From reading the forums and the docs I understand that VDD_SOC does not include VDD_CPU and VDD_GPU and also VDD_SYS5V does include DDR, CPU, GPU and CV. So what is the difference between VDD_SOC and VDD_SYS5V?
I have already looked at the following two devtalk posts:
Ok that makes sense for SYS5V. And from the other links SOC doesn’t contain CPU, GPU, DDR, and CV so what exactly is SOC measuring?
Also we don’t have any issues, we are just trying to profile the power workload of an application so this information is necessary for that. Even at idle in our monitoring SOC power usage is fairly significant so we are confused what is causing this high usage.
VDD_SOC is mainly for internal a set of embedded processors, you can find a Xavier Processor Block Diagram in Xavier Series SoC Technical Reference Manual in DLC. https://developer.nvidia.com/embedded/downloads
