channel:0x00 frame:11 vi_tstamp:114307503616 data:0x00000000
kworker/4:0-11715 [004] .... 3648.806118: rtcpu_vinotify_event: tstamp:114307560040 tag:CHANSEL_PXL_SOF channel:0x00 frame:12 vi_tstamp:114307559538 data:0x00000001
kworker/4:0-11715 [004] .... 3648.806118: rtcpu_vinotify_event: tstamp:114307560204 tag:ATOMP_FS channel:0x00 frame:12 vi_tstamp:114307559545 data:0x00000000
kworker/4:0-11715 [004] .... 3648.806121: rtos_queue_peek_from_isr_failed: tstamp:114307836710 queue:0x0b4b4500
kworker/4:0-11715 [004] .... 3648.806122: rtcpu_vinotify_event: tstamp:114307861379 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:12 vi_tstamp:114307861010 data:0x08000000
vi-output, s5k4-12004 [004] .... 3648.829639: tegra_channel_capture_frame: sof:3648.603504438
kworker/4:0-11715 [004] .... 3648.862169: rtcpu_vinotify_event: tstamp:114309228962 tag:CHANSEL_PXL_EOF channel:0x00 frame:12 vi_tstamp:114309228287 data:0x098f0002
kworker/4:0-11715 [004] .... 3648.862173: rtcpu_vinotify_event: tstamp:114309229091 tag:ATOMP_FE channel:0x00 frame:12 vi_tstamp:114309228310 data:0x00000000
kworker/4:0-11715 [004] .... 3648.862174: rtcpu_vinotify_event: tstamp:114309284736 tag:CHANSEL_PXL_SOF channel:0x00 frame:13 vi_tstamp:114309284232 data:0x00000001
kworker/4:0-11715 [004] .... 3648.862175: rtcpu_vinotify_event: tstamp:114309284898 tag:ATOMP_FS channel:0x00 frame:13 vi_tstamp:114309284238 data:0x00000000
kworker/4:0-11715 [004] .... 3648.862176: rtcpu_vinotify_event: tstamp:114309548923 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:13 vi_tstamp:114309548547 data:0x08000000
vi-output, s5k4-12004 [005] .... 3648.884836: tegra_channel_capture_frame: sof:3648.658694678
v4l2-ctl-12003 [005] .... 3648.885211: tegra_channel_set_stream: enable : 0x0
v4l2-ctl-12003 [005] .... 3648.885215: tegra_channel_set_stream: s5k4hayx 2-002d : 0x0
v4l2-ctl-12003 [000] .... 3648.885466: tegra_channel_set_stream: 150c0000.nvcsi--1 : 0x0
v4l2-ctl-12003 [000] .... 3648.885472: csi_s_stream: enable : 0x0
v4l2-ctl-12003 [000] .... 3648.893553: tegra_channel_close: vi-output, s5k4hayx 2-002d
v4l2-ctl-12003 [000] .... 3648.898451: tegra_channel_set_power: s5k4hayx 2-002d : 0x0
v4l2-ctl-12003 [000] .... 3648.898468: camera_common_s_power: status : 0x0
v4l2-ctl-12003 [000] .... 3648.900610: tegra_channel_set_power: 150c0000.nvcsi--1 : 0x0
v4l2-ctl-12003 [000] .... 3648.900613: csi_s_power: enable : 0x0
kworker/4:0-11715 [004] .... 3648.918123: rtcpu_vinotify_event: tstamp:114310953681 tag:CHANSEL_PXL_EOF channel:0x00 frame:13 vi_tstamp:114310952981 data:0x098f0002
kworker/4:0-11715 [004] .... 3648.918126: rtcpu_vinotify_event: tstamp:114310953808 tag:ATOMP_FE channel:0x00 frame:13 vi_tstamp:114310953005 data:0x00000000
kworker/4:0-11715 [004] .... 3648.918127: rtcpu_vinotify_event: tstamp:114311009430 tag:CHANSEL_PXL_SOF channel:0x00 frame:14 vi_tstamp:114311008927 data:0x00000001
kworker/4:0-11715 [004] .... 3648.918127: rtcpu_vinotify_event: tstamp:114311009594 tag:ATOMP_FS channel:0x00 frame:14 vi_tstamp:114311008933 data:0x00000000
kworker/4:0-11715 [004] .... 3648.918130: rtos_queue_send_from_isr_failed: tstamp:114311014210 queue:0x0b4a7258
kworker/4:0-11715 [004] .... 3648.918131: rtos_queue_send_from_isr_failed: tstamp:114311014323 queue:0x0b4aad68
kworker/4:0-11715 [004] .... 3648.918131: rtos_queue_send_from_isr_failed: tstamp:114311014434 queue:0x0b4ac998
kworker/4:0-11715 [004] .... 3648.918132: rtos_queue_send_from_isr_failed: tstamp:114311014546 queue:0x0b4ae518
kworker/4:0-11715 [004] .... 3648.918133: rtos_queue_send_from_isr_failed: tstamp:114311014653 queue:0x0b4af2d8
kworker/4:0-11715 [004] .... 3648.918133: rtos_queue_send_from_isr_failed: tstamp:114311014774 queue:0x0b4b0098
kworker/4:0-11715 [004] .... 3648.918134: rtos_queue_send_from_isr_failed: tstamp:114311014882 queue:0x0b4b0e58
kworker/4:0-11715 [004] .... 3648.918134: rtos_queue_send_from_isr_failed: tstamp:114311014993 queue:0x0b4b1c18
kworker/4:0-11715 [004] .... 3648.918135: rtcpu_vinotify_event: tstamp:114311015128 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:14 vi_tstamp:114311013488 data:0x08000000
kworker/4:0-11715 [004] .... 3648.918136: rtcpu_vinotify_event: tstamp:114311015238 tag:CHANSEL_FAULT_FE channel:0x01 frame:14 vi_tstamp:114311013488 data:0x00000001
kworker/4:0-11715 [004] .... 3648.918136: rtcpu_vinotify_event: tstamp:114311015443 tag:ATOMP_FE channel:0x00 frame:14 vi_tstamp:114311013491 data:0x00000000
kworker/4:0-11715 [004] .... 3648.918138: rtos_queue_send_failed: tstamp:114311016077 queue:0x0b4a7258
kworker/4:0-11715 [004] .... 3648.918139: rtos_queue_send_from_isr_failed: tstamp:114311017609 queue:0x0b4a7258
kworker/4:0-11715 [004] .... 3648.918139: rtos_queue_send_from_isr_failed: tstamp:114311017716 queue:0x0b4aad68
kworker/4:0-11715 [004] .... 3648.918140: rtos_queue_send_from_isr_failed: tstamp:114311017824 queue:0x0b4ac998
kworker/4:0-11715 [004] .... 3648.918141: rtos_queue_send_from_isr_failed: tstamp:114311017931 queue:0x0b4ae518
kworker/4:0-11715 [004] .... 3648.918141: rtos_queue_send_from_isr_failed: tstamp:114311018035 queue:0x0b4af2d8
kworker/4:0-11715 [004] .... 3648.918142: rtos_queue_send_from_isr_failed: tstamp:114311018139 queue:0x0b4b0098
kworker/4:0-11715 [004] .... 3648.918143: rtos_queue_send_from_isr_failed: tstamp:114311018244 queue:0x0b4b0e58
kworker/4:0-11715 [004] .... 3648.918143: rtos_queue_send_from_isr_failed: tstamp:114311018354 queue:0x0b4b1c18
kworker/4:0-11715 [004] .... 3648.918144: rtos_queue_send_failed: tstamp:114311018785 queue:0x0b4a7258
kworker/4:0-11715 [004] .... 3648.974144: rtos_queue_peek_from_isr_failed: tstamp:114312836722 queue:0x0b4b4500
kworker/4:0-11715 [004] .... 3649.142211: rtos_queue_peek_from_isr_failed: tstamp:114317836729 queue:0x0b4b4500
kworker/4:0-11715 [004] .... 3649.310179: rtos_queue_peek_from_isr_failed: tstamp:114322836732 queue:0x0b4b4500
kworker/4:0-11715 [004] .... 3649.478254: rtos_queue_peek_from_isr_failed: tstamp:114327836746 queue:0x0b4b4500
kworker/4:0-11715 [004] .... 3649.590227: rtos_queue_peek_from_isr_failed: tstamp:114332836745 queue:0x0b4b4500
kworker/4:0-11715 [004] .... 3649.758228: rtos_queue_peek_from_isr_failed: tstamp:114337836754 queue:0x0b4b4500
kworker/4:0-11715 [004] .... 3649.926211: rtos_queue_peek_from_isr_failed: tstamp:114342836778 queue:0x0b4b4500
kworker/4:2-12009 [004] .... 3650.094202: rtos_queue_peek_from_isr_failed: tstamp:114347836767 queue:0x0b4b4500
kworker/4:2-12009 [004] .... 3650.262263: rtos_queue_peek_from_isr_failed: tstamp:114352836773 queue:0x0b4b4500
kworker/4:2-12009 [004] .... 3650.430228: rtos_queue_peek_from_isr_failed: tstamp:114357836783 queue:0x0b4b4500
kworker/4:2-12009 [004] .... 3650.598202: rtos_queue_peek_from_isr_failed: tstamp:114362836788 queue:0x0b4b4500
kworker/4:2-12009 [004] .... 3650.710213: rtos_queue_peek_from_isr_failed: tstamp:114367836794 queue:0x0b4b4500
kworker/4:2-12009 [004] .... 3650.878201: rtos_queue_peek_from_isr_failed: tstamp:114372836801 queue:0x0b4b4500
kworker/4:2-12009 [004] .... 3651.046214: rtos_queue_peek_from_isr_failed: tstamp:114377836814 queue:0x0b4b4500
kworker/4:2-12009 [004] .... 3651.214222: rtos_queue_peek_from_isr_failed: tstamp:114382836814 queue:0x0b4b4500
kworker/4:2-12009 [004] .... 3651.382231: rtos_queue_peek_from_isr_failed: tstamp:114387836836 queue:0x0b4b4500
kworker/4:2-12009 [004] .... 3651.550197: rtos_queue_peek_from_isr_failed: tstamp:114392836829 queue:0x0b4b4500
kworker/4:2-12009 [004] .... 3651.718173: rtos_queue_peek_from_isr_failed: tstamp:114397836835 queue:0x0b4b4500
kworker/4:2-12009 [004] .... 3651.830204: rtos_queue_peek_from_isr_failed: tstamp:114402836847 queue:0x0b4b4500
kworker/4:2-12009 [004] .... 3651.998197: rtos_queue_peek_from_isr_failed: tstamp:114407836849 queue:0x0b4b4500
kworker/4:2-12009 [004] .... 3652.166198: rtos_queue_peek_from_isr_failed: tstamp:114412836855 queue:0x0b4b4500
kworker/4:2-12009 [004] .... 3652.334238: rtos_queue_peek_from_isr_failed: tstamp:114417836864 queue:0x0b4b4500
kworker/4:2-12009 [004] .... 3652.502197: rtos_queue_peek_from_isr_failed: tstamp:114422836875 queue:0x0b4b4500
kworker/4:2-12009 [004] .... 3652.670184: rtos_queue_peek_from_isr_failed: tstamp:114427836876 queue:0x0b4b4500
kworker/4:2-12009 [004] .... 3652.838213: rtos_queue_peek_from_isr_failed: tstamp:114432836883 queue:0x0b4b4500
kworker/4:2-12009 [004] .... 3652.950228: rtos_queue_peek_from_isr_failed: tstamp:114437836888 queue:0x0b4b4500
kworker/4:2-12009 [004] .... 3653.118220: rtos_queue_peek_from_isr_failed: tstamp:114442836917 queue:0x0b4b4500
kworker/4:2-12009 [004] .... 3653.286209: rtos_queue_peek_from_isr_failed: tstamp:114447836904 queue:0x0b4b4500
kworker/4:2-12009 [004] .... 3653.454143: rtos_queue_peek_from_isr_failed: tstamp:114452836913 queue:0x0b4b4500
I think it’s related to clock or something but I’m new in this field so I don’t know much about this.
Please help me.
