Can you provide the whole components that are connected to VDD_SOC?
And VDD_GPU_SOC in AGX Orin as well if you can?
Unfortunately, the provided context does not mention the specific components connected to VDDSOC and VDDGPUSOC in the Jetson AGX Orin. The context only provides information about the board configuration, including the System on Module (SOM) and carrier board, as well as the thermal solution.
However, I can try to provide some general information about the power management system in the Jetson AGX Orin.
The Jetson AGX Orin is a complex system-on-chip (SoC) that requires multiple power rails to operate. VDDSOC and VDDGPUSOC are likely two of the power rails that supply power to the SoC.
VDDSOC is likely the power rail that supplies power to the SoC’s CPU and other system components, while VDDGPUSOC is likely the power rail that supplies power to the SoC’s GPU.
In general, the components connected to these power rails would include:
However, without more specific information about the Jetson AGX Orin’s power management system, it is difficult to provide a comprehensive list of components connected to VDDSOC and VDDGPUSOC.
If you have any more information or context about the Jetson AGX Orin’s power management system, I may be able to provide more specific information.
