Hello
When I use a declared integer variable as loop variable for an implied-do and then use the same variable in an internal subroutine, it seems to become aliased to another variable.
In the example, the loop in the subroutine executes the required number of iterations, but the value of the outer loop variable i is always equal to the inner loop variable j. This example works fine with other compilers.
Example:
PROGRAM pgitest
IMPLICIT NONE
INTEGER, PARAMETER :: imax=2, &
jmax=3
INTEGER :: i, j, array(10)=(/(i, i=1,10)/)
CALL sub1
CONTAINS
SUBROUTINE sub1()
print*, “imax,jmax”, imax,jmax
do i=1,imax
do j=1,jmax
print*, “i,j”,i,j
end do
end do
END SUBROUTINE sub1
This example code should print
~> a.out
imax,jmax 2 3
i,j 1 1
i,j 1 2
i,j 1 3
i,j 2 1
i,j 2 2
i,j 2 3
but when compiled with pgfortran, I get instead:
~> pgfortran -V
pgfortran 13.10-0 64-bit target on x86-64 Linux -tp sandybridge
The Portland Group - PGI Compilers and Tools
Copyright (c) 2013, NVIDIA CORPORATION. All rights reserved.
~> pgfortran pgitest.f90
~> ./a.out
imax,jmax 2 3
i,j 1 1
i,j 2 2
i,j 3 3
i,j 1 1
i,j 2 2
i,j 3 3
Regards
Pirmin
